Visitor Agreement.
Think of the stupidest thing the guy around you could possibly do, then get ready, because he will probably do it.
That has saved me many times!
For fuses, the trick can be figuring out which one. And real important, what caused it to blow. And if there aren’t correct spares in the box, you end up at the dealer anyway.
My pet peeve is the typical brain-dead moron who takes curves and ramps at 50% of the advisory speed with the brakes applied the entire time.
Another population group that needs to be confined to public transit.
Lesson learned.
One of our tennis guys said his 20 something year old Corvette had a burning smell coming from the steering wheel. Car has 180000 miles on it....figures it is a wire shorting.
What next?
A “Caution-Sharp edges!” label affixed to every knife?
1. Pick up soldering iron
2. If discomfort is noted, set it down and pick up the other end
If I had a new 100K+ Maserati (I assume moneybags had a Quattroporte and not a plebian Ghibli), I too wouldn't dink around with anything.
Both good cars. Both quite different from each other. Probably a long post, but here goes...
PERFOMANCE....hands down, the Stinger. The turbos spool up quickly and the rush of speed happens "right now" with a shove back into the seat. I think Kia is understating the engine's power. Add to that, the Kia 8-speed, while using a torque converter (vs the dual clutch automatics out there) snaps off quick shifts and is willing to drop down gears smoothly with little provocation. I know some of the engine sounds are piped in. But, it sounds good, too.
TLX is typical Honda/Acura....smooth, rev happy V6. You have to prod it into the upper revs to get it to really go (at 4K RPM, the rush is almost turbo like). But, that's because there's not the low end torque you get with the Stinger TT. The trans, while smooth shifting, really doesn't respond with any urgency when you prod it. It hesitates before making a move down a gear or two, even after you floor it. I keep it in Sport or Sport+ mostly. But, Sport mode isn't aggressive enough, and Sport+ seems to hunt. I understand what Acura was trying to do. They're trying to replicate what a manual feels like. Generally speaking, the execution is lacking, though. I understand the DSG Honda mates to the 4 cyl is better. Not sure why they didn't just match it with the V6, unless there were mating issues with the SH AWD.
SUSPENSION....again, Stinger hands down. It has an adaptable suspension that, given it's handling capabilities, I'm amazed at how it handles bad pavement. Over the smooth stuff, it feels like a luxury car ride. Over bad pavement, you feel something, but the car tracks true and you are in control at all times. There is little body lean felt. And the chassis is as solid as granite. I can take corners at speeds that the TLX would balk at.
The TLX, by comparison, feels...I don't know...floppy? You can upset the steering and rear end if you hit broken pavement. Over smooth pavement, it's as luxurious a ride as anything out there, though. That said, the SH AWD WILL blast you through a corner, almost magically. That said, you have to stay on the gas to get it to that point. Problem there, if you're on the gas through the corner, you have to set up for another corner and it takes a bit for the weight transfer to settle down.
STEERING....Stinger wins again. It's not over/under boosted. Maybe a shade on the light side in town. But, on the road, I know exactly what the front wheels are doing. Start to hustle and the Stinger's steering really shines with quick transitions and good feel.
The TLX's is on the heavy side....a shade artificial. Still, easy to control. Again, you can feel rough shudders through the steering wheel, though. Not a lot...just enough to feel a bit "antsy".
COMFORT....this is where it gets a little tricky. Depending on your size (I'm fairly average), the Stinger sits lower than the TLX. That might be an issue for some. Not for me, but I can see someone my age, or a larger person not wanting to sit low. For me? I have no qualms. The seats in the Stinger are comfortable, but it's because they have nice bolstering. The heated seats are some of the best I've parked my posterior, IN ANY car I've ever ridden in. They are bolstered to my liking, too. They adjust forward, aft, has a power thigh support and power lumbar support, as well as power adjustable bolsters. The leather they are wrapped in are top notch. They call it Nappa Leather, but I don't know the differences between leathers. They are soft to the touch.
