2021 Toyota Tundra Lease Deals and Prices
1234689
  • kyfdxkyfdx Moderator Posts: 262,566
    Oh, ok. How about the midwest area - 63111 for example.
    .00219 MF
    74%/68% residual
    But, those are Toyota Financial numbers
    SETF is a completely different bank. The numbers may not even be close
  • schmatschmatschmatschmat Member Posts: 44
    Could I get numbers for a 2021 Tundra SR5 CrewMax 4x4, for 36/39 months, 10k a year, in 49267? Thanks!
    .00219 MF and 73% residual
  • revelliosrevellios Member Posts: 4
    May I please have the residual value, money factor and any available incentives for the following:
    2021 Toyota Tundra SR5 4D CrewMax 4WD
    Zip 52405
    Thank you very much
    Zip 52405
    Thank you very much
    .00219 MF and 72% residual
  • swjacksonswjackson Member Posts: 10
    Can I get the mf and rv on a 2021 tundra crewmax 4x4 sr5 32507 36/10
    Sorry, but we don't have the Tundra programs for the Southeast Region.
  • JschneiderJschneider Member Posts: 2
    Looking for MF/RV on a '21 CrewCab Limited, 36/15k in 55038? Dealer says USBank is better than TFS.
    .00219 MF and 70% residual
    We don't have the US Bank programs
  • rawchuckrawchuck Member Posts: 1
    Hi, can you please give me MF/RV on a 2021 Tundra 1794 CrewMax? Looking for 36/12. Thanks!
    What is your location?
    2WD or 4WD?
  • CantHavMyCouchCantHavMyCouch Member Posts: 2
    Can I get MF (Tier 1 & 2 if possible) and RV for 2021 Tundra SR5 CrewMax 4WD 36/12
    Zip 65202
    Thank you for your time
    Also, any incentives or rebates please. Thanks!
    Zip 65202
    .00245 MF and 72% residual
    Sorry, don't have lower tier info
  • s1175290s1175290 Member Posts: 4
    Hi! Could I get MF and RV for a 2021 SR5 Crewmax 4WD for:
    60148
    Is it the same as 65202 above?
    Any incentives? I do have an existing Toyota lease.
  • MichaellMichaell Moderator Posts: 260,197
    60148
    .00245 and 72%
    No incentives
    MO $1000 loyalty
  • KJ_ducKJ_duc Member Posts: 5
    TRD PRO
    83714
    24/15k
    KJ_duc said:
    TRD PRO
    83714
    24/15k
    Crew or Double Cab?
    KJ_duc said:
    TRD PRO
    83714
    24/15k
    Crew or Double Cab?
    Crewmax. Apologies
    KJ_duc said:
    KJ_duc said:
    TRD PRO
    83714
    24/15k
    Crew or Double Cab?
    Crewmax. Apologies
    .00245 MF and 78% residual
  • jimziggjimzigg Member Posts: 71
    53150
    36/15 and 39/15
    Any incentives? I do have an existing Toyota vehicle.
    53150
    36/15 and 39/15
    .00245 and 70%
    No incentives
    No loyalty
  • snowthundahsnowthundah Member Posts: 6
    Do you have the MF and RV for a TRD Pro Crewmax 3 yr, 30k mile, zip 01876?
    .00245 and 75%
  • err0r4o4err0r4o4 Member Posts: 36
    Hi could I get the RV / MF for a
    2021 Tundra SR5 5.7L 4WD CrewMax
    24/12
    Zip code 19810
    Thanks!!
    24/12
    Zip code 19810
    Thanks!!
    .00245 MF
    78%/72% residual
  • Angel_Fig27Angel_Fig27 Member Posts: 3
    Hi there, may I have MF/RV for 2021 Tundra TRD Sport 4WD CrewMax
    36/12 in 91762? Thanks!!
    I don't see a TRD Sport trim for the Tundra
  • NATS7599NATS7599 Member Posts: 2
    Good morning, may I have MF/RV for 2021 Tundra TRD Pro 36/12 in 22554? Appreciate the time!
    CrewMax or Double Cab?
    CrewMax, Thanks!
    CrewMax, Thanks!
    .00245 and 74%
    Sorry, it would just be a SR5 Trim 4x4 CrewMax 36/12 in 91762. Thanks!!
  • jnarmstrjnarmstr Member Posts: 9
    Could I get the RV/MF/incentives for a:
    2021 Tundra SR5 CrewMax 4x4 for 24/12 and 36/12 in zip code 32409
    Sorry, we don't have the Tundra programs for the Southeast Region
  • mwilson6618mwilson6618 Member Posts: 4
    Hello, Can you provide RV/MF/incentives for 2021 Tundra Limited CrewMax 4x4 for 36/12 in 98011.
    Please and Thank you!
  • Jpw78Jpw78 Member Posts: 1
    Can you provide the RV/MF/Incentives for:
    2021 SR5, 4WD, Crewmax (do options such as TRD matter)
    Zip code: 37042
    Zip code: 37042
    .00245 and 70%
    No incentives
    Options and packages do not affect the program numbers
  • impaul4impaul4 Member Posts: 47
    Can I get MF, RV, incentives for 2021 Crewmax TRD Pro 4x4 . 79258. Could I get it for 24/12 and 36/12. Thanks
    .00245 MF and 80% / 74% residual
    No incentives
  • HECMPROHECMPRO Member Posts: 12
    Thank you for helping so many!
    Does a lease MF run higher, lower, or equal to Loan APR? i.e. with excellent credit, you could expect an APR of 4.42%. Does that mean if you decide to lease, they should be offering a MF .00184 ? It sounds too easy to me. I'm trying to prepare with what the dealer might present and in my experience, it's always grossly high unless you are prepared and push back.
    I'm looking at three 2021 Tundra trims in 78613, when time allows what would be the MF & RV (excellent credit)
    Crewmax TRD Pro 4x4 - 24/12 , 1794 4x4 - 24/12, Limited 4x4 - 24/12
    Thank you!!! You are very appreciated!
    .00245 MF
    80%, 74%, 78%
    Lease MF are completely separate from finance APRs. No correlation between them, at all. I suppose that's the banks way of encouraging customer to buy or lease, accordingly.
    Hi there!! Thanks for all the help!! May I have RV/MF 36/12 for 2021 Tundra Platinum Crew Cab 4x4 in 91762. Thank you so much!!
    .00245 MF and 70% residual
  • KnndlbKnndlb Member Posts: 11
    Hello, can I get the MF, Residual, and Incentives for Crew Max cabs in 76017 on the following:
    SR5 4x4
    Limited 4x2
    Limited 4x4
    TRD 4x4
    Thanks in advance!
    SR5 4x4
    Limited 4x2
    Limited 4x4
    TRD 4x4
    Thanks in advance!
    SR5 4x4
    Limited 4x2
    Limited 4x4
    TRD 4x4
    Thanks in advance!
    Knndlb said:
    SR5 4x4
    Limited 4x2
    Limited 4x4
    TRD 4x4
    Thanks in advance!
    Unless you are buying by tomorrow, all of these numbers expire...
    Why don't you wait until after Wednesday?
