1204720482050205220533236
  • stickguystickguy Member Posts: 54,445
    that is hideous.
  • explorerx4explorerx4 Member Posts: 21,180
    Don;t get worked up about that BMW grille, you can cover a bunch of it with a front plate. :p
  • kyfdxkyfdx Moderator Posts: 273,203
    Kind of tempted by this. It is obviously not the fastest SUV, but it is cheap (overpriced as is, believe it or not). There is another ML AMG I found and actually sent to the wife. But then I think to myself "would I even want to drive the Charger when my SUV goes 0-60 in 4.5?" So maybe I should get a slower, cheaper R500. LOL.
    Isn’t that a shared platform with the OG Pacifica?
    Yup.. My son called them the Ugly-Class. B)
    Eh. Still looks like a bmw to me. Not the concept car, but what lurks in the shadow Of the first pic. I haven’t considered their cars terribly attractive for a long time now anyway.
  • oldfarmer50oldfarmer50 Member Posts: 24,698
    My Moms 2015.5 V60 CC is sitting at the Volvo dealer. Was smoking and lost 2.5 quarts of oil in less than 1000 miles.
    Car has a blown piston seal/ring. At 42k miles. Some quick googling shows this is a known issue on these cars. It is covered by warranty but would otherwise be north of $5000.
    Can anyone more mechanically inclined tell me what the odds are of damage to the cylinder walls as a result?
    Not mechanically inclined but cylinder wall scoring would be my main concern.
    edited May 2020
    tifighter said:
    The main question for today's random craigslist posting is, what do you wear when you drive it?
    A mullet?
    Speaking of TTAC's news coverage, are they really going with that grille for the new 4-series? Doesn't look like a BMW at all.
    Yuck!
  • 28firefighter28firefighter Member Posts: 9,959
    Volvo dealer is going to borescope the cylinders and document the results for warranty purposes. We shall see.
    Why scope? They already know it is a teardown or replacement for the ring alone.
    No clue. Absolutely no clue. Now that you call that out, it makes no sense.
    Haircut, today! No more mullet.
    Wonder if they evaluate to see if they can just do a ring job, or need to replace the engine so won’t bother with full tear down?
    I have a punch-related non-punch.
    US Bank offered to extend the lease on the Tacoma for six months at the same payment. Just couldn’t pass it up. $265/mo. for $37K MSRP vehicle.
    Also, by extending the lease, they waive the $395 disposition fee at lease end. In effect, 4.5 payments for 6 more months.
  • MichaellMichaell Moderator Posts: 269,455
    I'll bet your son is happy about that.
    Screaming deal. That’s basically a zero DAS 6 month lease, no exit fees, for $199/month. I would take that!
  • corvettecorvette Member Posts: 11,801
    I’m guessing if there is additional damage, Volvo may send them a crate engine instead of having the dealer repair.
  • nyccarguynyccarguy Member Posts: 17,880
    Right. There has to be a point where it is cheaper for Volvo to send a fully built replacement engine. Although that might take a while. Mom has a loaner? This car is leased or purchased?
    That is a complete no-brainer, @kyfdx.
    I hear the mullet is making a comeback. ;)
    Good deal on the Taco extension!!!!!!
  • tjc78tjc78 Member Posts: 17,606
    That was a two year lease originally on the Taco? If so, yeah no brainer.
    edited May 2020
    It is often the way these days. A rebuild is more expensive from their POV. But I don't understand the further assessment. A rebuild is a rebuild is a rebuild. It shouldn't matter what the cylinder looks like. Unless the crossing point is "if we have to send you a block, we'll just send you a new engine instead." So someone figured out a short block plus rebuild time exceeds a new long block. I guess then it makes sense.
    Getting more info from sales folks should not be so hard all the damned time. I reached out about this turbo because the VIN and carfax don't work. It took 10 mins on the webchat plus 5 emails back and forth to find out "This vehicle was imported from Europe and the VIN listed is correct, however we do not have a Carfax. This vehicle also can not be financed die to this and will need to be a cash purchase."
    No red flags there! And you only have to go to Indy to get it.
    Ad says 'Clean Carfax'. ok.
    The new TLX was revealed today. The interior takes a lot of cues from the RDX and the exterior reminds me of an ILX. As expected the 4 cylinder is the same one found in the Accord and the Type-S will get the turbo'd V6 with, I'm guessing, a little bit north of 400HP.
    https://www.caranddriver.com/news/a32687740/2021-acura-tlx-sports-sedan-photos-info/
    looks nice. more modern. really is just a sedan version of my RDX though. same engine and dash.
    too bad I did not want it longer, lower or wider!
    hope they do well with it. Definitely won't be selling one to me though.