The TLX's seats are uber comfy.....Milano Leather (again, don't know the difference between them and the Stinger's Nappa Leather). Plus, as y'all know, I love me some red interiors. They aren't quite as bolstered as the Stinger's, and don't have as many adjustments. But, none of that really matters as they are very comfortable in their own right.
Steering wheels in both are great, leather covered. I like the Stinger's a tad more because it has a flat bottom and is just slightly easier to control.
STEREO.....TLX wins....bigly. The ELS Stereo is the best of any car I've ever been in, regardless of price. I hear the new ELS (as in the RDX) is even better, which is incredible. While the TLX doesn't carry a "big brand" name like B&O, my understanding is it uses Pioneer's D3 Digital amps and their well regarded speakers. The front end comes from Panasonic, which makes some of the best in the biz.
The Stinger's stereo isn't a slouch and probably better than 90% of OEM stereos out there. It's a Harmon Kardon unit (who also makes JBL, Mark Levinson, and many others). Typical H/K, it's bass heavy. But, it plays loud and clear. It's good, just not great like the TLX's.
EQUIPMENT....truthfully, I don't know how much more you can ask for as far as options and features. They're both loaded up. But, it comes down to execution of those features that sets the Stinger above the TLX. There is no "ping-pong" effect for Lane keep on the Stinger. It's radar/lidar cruise is smooth (TLX can be abrupt in both braking and acceleration). I like the two screens on the TLX for infotainment. Control the stereo with one, and the Nav with the other. On the Stinger, the resolution is better, but you have one screen that you can split in two or three different windows. Stinger has 3D view of the entire car, both forward, back and from above. TLX only has a rear camera.
Stinger has better heated and better cooled seats than the TLX. TLX will turn the heated and/or cooled seats on automatically depending on outside temp. The Stinger you have to do that manually.
ANCILIARIES....Stinger's rear window view is small. TLX's A-pillar is thick and tough to see around without craning your neck. Stop/Start on the TLX is abrupt off and on. Don't try to make a 3 point turn with it, either as you'll find yourself with the engine off as you're trying to make a turn going forward. It needs some work. Stinger's stop/start is significantly better and much less perceptible.
MPG....TLX wins, by a significant margin. In town, I get 22-23 MPG. It really shines on the interstate....getting as high as 38 MPG for me. The Stinger is holding to about 20 MPG in town, but 24-25 MPG on the highway. I keep my foot planted in both of them for the most part, though.
MATERIALS AND BUILD....exemplary in both. Leather where it's supposed to be. Soft touch everywhere. The aluminum trim in the Stinger is particularly fetching. Build on both cars is as good as anything I've seen. Both are tight as drums and feel quite solid.
Concluding....for low $40K (what I paid for the TLX A-Spec V6 SH-AWD) or $37K plus change that I paid for the Stinger GT2 AWD, I don't know that you can find a better car.
I knew this going in, but I won't get the service on the Stinger as I do on the TLX. TLX dealership has bent over backwards whenever I called on them. They even give me a car wash and loaner with every oil change.
Kia...I called my sales lady with operational questions. She said she's new and handed me off to service, who has never returned any of the 3 or 4 calls I've made to them. This is part of a large dealer group, too. The principal owns Cadillac and Mercedes dealers, too. Good service should not be foreign to this group. Kia's got some work to do on that front. But, the Stinger's assembled as carefully as anything I've seen, it's materials match up to cars that cost 2x the price.
Slap a Gran Coupe badge, AMG C43 badge or an S5 badge on it where the Kia logo is, up the price $10K, and people would be lauding the Stinger as a wonderful Sport-Luxury car as well as a great value. As it stands, it competes with all of those other German brands.
Them's my thoughts.
Taking the rest of today and tomorrow off, then taking the first week of vacation for 2020 next week.
My neighbor took me to lunch and then to pick up his new Mercedes. Saw some nice cars.
