Dodge Dakota - General Topic
191012141517
  • iowabigguyiowabigguy Member Posts: 552
    Congrats in the new ride. I too replaced a Dakota with a Ram. I have 2 wheel drive Quad Cab, 5.7, 5 speed auto and 3.92 posi rear. With the cruise control set for 67mph on the interstate my truck gets 17.3 mpg consistently. I suspect your 4.7 may get 18 in the same conditions. The aerodynamics for the Ram are similar to those of a barn door so the mpg really falls off with speed. If I push the speed up to 75-80 then I drop about 2 or 3 mpg. Rick
  • dako1dako1 Member Posts: 18
    Hope you're right. If this truck runs well I may get a fiberglass toneau cover which may help somewhat too. If not I'm about 1 1/2 yrs away from retirement so the commute and mileage thing won't be as big of a concern. I didn't realize that the 5spd. auto came with a 3.92 rear end. I wish mine was a 5 spd but I don't think that was offered in 2002 unless maybe at the end of the year.
  • dustykdustyk Member Posts: 2,926
    You most certainly don't owe anyone an apology for buying something other than a Dakota.
    The RAMs are nice trucks and I'm sure you will be very, very pleased with it. Everyone I've talked to with the newer RAMs have been exceptionally pleased with them.
    Best of luck,
    Dusty
  • bubblegum44bubblegum44 Member Posts: 2
    bookity
    The convertibles were made in 1989, 1990, and 1991
    They were made in 4 and 2 wheel drive. there were 2800 made in 1989 and 1028 in 1990 and 9 in 1991. I have a 1990, it is a fun truck, I like you wanted one when they first came out, but with kids couldn't justify at the time. Mine came up for sale last year and I bought it. I got it from the original owner. The biggest problem is finding parts for them, some of the parts are getting worn and are impossible to find.
    Oh well so much for history.
  • bookittybookitty Member Posts: 1,303
    Robert, than you for the response and information. I did find other information on the internet concerning these trucks, where they were raised, tricked out, etc. Perhaps a "keyword search" could help in obtaining spare parts.
    Bookitty
    For what its worth (and that really applies in this case), the latest edition of Consumer Reports Buying Guide now rates the Dakota "predicted reliability" as "average," up I believe from "less than average."
    How does Consumer Reports predict reliability just based on reader responses? When the only basis is past history data, the only thing you might be able to demonstrate is trend. Perhaps the CU definition bears closer scrutiny:
    "Predicted reliability is a JUDGEMENT based on our annual reliability survey data. New or recently redesigned models are marked "New." -- Consumer Reports Buying Guide, 2004, page 171.
    A "judgement" based on survey data? I can't believe that the fine editing staff at CU couldn't be more explicit. The term "judgement" refers to a human condition, so it sounds like people are interpreting the data instead of letting the data speak for its self.
    How did the Dakota and Mitsubishi Eciplse both get a "predicted" average when the Eciplse's individual years (2000, 2001) were rated worse than Dakota, and included SIX YEARS of "insufficient data?"
    Dusty
  • bpeeblesbpeebles Member Posts: 4,085
    Do not forget that CR gets all of its historical data from the annual questionare it sends to all of its subscribers. If too few of the CR subscribers own a Dakota, then there is "insufficient data".
    Knowing this is important because one can begin to understand the "bias" that is built into the CR reporting.
    CONSIDER THIS:
    Since CR has been touting Honda and Toyota as the best for many many years, the CR subscribers have, of course, been buying Hondas and Toyotas. Now, when the annual questionare goes out to all of the CR subscribers, guess which vehicles they tend to report on?
    CONTINUING... if CR tends to poo-poo a vehicle in one of its tests... the CR subscribers, being the loyal buch that they are, will follow suit.
    This is one reason that I do not put too much credance in the CR data. Do not get me wrong tho, the overall patterns in their data are pretty accurate. (If the data shows that the exhaust system tends to need replacement after about 4 years... it is often correct.)
