2019 GMC Sierra Lease Deals and Prices
11012141516
  • gator83gator83 Member Posts: 1
    looking for money factor and residual on 2019 Sierra AT4 crew cab 4X4 39/12 and 39/15 zip 08753
  • MichaellMichaell Moderator Posts: 269,587
    39/15
    .00186 and 61%
    Total Cash of $5800 includes:
    $1500 GM Select Market Incremental CCR Program exp. 09/30/2019
    $4300 GM Select Market Incremental CCR Program exp. 09/30/2019
  • cbuckscbucks Member Posts: 5
    Curious if there are different promotions for areas? I have an office with multiple locations can buy out of whichever is best
    cbucks said:
    Anyone have the numbers & incentives for 2019 Sierra 1500 Crew Cab Standard Box 4x4, 36/15k or 36/10k, zips 60527, 46360 or 49117? Thanks!
    Why so many zip codes?
    What trim level?
  • DawgrepDawgrep Member Posts: 20
    edited September 2019
    Residual, MF and Incentives on 2019 Denali 36/12
    46802
    46802
    .00183 and 61% (36/15) or 59% (39/15)
    $5650 incentives
    46802
    $5650 incentives
    Thanks, and 36/12 ? I had it buried on the top line?
    Dawgrep said:
    46802
    $5650 incentives
    Dawgrep said:
    46802
    $5650 incentives
    Add 2% for 12K
  • GutterGutter Member Posts: 2
    Can I get MF, residual and incentives
    2019 Sierra Denali 4x4 36mo/12k Zip Code: 32808
    Thanks!!
    Thanks!!
    .00183 and 63%
    $5025 incentives
  • jdmfreejdmfree Member Posts: 5
    MF/residual/incentives
    19 elevation double cab
    24/12
    24/12
    Why do you need a different milage allowance for the different terms?
    24/12
    sorry
  • kyfdxkyfdx Moderator Posts: 273,559
    24/12
    sorry
    Assuming 4X4
    .00191 MF
    64%/62% residual
    $4900 incentive
    24/12
    sorry
    Assuming 4X4
    .00191 MF
    64%/62% residual
    $4900 incentive
    yes 4x4. does it change much going to a crew cab? this will be a second truck for me so shopping for the best deal.
    also 4900 incentive is for any customer, not returning GM?
    jdmfree said:
    24/12
    sorry
    Assuming 4X4
    .00191 MF
    64%/62% residual
    $4900 incentive
    I don't see an Elevation trim in the Crew Cab
    No qualifiers on the incentive
  • Tomski12Tomski12 Member Posts: 17
    Hi ,
    I’m looking for the mf, rv, and any incentives for a 2019 Sierra 1500 Denali 4x4 in 84403. 36/12.
    Tomski12 said:
    Hi ,
    .00183 MF and 63% residual
    $4650 customer incentive
    Sorry to ask again
    2019 Sierra slt 4x4 crew 19053
    jdmfree said:
    Sorry to ask again
    .00186 and 62% (36/15) or 61% (39/15)
    $5400 incentives
  • pacopg3pacopg3 Member Posts: 81
    Can I please have MF, Residual and incentives on the following:
    Elevation Crew Cab 4x4
    AT4 4x4
    Denali 4x4
    Denali 4x2
    Zip 85250, 36mos , 12k miles.
    Thanks in advance!
    AT4 4x4
    Denali 4x4
    Denali 4x2
    Thanks in advance!
    I don't see the Elevation available as a Crew cab, just Double Cab
    Elevation Double
    .00191 MF and 64% residual
    $3400 customer incentive
    AT4
    .00186 MF and 64% residual
    $4300 incentive
    Denali (either)
    $4650 incentive
    AT4 4x4
    Denali 4x4
    Denali 4x2
    Thanks in advance!
    Elevation Double
    AT4
    $4300 incentive
    Denali (either)
    $4650 incentive
    Thank you for the information! I will post when I finish the deal.