He paid mid $40s for his CLA. I wouldn't trade him even up for either my TLX nor my Stinger. Of course, I didn't tell him that....just that he had a beautiful car. I know we have many Mercedes fans here. But, you will never convince me that Mercedes Tex seats are as good as leather. Nope...not close...not that I've ever seen.
Some of the cars I saw, and liked....
It’s refreshing to find an AWD car that isn’t primarily designed to placate the imbeciles who think AWD or FWD is a mandatory requirement for driving on wet pavement.
False economizing is one of my pet peeves. Someone tries to save a few buck$ but spends more to fix it in the long run. My SIL buys an Amish heater because it is on sale for half price until midnight, only $100 reduced from $200. Check the scam on the net, you can buy a Sunbeam that is every bit as good for $30. False economizing.
I'd like to know how your brain works...how did you get that video from my mentioning Amish heaters.
Negligence generally consists of five elements, including the following: (1) a duty of care owed by the defendant to the plaintiff; (2) a breach of that duty; (3) an actual causal connection between the defendant's conduct and the resulting harm; (4) proximate cause, which relates to whether the harm was foreseeable; ...
A young driver should take greater care to compensate for the fact they don't have the experience yet to be fully skilled or fully capable of driving perfectly safely.
When you were young, "not seeing non-moving objects" wasn't lack of skill per say, it was lack of awareness. Your eyes didn't improve with age. More likely, you just misestimated the boundaries of your own vehicle. This is what happens to old people as well. They aren't blind!!! You may have diminished eye sight, but you are not blind! IF they are blind, they are grossly negligent for turning the keys in the first place (or pushing the Start button these days).
Most collisions and fatalities do result from negligence because it is known that the main causes of collisions and fatalities are completely preventable and avoidable. This is equivalent to say, the harm that was caused was forseeable, predictable, and inevitable if you drive while doing the following:
1) Distraction/Cell Phones
2) Drunken/Intoxicated
3) Drowsy/Fatigued
4) Failure to Signal
5) Unsafe lane changes or merging
6) Unsafe Turns
7) Failure to take extra duty and care when backing up
8) Failure to properly maintain their car/equipment, and/or inspect it for proper maintenance.
9) Failure to Yield Right of Way
I think you'll find it hard to find anyone that has experience with something that doesn't fall in the above 9 item list.
An honest accident is the following:
1) Lighting strikes you through your open window (though one could argue why is your window open during a thunderstorm...).
2) The hand of god causes something crazy to happen before you (sinkhole, tree falling, falling rock from the mountain top).
3) Incapacitating health emergency that had little to no warning.
We are all human and we all make mistakes. It's okay to own some negligence and take responsibility if one inflicts harm on another. This is a much better option than say, blaming a bee sting.
Are they less dangerous for recognizing they suck at driving? Perhaps, if they say, avoid the freeways. If they merge onto a freeway at 38 MPH as @fintail pointed out Seattle drivers tend to do, I'd say their awareness makes no difference to how dangerous a driver they are to everyone else.
I respect drivers that either admit they are too incompetent or too fearful to get on the freeway. There are many more that need to join them, and clear the Interstate from their impediments.
It's OK to have scratched the edge of your fender once in a blue moon (not OK if you are doing it regularly or occassionally). It is not OK if you are running over pedestrians and or hitting bicyclists. It is okay to scuff a wheel on a curb once or twice per car ownership period, it is not OK to have totalled every car you've ever owned.
See the difference?
I realize the word "gross" might throw some people off. It is subjective, and subject to interpretation. I have higher standards for drivers than say, the DMV of CA.
Even on the old car, if it seems even a little out of my comfort zone, I will probably just put it on the list for the indy mechanic to look at during the yearly service/inspection. I lack a proper garage setup with tools/ramps etc, and if I dig into it and break something or can't get it back together, that false economy will laugh loudly at me. That's my fear with its recent turn signal issue - I have a suspicion where the fault lives, but there's a big risk breaking things if I dig in. I'll spend an hour or two of labor and have it done right.
Being directly partially responsible for a disastrous fatality rates year in and year out does fit squarely on law enforcement and driving instructor failings for the United States.