    .....about the patterns being accurate. One professor who recently has done a critique of the CR reliability data found examples of gross inaccuracy and flagrant bias even in the category detail reports.
    The one that was really bad was on a Ford car (Torino, I think) in the seventies. Appearently there were an estimated few hundred cars with bad wheel bearings installed on the manufacturing line, so Ford recalled about 10,000 cars in order to inspect, find, and repair the defective bearings. Owners listed this as a "repair" even though only a few hundred were ever suspect. To make matters worse, CR gave that model a "black mark" that lasted for three years, until the model was dropped even though there were only a handful of reported problems with bearings after that.
    When I look at our fleet maintenance reports and compare them to CR's "reliability data," they are sometimes 180 degrees different.
    Dusty
    I see that Mopar Performance Parts lists a "high performance" air filter for the Dakota/Durango 287 (4.7) motor, PN P4510466.
    Has anyone tried this filter? Any comments?
    Best regards,
    Dusty
  • sunburnsunburn Member Posts: 319
    I was at my local dealer the other day and they had a 2004 QC sitting on the lot. It had a very different trim package compared to previous years. The upper front bumper was black and the lower front bumper was painted, just like you would find on previous Dakotas with the Sport package. The grille, however, was chrome, like you would find on an SLT package. Did Dodge merge the Sport and SLT packages for 2004? I thought it looked kind of ugly.
    Sunburn, yes. The 2004s all have a chrome grille with the exception of the base model.
    The base model front fascia and grille are gray. The rear bumper is black upper and gray lower.
    The SXT has a chrome grille with gray front upper and lower fascia. It comes with body-colored wheel flares. The rear bumper is black upper and gray lower.
    The Sport gets a chrome grille with the upper fascia black and lower fascia body color. The wheel flares are no longer standard. The rear bumper is black upper and gray lower.
    The SLT has a chrome grille, chrome upper front and gray lower front fascia. The rear bumper is chrome.
    The only body-colored grille is with the Stampede package, now a model variant instead of an option. This includes a full body-colored front fascia and rear bumper.
    Dusty
  • mopar67mopar67 Member Posts: 728
    it relies on the person filling out the questionaire to determine what constitutes a "serious" problem.
    I know this for a fact as I have filled out and sent in this very device for 7 years now. Often the mindset of the participant as well as good or bad dealer service can influence how those questions are marked.
    Suffice it to say, CR is ok at best, downright biased at worst.
    According to the parts person at my dealership, 2002 and newer Dakotas and Durangos received completely different brake components, including different rotors. He said that their incidence rate of in warranty rotor replacement has dropped to near zero (he said that one 2002 Durango got warranty replacements at 31K).
    This might explain why I haven't heard of any rotor complaints on newer Dakotas.
    Dusty
    Now at 20,000 miles my '03 Dakota Club Cab 4.7 and 545RFE has a to-date average of 16.57 mpg. The last two tanks were 13.45 and 13.59, but it has also been sub-zero temperatures here in Western New York state. This was a similar pattern last winter. The last tank includes a rather hasty trip on the expressway that would be considered non-conducive to good mileage. All through October and November the average remained above 17.2, and that included a lot of around town driving.
    One thing I noticed was an apparent increase in mpg after I replaced the factory air filter. Unfortunately the temperatures dropped precipitously soon after so that cannot be verified.
    Dusty
  • hennehenne Member Posts: 407
    Well, I traded my 02 Quad Dakota for a 04 Chevy Silverado. I hope none of you have to go through the same problems I had and I wish you all the best of luck. I will look in once in a while to say hello and see how everyone is doing.
    Robert
    Good luck! Hope your Chevy meets your expectations. Rick
    Robert, please don't be a stranger. We like Silverado guys as well. Here's wishing you the best with your new mount, and please continue to monitor and post. Let us know how you like the Chevy Silverado. It is a good looking truck. Give us all of the details.
