2020 Land Rover Range Rover (Full Size) Lease Deals and Prices
2456789
  • k993massk993mass Member Posts: 11
    Hi, could you provide the MF and residual on a 2020 P400 HSE for 33/36/39 10K miles and 12k miles? Thanks!
  • kyfdxkyfdx Moderator Posts: 272,437
    33/12: .00111 MF and 61% residual
    36/12: .00113 MF and 58% residual
    39/12: .00115 MF and 56% residual
  • chrisandrew1229chrisandrew1229 Member Posts: 3
    Hi, could you please provide the MF and residual on a 2020 full-size RR Autobiography for 33/36/39 12k miles? Thanks in advance!
  • MichaellMichaell Moderator Posts: 268,562
    I don't see the Autobiography trim for 2020
  • Derf26Derf26 Member Posts: 1
    Range Rover Sport Hse V8 $99622 in 08002
    36months/15k miles
    39months/15k miles
    Mf and residual? Thanks!
    36months/15k miles
    39months/15k miles
    .00139 and 53%
    .00140 and 51%
  • AirBull76AirBull76 Member Posts: 2
    Interested in 2020 Range Rover HSE Td6 in Houston area $105k MSRP.
    36/10 MF and residual
    Central Texas
    .00124 MF and 60% residual
  • Carnold2002Carnold2002 Member Posts: 1
    edited November 2019
    Hey Guys, can I get the MF and residual for a 2020 RR P525 HSE? The MSRP is $124,178.
    36 months/12k miles. Thanks!
    .00139 and 55%
  • Ishaan16Ishaan16 Member Posts: 123
    Hello, may I please have the MF, RV, and incentives for a P400 HSE? 36/15k. ZIP 92886.
    Is that the regular HSE or the PHEV HSE?
    The regular HSE
    The regular HSE
    .00113 and 56%
    No incentives
    The regular HSE
    .00113 and 56%
    No incentives
    What are the numbers for the PHEV as well? Any better?
    Ishaan16 said:
    The regular HSE
    .00113 and 56%
    No incentives
    Not better.
  • DLSkyguyDLSkyguy Member Posts: 31
    edited December 2019
    Hello-
    Can I get the MF & RV for zip 43230 for a 2020 RR HSE Sport dynamic P360
    . 36/12 MSRP: $86,400
    New to RR and interested in one I came across. Also, does not all RR have 4WD? Thanks
    DLSkyguy said:
    Hello-
    This is the RR Sport?
    Please repost here:
    https://forums.edmunds.com/discussion/56846/land-rover/range-rover-sport/2020-land-rover-range-rover-sport-lease-deals-and-prices#latest
    Correct, Will do, Thanks
  • CarGuy3161CarGuy3161 Member Posts: 1
    Hello
    Can I please have the MF/RV for zip 90808 for 2020 RR HSE TD6
    MSRP: $104,592
    33/12k
    36/12k
    Hello
    MSRP: $104,592
    33/12k
    36/12k
    .00122 MF and 62% residual
    .00124 MF and 59% residual
  • boylaboyla Member Posts: 16
    Can I please have mf/rv for 2020 RR p525 HSE for 33/10k and 36/10k? Zip is 90015. Thank you
  • SFRoverSFRover Member Posts: 11
    Hi there - could you please provide the MF and residuals for a 2020 RR P525 Autobiography with 7.5k and 10k miles, 33 and 36 months? Zip code 94114. Thanks!
    .00138 MF and 60% residual
    .00139 MF and 56% residual
    SC or SV?
    SWB or LWB?
    Sorry - SC and SWB. Thanks!
    SC or SV?
    SWB or LWB?
    Hi there - just checking in. Could you provide those? Thanks!
    SC or SV?
    SWB or LWB?
    SC or SV?
    SWB or LWB?
    .00146 MF
    57%/54% residual for 33/36 mo, 10K/yr
    Add 1% for 7.5K/yr
  • peternjpeternj Member Posts: 4
    Hi - Can you please provide MF and residual for a 2020 RR P400 HSE for 15,000 miles per year, and terms 33, 36, 39, and 42 months? Thanks
    Is that the PHEV or not?
    No it's not the PHEV
    .00111 and 59%
    .00113 and 56%
    .00115 and 54%
    .00150 and 52%
    .00111 and 59%
    .00113 and 56%
    .00115 and 54%
    .00150 and 52%
    Hi, could you please provide the MF and residual on a 2020 P400 (PHEV) HSE for 33/36/39 10K miles and 12k? Thanks!
    .00171 MF
    61%/58%/55% residual, 12K/yr
    May I please have the MF, RV, and Incentives for a V6 HSE in ZIP 95129? 33/15k, 36/15k, and 39/15k please. Thank you.
    .00111 and 59%
    .00113 and 56%
    .00115 and 54%
    No incentives
    .00111 and 59%
    .00113 and 56%
    .00115 and 54%
    No incentives
    May I please have the same information based on ZIP 92886?
    Ishaan16 said:
    .00111 and 59%
    .00113 and 56%
    .00115 and 54%
    No incentives
    Ishaan16 said:
    .00111 and 59%
    .00113 and 56%
    .00115 and 54%
    No incentives
    LR numbers are national.
  • DallavecchiaDallavecchia Member Posts: 3
    Can you pls provide MF/Residual 2020 V6 HSE p400 (no-hybrid) 33/10k and 36/10k zip 15146
    .00111 and 62%
    .00113 and 59%
  • ROBRTM5ROBRTM5 Member Posts: 81
    Can you pls provide MF/Residual for 2020 V6 HSE SWB (no-hybrid) 36/10k zip 33324
    .00113 MF and 59% residual
  • KennedyStoneKennedyStone Member Posts: 17
    Can I get the MF and residual for a 2019 RR full size SE. 7500 and 10000, 33 Months, 94109. Thanks!
    Please post in the 2019 model discussion, here:
    https://forums.edmunds.com/discussion/51942/land-rover/range-rover/2019-land-rover-range-rover-full-size-lease-deals-and-prices#latest
    Thank you! Can I get the MF and residual for a 2020 RR full size SE. 7500 and 10000, 33 Months, 94109. Thanks!
    Don't show an SE trim
    Base trim? If so, then gas or diesel?
    Base and gas. Thank you!
    33/10
    .00113 and 58%
  • volklgearvolklgear Member Posts: 15
    Hello - please post updated MF/Residuals and any incentives for P525 HSE SWB for 33/10, 36/10. 39/10 leases. Thanks!
