2020 Subaru WRX & STI Lease Deals and Prices
abiezerfabiezerf Member Posts: 10
edited October 2019 in Subaru
What is the current MF/Residual for STI Limited and STI Base in Miami for 36/12K?
«13456711
  • MichaellMichaell Moderator Posts: 270,813
    STi Base - .00205 and 64%
    STi Ltd - .00135 and 61%
  • westonmattawestonmatta Member Posts: 9
    MF and residual for a wrx premium 36/12 in 19522 with incentives? Thanks!
    CVT or stick shift?
    Stick
    Stick
    .00145 and 59%
    No incentives
  • TristanTristan Member Posts: 2
    Looking for MF, RV, and any lease credit/incentives for 2020 Subaru WRX Base model with a Manual Transmission. Zip code 11417. 36 months/ 10k per year. Thank you.
  • kyfdxkyfdx Moderator Posts: 275,678
    .00170 MF and 61% residual
  • HunterwreckHunterwreck Member Posts: 7
    Stick
    .00145 and 59%
    No incentives
    Hi may you please provide the MF number for the 36/15K
    Thank you for your help.
    Stick
    .00145 and 59%
    No incentives
    For the WRX premium?
    Stick or Automatic?
  • wrstdudewrstdude Member Posts: 29
    Hi! Can I get the MF/Residual/Incentives for a 2020 WRX Premium Automatic 36/10k in St. Louis (or if you need a specific zip, 63376)?
    .00105 and 58%
    no incentives
    .00105 and 58%
    no incentives
    Thank you, again!
  • svrdssvrds Member Posts: 1
    Can I get MF/Residual/Incentives for a 2020 WRX Premium Manual? 36/12k Zip Code 92649
    .00110 and 57%
  • ianckanianckan Member Posts: 52
    Could I get the numbers for a 2020 WRX Limited- Manual? Zip code:94040
    36/10k
    36/12k
    Incentives if any.
    36/10k
    36/12k
    Incentives if any.
    .00125 MF and 58% residual
    No incentives
  • Roe_roe2019Roe_roe2019 Member Posts: 21
    Could I please get numbers for 2020 wrx sti limited manual 36/12k or 39/12k in Orlando, fl 32819. Thanks!
    Wing or lip?
    Lip. Also, numbers for base sti? Thanks.
    Base
    .00170 MF and 62% residual
    .00195 MF and 60% residual
    LTD w/Lip
    .00120 MF and 60% residual
    .00145 MF and 58% residual
  • CentenoCenteno Member Posts: 1
    edited November 2019
    What is the current MF/Residual for WRX Limited Manual 36/12K and 36/10K.
    Zip Code 95757 - Elk Grove, CA
  • JoshposhJoshposh Member Posts: 54
    Can I please get numbers for zip 95608. Wrx base manual please. For 10/24 and 10/36. And any incentives?
    .00260 and 69%
    .00170 and 61%
    No incentives
  • ken_k_wken_k_w Member Posts: 27
    What are the MF and residual for wrx manual premium 10k/36months? Zipcode 07041
    .00110 MF and 58% residual
  • ocho817ocho817 Member Posts: 9
    Numbers please for premium automatic 10k/36 and 7.5k/36, 14534. Thanks!
    .00105 MF and 58% residual
  • Dpatt711Dpatt711 Member Posts: 2
    Looking for numbers on STI Base and LTD 10/36, 03220
    Base: .00170 MF and 63% residual
    LTD: .00120 MF and 61% residual
  • desiidesii Member Posts: 17
    Looking for numbers on the following all for 92804
    2020 WRX prem 36/12k manual
    2020 STI base 36/12k
    Also, what is tier 1 and tier 2 MF?
    (going down to 10k is that +2% residual?)
    .00110 MF and 57% residual
    +1% for 10K/yr
    Add .00025 for Tier 2
  • jarjohjarjoh Member Posts: 72
    Can I please have lease numbers on a 2019 WRX - premium and limited. 6spd manual. 24 and 36 months, 10k and 12k miles. Residual, MF, incentives Zip 33545
    *2020, not 2019
    jarjoh said:
    *2020, not 2019
    Sorry - limited and premium
    jarjoh said:
    *2020, not 2019
    24/12
    .00260 and 65% / 64% for LTD / PREM
    LTD - .00125 and 58%
    PREM - .00110 and 57%
    No incentives
    jarjoh said:
    *2020, not 2019
    24/12
    No incentives
    What about the two STI trims?
    jarjoh said:
    jarjoh said:
    *2020, not 2019
    24/12
    No incentives
    Lip or Wing for STi Limited?
    jarjoh said:
    jarjoh said:
    *2020, not 2019
    24/12
    No incentives
    Wing. But I’d be interested to see what lip is as well.
    jarjoh said:
    jarjoh said:
    jarjoh said:
    *2020, not 2019
    24/12
    No incentives
    Base: .00170 MF and 62% residual
    LTD: .00120 MF and 60% residual
    Either lip or wing
  • kduff85kduff85 Member Posts: 41
    Can I get 2020 WRX LTD Manual 36/10 and 39/10 for 76182?
    .00125 and 59%
    .00170 and 58%
    No incentives
    Can I get lease number for wrx base 12k miles 36 mo for 92804?
    .00170 and 60%
    thank you everyone for the quick responses.
    Are the january numbers out already?
    if so, can i get numbers for a premium 12k 36 mo for 92804? also for a base same specs.
    Tier 2 credit if possible
    thank you!
    thank you!
    New programs start tomorrow. Might take a couple of days, before we see them
  • RodRom85RodRom85 Member Posts: 4
    Any In
    Any Incentives for JAN 2020?
    RodRom85 said:
    Any In
    New numbers
    .00155 MF and 61% residual
    .00100 MF and 59% residual
    No incentives
    thank you!
    Are these numbers in yet?
    thank you!
    Numbers are in - stick or CVT?
