I hope she doesn't park it in her garage these days.
She probably doesn't drive it much...she probably has a chauffeur.
Looks good. But have you seen any for sale? I can’t seem to locate anything other than pics.
It is made in China. I think there are similar ones, such as Polaris, but they seem to make them for work purposes.
At least something like this doesn't look goofy;
....also be nice to have 4 seaters.
"Soapbox ON"
I searched for some other battery problems. I don't recall any big thread about Hyundai in February 2021.
Hyundai to replace 82,000 electric-vehicle batteries over fire risk
https://www.bbc.com/news/technology-56156801
Even Toyota has 12-volt battery issues...
https://www.reuters.com/article/us-toyota-probe-usa/u-s-investigates-nearly-1-9-million-toyota-rav4s-over-fire-risks-idUSKBN2AT2IT
And Honda has 12-volt battery and computer management problems
causing what is being described as parasitic drains.
http://www.hondaproblems.com/battery-drain/
I would expect more from Honda, but then... they're not GM
so I don't recall any discussion here? Hmmmm.
"/SOAPBOX OFF"
“Garcon, bring me a brand new Bolt EUV in the same color as my original. Make sure this one has four smoke detectors installed as well two fire extinguishers filled with propellants (a la James Bond) and a fireproof suit under the driver’s seat.”
Problem solved and GM comes out smelling roses.
Those links all go to the Hyundai battery recall
I’m debating if I want a 6-seater. I mean, it would be nice, but they are all pretty big. There are some that have 4 forward facing and 2 rear. Not too bad. Pricey, though.
I’ve also been kicking around the idea of a small wagon of some sort. Seems like the cost wouldn’t be much different. Like… ok, hang in there with me … a Honda Element where I chop off the top.
But I don’t know the rules down there. I assume a real car would require real car inspection, reg, etc. So maybe I wouldn’t be allowed to chop off the top.
Nope! Helped a bit on my right side but left side very painful. Starting therapy tomorrow but my PCP called me yesterday and said he thinks I am going to need surgery to relieve the pain. He told me to try the epidural again in a few months, but the neurosurgeon would be next. Very frustrated! 😩😩😩
Mike, I’m so sorry to hear you did not get much relief.
Ugh. Well, speaking of appliances (as we usually do), our 17-yr-old washer finally gave out. I could probably fix it, but seems a fool’s errand. It made a god awful noise last night and stopped spinning. I dragged it outside and opened her up to find this. And that was after finding out the outer lip of the drum case was worn through.
2018 430i Gran Coupe
I would really look into it. There are different rules about licensing, being able to drive on sidewalks, safety inspections. 6 seaters tend to be big and long. I don't know how safe these things are, so I don't know if you want to drive around with 6 in one of them. I have seen them in Sun City where there are lots, people drive them and let their dog run beside them on a leash.
It's still being salvaged.
About 2 minutes in, the sections currently being salvaged are shown(5 and 6).
5 minutes in, I think I see a white Telluride.
+1 A lot to go through for little gain. I hope they can find a solution that works.
I think the front-loading washers, like ours, likely have a shorter life expectancy. Holding up all that weight from the side is not nearly as easy as doing it from underneath.
And, yes, we’ve raised 2 boys with it. Lol. It has led a rough life. Just ordered a new one from Costco. Won’t be here for 9 days, though. Oh well.
Point of this, wife wants no part of another front load, so we plan to get a top load HE unit (no agitator) instead. At least no more moldy door gaskets to deal with!
We tried a top load when we moved, and I left the front load with the renter. Wife HATED it. Said it didn’t clean the clothes well. So when our first renter moved out, the rental home got our brand new washer and I brought the old one here.
I just received an email from UPS or FedeX (can't remember which) indicating that delivery on my 58 pound recliner from Wayfair is expected Sept. 8.
However, I could not help but notice that it says the package will be left on the front yard in its original packaging. I will be responsible for unpacking and assembling the chair as well as disposal of the shipping packages.
I thought this was a joke but my wife says the shipping company no longer enters your house. Their responsibility ends with delivery in your front yard, rain or shine. What gives, is this the new normal? So much for free shipping.
I didn’t realize they had a fire on board. What a job they are doing.
You will have keep us appraised about how your new tires work out.
New tires do take some miles to work in.
I know you feel like you are taking a chance with a tire that is a new design.
Also, I thought places did not cross rotate any longer. Just did front to back on the same side. Which is what car companies called for. Definitely have to on the directional tires.
The only victory I’ve had recently is my window air conditioner which started leaking condensation in buckets down the inside window sill. I took the case apart and hosed a lot of sludge out of the interior. Now it runs better and doesn’t leak.
Make sure your window AC unit has a downward slant on the outside.
I don't know about the Costco guy, usually tires made for snow won't last as long because they have to be softer to grip the road....you can't have everything. Who cares about extra miles if it is a great performing tire. The Pirellis on my E400 are noticeably much better than the Goodyears....I wish I got them sooner.
They give the address for head office as;
© 2021 Mercedes-Benz USA, LLC, A Daimler AG Company
One Mercedes-Benz Dr.
Sandy Springs, GA 30328
Do you think MB is still in the Daimler Building?
I am not sure if this is the same phony return email address as last time;
survey.research-w4187@sendyourfeedback.com
2014 BMW 428i convertible, 2015 Honda CTX700D, 2025 Hyundai Tucson Limited.
Anyway, not really enough information on it to make a good suggestion. But I would say that due to the fact that selling the stock could result in a tax liability and that with what's going on with current government spending might trigger high inflation I wouldn't suggest accelerating payments on any long term liabilities. If I were him I would wait for retirement before paying off or refinancing to a shorter loan term.
Since you’ll be up that way maybe you could say hello to our poster buddy @xwesx.
If i remember correctly there are no roads or ferry service to Bethel, AK. You would need to ship your car there.
I think they are hyping it so that people will actually evacuate the area.
They problem with that is that people remember the overhyping and the next time around they will ignore the warnings. Remember the boy who cried wolf?
Second on the way home I saw a 70's maybe early 80's corvette with a targa top. From the back I could see that the top of the drivers head was about 2 or 3 inches higher than the roof line of the vette.
Nissan failed with a convertible Murano, so RR figured they should try too.
I can't imagine the insurance claim on this accident
Speaking of drop tops I got to drive a Mazda MX5 yesterday. Made the Corvette feel like a limousine. While it felt fairly comfortable once you were in it, getting in and out was an adventure. When I got out the 3 hairs on the top of my head were totally messed up from the wind. :'(
He said, "today, we are finally testing driving the New Kia EV6 for the 1st time, Kia’s New EV. The Kia EV6 is Kia’s all-new EV car based on the all-new E-GMP platform, which is, of course, it shares with Hyundai IONIQ 5. Our test car came with dual-motor system (Long-Range) producing 239kW and 605Nm of torque. So, now let’s go out and drive the Kia EV6 and see if it is better than other EV cars, especially Hyundai IONIQ 5."