    Bookitty
  • ford_biiford_bii Member Posts: 120
    Your only mistake is that you should have bought a new F-150. :)
    Sorry, I'm a Ford/Dodge guy. Never did like Chevys.
  • spike50spike50 Member Posts: 481
    Its has been interesting to note everyone's truck experiences over the last 4 years in the context of a statistics class that I just finished. The original design and construction quality of every component on the truck varies widely (more than it should it seems). And there appears to be certain trucks that get more than their share of marginal or outright junk components destined to fail prematurely, making life miserable. It's unfortunate that it happens in this day and age with all of this potential to do the right things in the beginning to produce and maintain a good product and loyal customers.
    Although 99.99% of us have never met face to face, it is a loss, nonetheless, when "one of the family" leaves under these circumstances. Good luck with your next truck and may the "good" statistics be with you.
  • dodgetrukndodgetrukn Member Posts: 116
    Happy St Pattys Day!! DRINK GREEN BEER !!
    Replaced original plugs at 45k miles..now confirmed after 3 tankfulls of gas, that my avg has gone up from ~16.2 to ~16.8 mpg! Even using the OEM plugs, champions..Quick job, and didnt break the clips holding the water hoses over the intact manifold. Waiting for dry warm day(s) to change the rotors, as definitely needed. Be safe tonight!!
    Ger, 2001 quad,4.7L - 3.92lsd
    My subject vehicle is a 2003 Dakota Club Cab in Bright Silver metallic. The finish is very smooth with no orange peel anywhere.
    I have used NuFinish for a number of years on a number of vehicles. Although there have been others tested that appear to shine a little better, I have liked the NuFinish liquid product for the following reasons:
    *very easy to apply
    *fairly easy to remove after haze
    *more durable and longer lasting than other products I've used
    All things do not remain the same and having seen the recent ads for Turtle Wax Ultra Platinum Series I decided to try it.
    Today was in the mid sixties here in Rochester, NY with overcast skies and sporatic drizzle. After a good wash I applied the Turtle Wax Ultra leaving the hood as my compare test (half NuFinish, half Ultra). With the exception of the hood this is the first coat of wax since last fall.
    Comparatively the Turtle Wax Ultra is creamier in consistency. NuFinish liquid is as consistent as Pepto Bismol while the Ultra is more like yogurt. The Ultra goes on noticeably easier than NuFinish, but I found that it took longer to come to a haze. The Ultra appears to go on and come off with less labor.
    My shine evaluation is subjective to my eye, but it appears that the Ultra seemed slightly better. It was most certainly not less shiny as the NuFinish. Even if it is, the application labor is less than NuFinish which has a tendency to go dry quicker. The Ultra appeared to have less friction when lightly dragging my fingers across the two finishes. One thing I noticed was the Ultra actually removed dried NuFinish from last fall around the "Dakota" and "Dodge" tape emblems on the tailgate and left no residue in its place.
    We'll have to wait to determine which lasts longer.
    (AutoZone)
    NuFinish Liquid 16 ounces = $5.99
    Turtle Wax Ultra Platinum Series 16 ounces = $7.99
    Dusty
  • quadmeisterquadmeister Member Posts: 25
    I use Meguires. Goes on easy, comes off easy. Not overly expensive. Gives a really nice finish. My truck is silver and it leaves a wet look with good "alder abrasion resistance". It did wonders for the look of my old wine colored truck that had many light scratches (from said alders while Rain Dance was applied). The burgundy wine color looked as if the paint was just sprayed on, all the time.
  • ronslakieronslakie Member Posts: 58
    Dusty - I used NuFinish for years but switched over to Zymoil about 3 years ago. I believe it gives a better shine and it definitely lasts longer. I do mine twice a year but find that water is still beading on the finish 6 months later. It is a little pricey at $12.99 but it was rated #1 by Consumers Report in there most recent tests.