  • SteveheinoSteveheino Member Posts: 18
    Hello, may I please have some help finding the MF, residual and incentives for:
    SLE 4x4 Double Cab 2.7L
    ultra-low mileage (not sure if there's less than 10k miles offered)
    36, 39 (if offered), 48 mo
    Zip: 60914
    Zip: 60914
    36/39/10: .00191 MF and 65%/63% residual
    42/48/10: .00219 MF and 61%/59% residual
    $3300 customer incentive
  • didamp65didamp65 Member Posts: 36
    Can I please have the MF and Residual & Incentives for both the AT4 and Denali crew cab for 13760? 36 & 39 @ 15k
    AT4 - .00186 and 62% / 61%; $5800 customer incentive
    Denali - .00183 and 61% / 59%; $6150 customer incentive
  • vpegany1vpegany1 Member Posts: 33
    Hello ! Can I please get lease numbers plus incentives for 2019 Sierra 4X4 crew cab both SLT and DENALI trim levels. 36/10k in zip code 95991
    SLT - .00186 and 65%; $3900 customer incentive
    Denali - .00183 and 64%; $4650 customer incentive
    AT4 4x4
    Denali 4x4
    Denali 4x2
    Thanks in advance!
    Elevation Double
    AT4
    $4300 incentive
    Denali (either)
    $4650 incentive
    thanks you for the previous information! Can you please also provide MF, residual and incentives on SLT crew cab 4x4 and 4x2, 36 mos, 12k miles, zip 85250?
    AT4 4x4
    Denali 4x4
    Denali 4x2
    Thanks in advance!
    Elevation Double
    AT4
    $4300 incentive
    Denali (either)
    $4650 incentive
    SLT Crew 4x2 - .00168 and 62%
    SLT Crew 4x4 - .00186 and 64%
    AT4 4x4
    Denali 4x4
    Denali 4x2
    Thanks in advance!
    Elevation Double
    AT4
    $4300 incentive
    Denali (either)
    $4650 incentive
    Thanks for all the information! Came through again! Ended up with a 2019 2WD Denali with Tech and Driver Assist 2 packages. 3 yrs, 12k miles, 0 out of pocket, $476 including tax.
    Hope this helps other people do their deals.
    pacopg3 said:
    AT4 4x4
    Denali 4x4
    Denali 4x2
    Thanks in advance!
    Elevation Double
    AT4
    $4300 incentive
    Denali (either)
    $4650 incentive
  • GoHogsARGoHogsAR Member Posts: 3
    May I please have the MF, residual, and incentives:
    2019 Denali crew cab
    36 months
    12k
    72712
    36 months
    12k
    72712
    Thank you. Will report back.
  • XoFQuietXoFQuiet Member Posts: 9
    May I please have the MF, residual, incentives, monthly payment(if possible):
    2019 Denali Ultimate crew cab 4x4 White Frost Tri Coat
    36 months
    10k
    66061
    36 months
    10k
    66061
    .00183 and 64%
    No incentives
  • chrisndenisechrisndenise Member Posts: 13
    Can I get MF, residual and incentives for 36/15 in 97006? Denali and SLT 4x4? Thank you.
    SLT: .00186 MF and 62% residual
    Denali: .00183 MF and 61% residual
  • MxwlBishMxwlBish Member Posts: 9
    Can someone please provide me with the MF, residual and incentives for a 2019 Denali? 75056.
    Also - any clarity on how those numbers might be affected if it were a 4k mile demo would be appreciated.
    No info on how GMF handles demos, but a reduction in residual is likely.
    Sorry about that. Left out a sentence... 36/15. 1500 Crewcab, short box, 4x4.
    All Denalis have the same program. ^^^^^
    Well, nothing to report yet. Worked with a couple of different dealers in the state and both are arriving at $~795/month for an Ultimate. Tax is high here (9.5%) but looks like I'm holding out to see what the October deals look like. Hoping to get down to $700/month.
  • C5chris99C5chris99 Member Posts: 11
    Hello, Can I please have the MF and Residual & Incentives for both the 19 Sierra 1500 Denali for 06484? 36 & 39 @ 15k. Thanks in advance
  • RjhoffmanRjhoffman Member Posts: 10
    Hey looking for Octobers MF and RV located in zip 10583 on
    Sierra Denali 4x4 6.2L
    36/12k
    24/12k
    Sierra SLT 4x4 6.2L
    36/12k
    24/12k
  • IronYIronY Member Posts: 16
    Hi can I please have mf and residual for Denali 4x4 36/12 , 36/15 for 28311
    4X2 or 4X4?