    We'll see if C&D likes it better than the current one.
    They LOVE saying that, no matter what. There is one in FL that's been for sale for quite some time. Has an accident in the history, yet they say "clean carfax." I have reached out to them 3 times and gotten no response.
    If the cylinder wall is messed up they might just warranty a new engine and save the tear down cost. Just a guess.
    Their lots must be overflowing.
    edited May 2020
    They probably send the damaged engine back to the factory, rebuild it there and then ship it out to the next customer who has bad rings.
    most likely last thing they need is more used cars
    That answer doesn’t make sense. Why should being imported from Europe make a difference? Was it imported used? When? I’d need to know a lot more of the back story.
    Run away from it.
    seems shady to import something that was readily sold here. But maybe it was legit. Not special enough to ignore that many red flags.
    36/12 originally
    still a no brainer move. Unless you are afraid to own a Taco for 6 months with only the powertrain warranty!
    nope. plenty of other choices.
  • Sandman6472Sandman6472 Member Posts: 7,348
    Got a York 3.5 ton, 17 seer last July. Yesterday around noon, it cut out. Seems the pipe letting the condensation water go outside wasn't at the right angle, so the water flowed back into the unit. It stopped working. Repair place sent a guy out this morning and he said the units are made that way so as not to damage them, didn't quite understand it all. Within maybe 5 minutes, if that, unit was back on and blowing cold air. Guess it was a freak occurrence but we're nice and comfortable again. Also, got the power bill today and with using just a few more kwh, bill went from $106 last month the $75 this month. Kinda odd but we do keep the temp at 79 as the other half is too cold at anything under that.
    Master toilet was screwing up again, running and flushing with no one touching the handle, so repair guy came 10 days ago. Tuesday am, water in bowl is really low and it's running again. Other half called and another tech came this afternoon and said whatever the last guy did, came undone and all is fixed again. He mentioned that it's a good toilet even though I said it's almost 33 year old. Again he said it's a good unit and don't replace it until it dies. So all is good in the house again.
    Backed the Golf out before the a/c repair guy came and saw oil on the floor, more than normal. Looked and had the last oil change on 2/0/20 so called Tires Plus to see about coming over to see what's up. Going in at 8 am tomorrow to see what's up. Seems like my high school friend finally retired so might have to find a new mechanic. Was going to go over to the VW store but figured since T P touched it last, might as well let them see what's up. Just hoping it's nothing major as it's hardly been used since mid March and not even 300 miles driven since the oil change. Wonder if it's a valve cover gasket or something like that. When I cleaned up the garage floor, felt like oil though and had that same brownish color.
    Seriously, was so hoping that nothing else would go wrong for awhile with it. Nothing I really want right now, even though almost everyone has 0% financing and first payments due like 3 months out. Very tempting to be honest!! Not the happiest person right now to be honest! Even though I really thought I'd get a 2020 something, figured the Golf would behave itself awhile longer!! Might as well see what's out there now!!
  • andres3andres3 Member Posts: 14,217
    But it's only a $37K MSRP vehicle when it's new. At 12 month it's a year old used car. At 36 months, it's a 3 year old used car. At some point, paying the same monthly fee you paid when it was brand new won't make sense anymore. Only you can decide that. Imagine if they kept offering extension forever?
    It's a lease. if it is working like new, really doesn't make a difference.
    unlikely to be a valve cover gasket. More likely is either they did not get the drain plug in right or forgot the gasket. Sometimes they slop some when refilling and it eventually works it's way down. But should be easy to figure out by putting it on the lift, and certainly should take it back to the place that did the work.
    So I was wrong. My mom’s V60 is a 2016 T5 which is the 5 cylinder. I’ve not read anything about these engines having this kind of trouble.
  • benjaminhbenjaminh Member Posts: 6,856
    edited May 2020
    Acura's full video on the new TLX.
    https://www.youtube.com/watch?v=52HgsMW0BbM
    ? You sure? I thought they phased that out mid 2015 model year (hence all the listings for 2015.5 models).
    According to several VIN decoders, including carvana, it is a 2016 V60CC T5 Premiere with B5254T12 engine, which is a 2.5 5 cylinder Turbo. I thought the same as you.
    I know the first year or so only FWD got the 4 banger. The AWD kept the 5 cylinder, and I think different models switched over at different times.
    Huh. Interesting. And VERY surprised this happened with the 2.5, but I guess occasional things still happen.
  • tifightertifighter Member Posts: 3,870
    2015.5 thing mainly had to do with the Sensus and driver safety upgrades, as I recall. Mine was a 2015.5