    Ron
    Has anyone noticed that ZYMOL is the most expensive wax on the wallmart shelves? This is for very good reason. Do some research on Caranuba wax and find out for yourself.
    http://www.zymol.com/phihome.htm
    I tried that NU-FINISH stuff once.... the next rainstorm, it "bled" from the roof to the windshield which made night-vision impossible for months. (no chemical was able to remove the silicone residue)
    UNDER NO CONDITIONS SHOULD PETROLIUM-BASED WAX (parafan)BE USED ON YOUR PAINT! (but it is great for candles)
    Personally, I am looking for protection... not "gloss" nor "beading". Neither of these are very good measurments of protection or longevity.
    Bpeebles, are you thinking of Finish 2000? The Nu-finish doesn't run at all and it contains no silicone. It's advertised as a "ceramic coating." Nu-Finish has always been in a medium orange plastic container around here. The Finish 2000 comes green and an off-color orange. I've never used it, but it appears to be a spray on, I think.
    I just picked up some Rain-x glass wax tonight and noticed that the shelf where the Zymoil was kept was completely bare. The counter guy at AutoZone said it's the best selling wax they carry, and the most expensive, too.
    How does the Zymoil do for lasting?
    Dusty
    (Dusty) I find zymol leaves a *deep* finish rather than a glossy finish. Folks that finish cars for show often use a yardstick to see how *deep* the paint is. (by looking at the reflection of the yardstick held vertically agains the paint)
    As for "lasting", I have been using zymool on my Dak for several years. The dirt just falls off when it is hosed off. I do not use *beading* as a measurement of "lasting" but it is obvious that the zymol is still there after several months.
    Interestingly, a sticker fell off my VW TDI this past winter exposing NON-zymoled paint. I found it very noticable that one area of the paint is ALWAYS more dirty than the rest of the vehicle. At first, I thought there was some sticky-residue on that area attracting the dirt but after a thorough washing to make sure, that area of the paint was dirty after the next rainstorm. My only conclusion is that the zymol on the rest of the car (applied last fall) is allowing the dirt to "shed" and not stick to the paint.
    You may draw your own conclusions...
    Last fall in an AutoZone store I saw gallon containers of HOAT antifreeze that was pre-mixed to 50-50. I was in this afternoon and they didn't have any in stock and said that was a first time purchase. They had never carried it before. The counterperson did not remember the name of it.
    Anyway, has anyone seen something like this in any auto parts stores?
    Thanks in advance,
    Dusty
    This is our first week or so of weather constantly above 55 degrees (F) in Western New York State. My 2003 Dakota (CC, 4.7, 545RFE, LSD 3.55) now has 23750+miles:
    * Mobil One 0W-30 motor oil
    * plugs changed at 10,000 miles
    * air filter replaced at 20,000 miles
    * no modifications from stock
    My daily drive is 6.4 miles to work with a few miles each day on the company facility. There are approximately 5-8 restarts per day.
    The last five tanks returned (in descending order) 16.68, 16.95, 17.34, 16.13, and 16.12 MPG.
    The running total since the vehicle was placed into service is 16.42 MPG.
    From 1 June through 15 October of last year, the average MPG was 17.1 (low 16.21, high 20.16).
    Best regards,
    Dusty
    (Dusty) Those Milage numbers are about right for an automatic xmission.
    One suggestion. Just reciently, Mobil has started to repackage its "Delvac1" oil for consumer use. Anyone that knows oil can attest that Delvac1 oil is perhaps the very best engine lubricant available today. It has seen MILLIONS of miles of use in fleet usage. With proper filtration on an engine, this oil can easilly go over 30K miles between changes.