I'd be careful citing "driving instructors," especially those that have practiced in the USA, and/or have already retired from doing it (responsible for the past performance).
It is the equivalent of taking advice from the Chicago Cubs on how to win World Series' consistently year after year.
The Camry that hit me most recently in a parking lot, in my view.
NOT A COINCIDENCE it was a Camry/Toyota.
NOT A Coincidence 3 of their 4 corners had noticeable damage after hitting me (only damaging one of those 4 corners in the process).
Confirmation bias? Maybe, but I'd bet against that. I'd bet big!
I recall when my son was in the apartment at OSU and I'd drive over to take something during the day or pick something up. I'd just drive leisurely in the right lane with the trucks at just under 60. I'd look up and there's a Civic or Pious tailgating me. I assumed it was to increase their gas mileage. So I'd start slowing down a click every 1/2 mile or so until they'd pass. If they didn't I'd click back up and note if they stayed right behind still. Irritating. Let them provide their own power instead of drafting.
The merging here is terrible. I don't drive in the right lane at some of the areas where bad merging occurs on our interstate.
Favorite is the guy who merges at 10 under the speed limit. Then you've passed and pulled back into the right lane. Look up and there they are tailgating 'cause they wanna go faster than you're going. They speed up after about 1/2 mile or more.
I assume your friend didn't pay MSRP. All but the most hyped MBs seem to be able to be had for at least 8-10% off sticker, sometimes much more at the right time and model.
AMG is a little overdone now, like ///M and S - nameplate dilution. The performance cred is as hot as ever, but I guess I liked that the cars were rare in the past. I like numerous old ones, but new ones don't get me going as much, maybe as these (and most everything else) lack a hood star these days. I still have a thing for the G-Wagen, but it is getting more difficult to find non-AMG ones with time. If I ever had that kind of spending ability, I'd likely have to special order the car. When it seems all Gs are AMG, it's almost a shark jumping moment.
I've had 4x MB with Tex, 4x with leather. I am indifferent. Leather is nice, but is extra cost on most models you'll find on the lot, and seldom ordered on these models - I suspect doing everything possible to keep leasing attractive. I think a lot of people can't differentiate it from leather, especially people used to the cheaper leather in mass market cars, but compare it to a finer leather, and there's no mistaking what is what. The ease of maintenance is an attraction - wipe it down now and then, and it'll look fine when the car is at the end of its service life.
I'm at around 11 months in this thing now, still feels special when I drive it, you pay for it, but get an amazingly refined machine, and as close to a traditional car as might exist on the market today:
I still recall in driver's ed being instructed to merge at a speed "comparable to other cars on the road". I don't know why this is hard to remember, although in my area with license testing being privatized, who knows what goes on.
I wrote a much longer post about how you should only "like" posts that say something meaningful or worthwhile. But, probably better to let it go.
Sure enough, at the last minute he pulls into my lane without signaling. I must have been psychic because I had braked just in case. Otherwise we would have become acquainted most unpleasantly.
Another peeve is people driving in rain, snow or fog with no lights on. It’s the law when using your wipers, it’s common sense when driving a dark car on a dark road in poor visibility. But one out of three seems to feel that as long as they can see the front of their hood, the world be damned. :@
Great comparo write up! Better than a lot of what’s out there written by professional editors. You didn’t mention braking. A very important part of how a car performs. As big of a Honda fan as I am (I’ve voted with my wallet 4 times), one of the areas that I feel they don’t address properly from the factory is braking. How does your TLX compare to the Stinger as far as braking feel & stopping ability for?
Cheap and dumb dishonest GM if you ask me.
Kia Consumer Affairs got a complaint for the dealership, but they don't have any power, I don't think that'll change the GM's position since he already took the wrong position and decision. Customer is always wrong. We never do anything wrong. They say that their lady hasn't lost a key FOB in 7 years. If anything, that means she was due! Especially considering their paperless system.
Shame, cause I did have some interest in the Stinger.... though not at their asking prices.
