2020 Ram 1500 Lease Deals and Prices
1356750
  • HomeStarRunHomeStarRun Member Posts: 6
    edited November 2019
    Hi!
    Can you please give me the residual, MF & rebates for 36 months (or 39 if it is a better program) 12K on a Laramie short box 4x4 crew cab V8 in 02865.
    Hi!
    .00038 MF and 56% residual
    $2000 incentive
  • jwr85jwr85 Member Posts: 18
    2019 Ram 1500 Laramie Quad Cab V8 4x4 36 month 10K Zip 53226, can i get MF, RV, and Nov incentives?
  • MichaellMichaell Moderator Posts: 268,688
    39/10
    .00078 and 55%
    $1500 incentives
    39/10
    .00078 and 55%
    $1500 incentives
    Any difference in the numbers for 2019 Rebel 1500?
    jwr85 said:
    39/10
    .00078 and 55%
    $1500 incentives
    The numbers given above are for a 2020 model (because, title of discussion)
    For 2019 model numbers, please post here:
    https://forums.edmunds.com/discussion/50544/ram/1500/2019-ram-1500-lease-deals-and-prices#latest
  • ukrmanukrman Member Posts: 5
    Hi, could you please provide MF/Residual and any promos for
    - 2019 Ram Laramie Crew Cab, 4x4, V8, MSRP around $60K - zip 08062?
    - 2020 Ram Laramie Crew Cab, 4x4, V8, MSRP around $60K - zip 08062?
    36/10 and 36/12
    The 2019 Rebel residual is kinda terrible curious is Laramie is the same. Thanks!
    36/10 and 36/12
    2020 Laramie
    $2000 incentive
    Please request 2019 model info, here:
  • bobbos21bobbos21 Member Posts: 5
    Can I have the numbers for a big Horn 4x4 36/10k zip 61704
    Crew or Quad?
    Crew
    Crew or Quad?
    bobbos21 said:
    Crew
    Crew or Quad?
    .00011 and 56%
    $2000 incentives
  • srchn96srchn96 Member Posts: 82
    Can I get MF, RV and incentives for Laramie and Limited 4x4 Crew Cab 5'7"
    77068
    77068
    Laramie: .00038 MF and 54% residual
    Limited: .00123 MF and 51% residual
    $1500 incentive
  • rone803rone803 Member Posts: 21
    Do you need the zip of the purchase location or the zip the car with be registered? Making a out of state purchase. Thank you.
    Dealer location
  • tpfieldtpfield Member Posts: 3
    Hi, I'm looking at a 2020 Ram Rebel Crew Cab 4x4 with eTorque Hemi and Rebel 12 package. Can you let me know the MF/RV and any incentives in the 91944 area?
    debating between 36/10 or 36/12
    .00125 and 55%
    $1000 incentives
    .00125 and 55%
    $1000 incentives
    Do either the MF or Residual change if I use the zip 92121?
    tpfield said:
    .00125 and 55%
    $1000 incentives
    No
  • rfish954rfish954 Member Posts: 9
    Can I please get numbers and incentives on 2020 Ram 1500 big horn 4x4 crew, 5.7 hemi in 48093.
    $3000 incentive
  • BobKidBobKid Member Posts: 2
    Looking at a loaded 2020 Ram Rebel Crew Cab 4x4 with 5.7L, air suspension, and Rebel 12 package. Can you let me know the MF/RV for 76049? Thanks,
    Sorry, forgot the 12K/36 month
    .00125 MF and 55% residual
    $1500 incentive
  • abunysabunys Member Posts: 1
    Looking at 2020 Ram 1500 Bighorn and the Laramie, both 4x4 V8. Could I please get the MF/Residual and Incentives for 36mo/12k and 36mo/15k please?
    Zip code is 47725
    Thanks in advance!
  • Gnebb23Gnebb23 Member Posts: 4
    Looking for MF and Residual 2020 Rebel Crew 4x4. 39/15. Zip 29902. Thanks!
    .00125 and 53%
    $1000 incentives
    Zip code is 47725
    Thanks in advance!
    BH - .00011 and 53%
    LAR - .00038 and 54%
    $2000 incentives
  • Gatorfan123Gatorfan123 Member Posts: 40
    Looking at 2020 Ram 1500 Limited 4x4 V8 - crew cab.
    Zip code is 34471
    looking for MF/Residual and any incentives
    lease term: 36 months and either 12k or 15k miles per year
    Zip code is 34471
    $1000 incentive
  • Birdman1nonlyBirdman1nonly Member Posts: 1
    Could I get some info for a 2020 Ram 1500 Big Horn 4x4 V6 etorque crew cab with 36mo/12k zip 48309 please?
    .00011 and 55%
    $3500 incentives
    77068
    $1500 incentive
    so is this Laramie Longhorn? the model just below the Limited. It seems financially it is much better to buy the Laramie loaded with all the options than the Limited, because the payments will be close to $150 a month cheaper, based on the lower MF and residual.
    77068
    $1500 incentive
    It is the Laramie.
    The Longhorn is a Limited variant, not a Laramie variant. (higher trim than the Limited)
    At least it was, last year.
    But, yes... the Laramie has a lot better program than the Limited (but the Longhorn is worse).
  • dowelbm01dowelbm01 Member Posts: 4
    Incentives, MF and Res% for:
    2020 LARAMIE 1500 Crew 4x4
    Zip 76108
    36/12 and 24/12
    Zip 76108
    36/12 and 24/12
    .00056 MF and 62% residual
    .00060 MF and 56% residual
    $1000 incentive
  • Noclass000Noclass000 Member Posts: 3
    May I please get numbers for 2020 bighorn or Laramie crew 4x4 5’7” bed 82901 36/12
  • Buddyboy52Buddyboy52 Member Posts: 9
    Could I please have MF and RV for a 2020 Ram 1500 Laramie 4x2 short box in zip 92677?
    36/10K please. If that term is not available then 36/12K.
    BH - .00035 and 55%; $1000 incentives
    LAR - .00060 and 56%; $2000 incentives
    .00048 and 54%
    $500 incentive
  • Speedser123Speedser123 Member Posts: 12
    hello, may i please have the rv, mf and incentives for the 2020 ram 1500 big horn v6, for zip code 48237.
    24/12k
    specific model if needed: https://www.edmunds.com/ram/1500/2020/vin/1C6RRFBG6LN220588/?paymenttype=lease
    24/12k
    Quad Cab 4WD?
    27/12
    .00018 MF and 57% residual
    $3500 incentive
  • Needhelp12DanNeedhelp12Dan Member Posts: 1
    Can I get the MF, Residual and incentives on a
    2020 Ram 1500 BigHorn back package Crew Cab v6 -4x2 36 month 12K Zip 33028?
    Thank you !
    Thank you !
    .00047 MF and 54% residual
    $500 incentive
  • BradleyRBradleyR Member Posts: 30
    May I please get MF, RV and incentives for Laramie and Limited 4x4 Crew Cab 5'7"
    13039
    36/10k-year
  • nathan471nathan471 Member Posts: 4
    Can I please get the current RV and MF on 2020 ram bighorn v8 in 45040? 36/10
    4x2 or 4x4?
    Crew or Quad cab?