    Now you and I can get this very same oil packaged in quart containers. It is called "Mobil 1 Truck&SUV 5w40" and is now on the shelves at Wallmart. The next time you are there, actually READ the bottle and see what I mean about this oil. It faaarrrr surpasses anything else on the wallmart shelves. (And costs the same as 'normal' Mobil1)
    Besides, that 0w oil you are using may not be desirable for your engine. ;-)
    Look at the Mobil 1 specifications:
    Mobil 1 0W-30:
    Viscosity @ 82F = 56cst
    Viscosity @ 212F = 10.3cst
    Pour point = -54F
    Viscosity Index = 175
    Flash Point = 234
    ___________________________________
    Mobil 1 5W-30:
    Viscosity @ 212F = 10.0cst
    Pour point = -45F
    Viscosity Index = 167
    Flash Point = 224
    ____________________________________
    The 0W-30 in Mobil 1 is the better oil. With a VI of 175, its actually more stable and has a higher viscosity at higher temperatures. In actuality the 0W-30 in Mobil 1 is nothing more than their 5W-30 with a lower pour point. This increases pumpability and ensures start-up and low temperature flow better than the 5W-30. The additive package formula will also increase moisture purging better than their 5W-30.
    Unless I were to plan a summertime trip to Arizona or someplace hot, I plan on running it all year from now on.
    Bests,
    Dusty
    Delvac was developed for fleet operators who wanted a motor than could provide service across a wide application and operated both gasoline and diesel engines.
    In general I stay away from wide viscosity service numbers. I have never used 10W-40 because of stability problems, although newer blends have better numbers than they use to. Older 10W-40 formulations were the cause of premature sludge build up, especially in colder climates.
    Looking at Mobil's specifications, the thing I find a little disconcerting is the way they state low temperature viscosity. The industry standard is ASTM D445 (82 deg. F; 27 C). Here Mobil states low temperature viscosity at 104 degrees F. At this temperature and 102 centistokes, this oil is too thick for winter time operation in a gas motor...in my opinion:
    Mobil 1 5W-40 Truck & SUV:
    Viscosity @ 104F = 102cst
    Viscosity @ 212F = 14.8cst
    Pour point = -45F
    Viscosity Index = 151
    Flash Point = 226
    In my experience Delvac has been used primarily by fleet operators with diesels, although I know Mobil has marketed this oil as gasoline friendly. Diesel motors are usually more tolerant of heavier oils because they're not as tight as gas motors.
    Bests,
    Dusty
    (Dusty) I agree that perhaps this oil may not be the best choice in the winter when -17F is the norm. (That is what I get here)
    I notice you do not mention the TBN (Total Base Number) in your comparisons. The TBN is the measure of an oil's ability to neutralize the acids that result from combustion. In real-world measurements, Delvac1 maintains its TBN where other oils tend to depleate their TBN.
    It is the TBN that allows for extended change intervals. When paying extra for oil, not only do I want better lubrication, I also want to leave it in the crankcase longer. This helps make the extra initial cost of the oil negligible.
    You also did not mention the Sulfated ash levels of the different oils either.
    BTW: Here is the release notice of this oil
    http://www.exxonmobil.com/Corporate/Newsroom/Newsreleases/xom_nr_- 041103_3.asp
    I just happened to notice the other day that the GVWR of a Grand Caravan is around 6600 lbs. The GVWR of my QC is only 6010 lbs. Why is the Dakota such a weakling when it comes GVWR?
    Sunburn, do you know what the unladen weight of the Grand Caravan is?
    My '03 Club Cab is rated the same as yours, 6,010 pounds GVWR. It weighs 4008. That leaves 2002 pounds for load, roughly. I forget what the tow rating is for the moment, but with the 4.7 I believe mine would be higher than the V6 version.
    If the Caravan weighs 4500 pounds, it means essentially that it's load-carrying ability is near 1500 pounds.
    Best regards,
    Dusty
    Dusty,
    I believe the GC weights in the 4500 lb ballpark. With a GVWR of 6600 lbs, that leaves 2100 lbs for payload.
    The 4008 lbs for you CC, is that from the owner's manual or have you had it weighed? According to the manual, my QC weighs 4550 lbs. However, it actually weighs 5010 lbs. Now, I've added a fiberglass cap, bed liner, and nerf bars, which probably add about 250 lbs. The weight of the options and stuff we add to our trucks adds up fast. Even by the book, my QC only has about 1400 lbs for payload. Which isn't much.
    I was just suprised to see the GC, which is unibody with a soft suspension, have a higher GVWR that the Dakota, which is a full frame construction. How much of these numbers are marketing vs. engineering?
    sunburn... I happen to have one of those right now... a sunburn that is.
    That number is most likely due more to marketing. DC has been known before to "accidently" fudge the numbers. My sister has a Caravan (not the Grand) and I'm pretty sure her van's #s are nowhere near that... and it doesn't appear to be a whole lot different than the Grand that parks beside me at work every day... other than the bells and whistles, that is.
    ...however, one might be surprised what a GC can carry, but I'd like to witness it before I believed it.
    ...by the way, if you were in the truck when you had it weighed, by my calculations that puts you at about 300 lbs, don't it? ;-)
    Sunburn,
    No I haven't had mine weighed. The 4008 pounds was the listed weight on the factory invoice form that is used in New York State for the Certificate of Title filing. It is listed as "shipping weight."
    As to your Quad, the difference is 460 pounds from the listed weight to the actual. You said that your cap is fiberglass. In my experience they are fairly heavy. If I had to bet money, I'd guess that cap is 250 lbs. by itself. And if you had a full tank of gas there's another possible 100 lbs.
    As to the difference between the mini-van and Dakota, whatever they say the van can carry I know the Dakota will handle that and more with ease.
    Bests,
    Dusty
    Bpeebles,
    The sulphated ash content in percent (ASTM D874) is 1.2 for 0W-30, 5W-30, and 10W-30 full synthetic blends.
    I don't have total base numbers for any of the oils on my list. Is that the same as ASTM D287?
    Bests,
    Dusty
    My QC's weight of 5010 lbs was without driver and a full tank of gas. As far as the cap goes, the manufacturer listed the weight as 135 lbs. I haven't had it off, so I can't say if that is correct or not.
    I used it when I had the Dak. I run it in the Suzuki now.
    Key thing as dusty mentioned, is the ability to pour at very low temps. To me, this is important as like the Dak, suzuki has camshafts sitting waaaaaaay up in the cylinder head. And like the 4.7, the cams spin in plain bearings in the head (meaning there are no inserts like a crank bearing). Thus, "wiping out" a cam "bearing" (using the term loosely) means also pooching the cylinder head. That means a new head. Read $$$$$.
    My logic is I want my oil up there doing its lubricating job as quickly as possible. That is why I use Mobil 1 synthetic, 5w30.
    Of course, a quality oil filter is key too but that's another discussion altogether!
    (dustyk)
    Here is a link to the datasheet for DELVAC1 5W40 (AKA "Mobil 1 Truck & SUV" ) You can see that the TBN is "12" . Keep in mind that "raw" TBN does not mean much.... the TBN after running 7,000 miles is more important. This is where this oil really shows its strength.
    http://www.mobil.com/USA-English/Lubes/PDS/Pds_Files/glxxe2cvlmom- obildelvac1_5w-40.pdf
    It appears that neither Brembo or Power Slot make rotors for the '03 and up Dakotas. As I've mentioned in here before, in '03 Dodge upgraded the brakes on the Dakota and the Durango and begining in '03 each received a different rotor setup.
    I checked with the local auto parts stores and no one has a listing for a '03 Dakota rotor...yet. I checked with my Dodge dealer and they have ONE at $90.00 each. He also said it was the first time he's has an inquiry about the '03 rotors and they haven't worked on any yet.
    The parts guy said they'd give me a discount(I suspect 10% since that's what they've done in the past) because I bought the truck there, but I passed on it since I think I'll wait until someone else comes out with one.
    For the '02s and down the best price I've seen on the web for Power Slots is $107.00.
    I did get to compare a '02 and '03 together. The '03s are heavier and as someone else commented the one I looked at was stamped "Bosch." The '02 was "Made in Canada."
    Dusty
    While I was there the parts counter guy said that Mopar had just lowered the price of ATF+4 from $27 per gallon to $17. ATF+4 is now only about sixty cents a quart more ($4.63 US).
    I wouldn't be surprised if ATF+3 is going to be phased out.
    Dusty
    One thing I forgot to mention. The '03 rotor is coated, the '02 is just bare gray iron.
    The '03 coating could be zinc or nickel cadmium derivative of some type.
    Dusty
    Has anyone taken off the front cover? Is it possible or completely out of the question to put a LSD or a selectable locker up there? Has anyone ever done it? What are the benefits: 2WL drive, tighter turns in 4x4 mode, maybe some improved handling on ice while in 4x4 mode, etc.?
    I'm not even "close" to starting a project like this but I'm curious.
    There is a reason that most OEMs do not offer a front LSD or locker. Unless you expect to be in the mud up to the axles or climbing over bolders, it is not a good idea. You will have virtually NO ability to control the direction of the vehicle.
    Have you never driven a normal 4X4 in the snow? With the xfercase locked in 4X4, tight turns are almost impossible because the front differentail (even with open differential) will make one of the wheels slip thus removing all steering ability. Adding a locking front diff makes it worse.
    Another real risk is that the front axles or driveshaft can be easilly ripped out the vehicle if there IS traction available.
    In other words, the front wheels MUST be free to spin at different speeds in order to steer the vehicle.
    My QC is a 4x4 and I've had some experience with 4x4 mode in different driving situations but you would never see my picture in a hard-core 4x4 magazine, unless it was in the "stupid move" section. I guess I'm wonder why a front dif LSD wouldn't provide the desirable 4x4 qualities, as well as, allowing for tighter turns while in 4x4 mode because the inner wheel could turn "somewhat" slower than the outside wheel, as is the case on the LSD equipped rear dif? It seems that these full-time AWD systems have multiple LSD's through out the drive train and they operate safely. Hey, just wondering out loud.
    I belive a LSD in a front differential gives you undesirable handling characteristics in turns. I believe that the best approach would be to install a "air locker". If you were in a situation you needed the additional traction you could engage the locker but in normal driving with it off you still would have an open differential. Rick
    Some years ago, one of our engineers proposed using limited slip or Posi-Traction on both ends of our rough terrain material loaders used in forestry, construction and industrial applications. The thought process was: If one is helpful in negotiating rough terrain, then two would be twice as helpful. Having "been there and done that" with a previous manufacturer, I rendered my opinion only to have it overridden. We built these machines with 2 wheel/4 wheel steer, with the 4 wheel steer selectively offering 4 wheel follow through or 4 wheel oblique. We also built articulated steer machines. With the test models, the 4 wheel steer needed only about 2 acres to make a circle in 2 wheel steer mode and about 3 acres in 4 wheel steer with some considerable "Armstrong Steering" boost. The articulated models never did make the circle as we ran out of continent. And boy did it fight!
    Bookitty
    Yes, it's true. But this time it's NOT a Dakota!
    A friend at work asked me to help him with a rotor change-out on his 2003 Ford Sport Trac. The original pads were still on it, but the rotors were warped pretty bad. Both the inside and outside rotor surfaces looked clean. Not like mine. So it appeared obvious that rotor surface scuzz was not the problem. This one had either some serious hard spots or were badly warped.
    One thing I must say after looking at this Explorer, the factory Dakota pads are probably pretty good quality. This Sport Trac was just about out of pad.
    Anyway, it's not just Dakota's.
    Best regards,
    Dusty
