Visitor Agreement.
Pretty soon the guy that patented the pill that you plop into a tank of water will be selling it on the internet.
And of course that always works. Like the law that says not to cheat when doing your taxes.
Well I don't when I fill up the bike If I let go of it it will fall down.
There has never been a government in the history of mankind that has actually thunk things through?
Two different factors in play here. The automatic shutoff is universal. What’s not universal is the hold-open latch. You don’t need it for the pump to shut off when the tank is full. I think it was in NC that I found pumps without a hold-open latch, but that’s where I would wedge the gas cap in if I needed to clean the windows.
I use the GasBuddy site to find the cheapest place but even with that you have to be careful. They rely on volunteers to report on prices and I suspect that some are signing up just to mess with people.
For example, Sunday I went to a nearby Sunoco station where the site said premium was $4.07/gal. Extraordinary cheap for around here. When I pulled in premium was $5.79! Way too much to have been a recent price hike. The reporter was either dumb as a rock or was deliberately misleading people.
Where did you see that? I thought they outlawed that a long time ago in NY
Local BJs gas station, unbeknownst to me, is under renovation. So, Stop & Shop gas, $4.30 PUG. RUG was $3.70, not a bad delta these days.
I used to always just fill when I wanted it (about 1/4 tank) since my stations were convenient and I passed them all the time. At the new place the cheap ones are not as close or where I usually go so I stop when I see it if I’m near half a tank or so.
If the stock Shelby GT500 Mustang and its 760 supercharged horsepower is too pedestrian for you, Hennessey Performance out of Texas has the answer.
Even though the 5.2-litre V-8 is the most powerful factory engine ever dropped into a Mustang, the speed demons from Texas felt the need to juice the stock setup, significantly increasing horsepower and torque, to 1,204 h.p. and 902 poundfeet of torque.
Cost, about $50000 if you bring your own Shelby GT500 in to the shop....limited to 66 cars to be made.
Perfect for oldfarmer's next car!
The 2014 C250 has 40000 miles on it. I was wondering about changing the transmission fluid. I always thought it should last for 100,000 miles, that was from the information I could find.
Now, some mechanics claim it should be changed at 50000 miles, which seems a bit soon, though it is good for the mechanic.
Opinions on that are welcome, but, even more important, does it actually wear out and is there a time limit on how long it lasts....that I can't find an answer to?
Yesterday I was in a little hurry going to work. It was pitch black so I wasn’t focused on anything other than staying in my lane. As I entered from the ramp I glanced down and was shocked to see that I was doing 100.
My car as it sits puts out about 460hp. With 1200hp you’d be doing 100 before you got out of your driveway.
Or the owner of the station.
Back in my working days I knew 3 guys who had 70 something Vettes. To avoid the over heating problem they removed the thermostat.
Since none of them drove them in the Winter those Vettes never saw a thermostat while they were the owners.
That’s because it was.
It seems like you can feel a bump even when driving over a quarter in the Vettes I’ve driven or rode in. I’ve never been a fan of that type of ride but a lot of folks are.
Driver. Change the tranny fluid. Brake fluid also is strictly time dependent, even more so in humid Florida where it can absorb moisture from the air.
And this really makes a good point;
Flushing and replacing brake fluid might cost $100 or less on many vehicles, but replacing rusted brake lines, brake calipers and other brake parts can run several hundreds of dollars, so clearly there’s value in keeping up with maintenance. As a rule of thumb, it’s wise to have the brake fluid inspected and tested for moisture content every few years, and no more than every five if you live in a high-humidity area. Drivers living in areas that get winter weather should also inspect their brake system frequently, as salt and other contaminants can get into the brake fluid.
And as if that’s not bad enough, I just saw a report that in addition to catalytic converters and truck tailgates, thieves are stealing taillights now.
https://www.cnet.com/roadshow/news/stellantis-urges-owners-to-stop-driving-cars-with-faulty-takata-airbags/?ftag=CAD13782fc
EDIT: no open recalls on my Charger.
Just don't go OCD and start testing too often. You do have to open the reservoir to perform the test, and opening the reservoir allows moisture from the atmosphere to get into the brake fluid, but if you only test once or twice a year that shouldn't be a problem.
I’m cursed with dishwashers! Older (10 years) unit at the shore is leaking at the front. Luckily it’s pretty easy to tell where the door seal has deteriorated. There are three separate parts. The main body gasket, seal at the bottom of the door and two splash guards.
Amazon has a generic kit for $30 containing all of it with mixed reviews. I ordered (from Amazon) all OEM parts separately for $70. About $30 cheaper than from Frigidaire directly.
That will be my project for next week. Looks like a no tool job, so should be pretty easy.
I think this is going to be a tough winter for some of us.
I’ve heard that the cheapy plastic putty knives are great for installing the press in gaskets as long as you use sandpaper to round over the sharp edges at the front corners.
Good luck. It might go another 10 years or until Mrs. @tjc78 gets tired of looking at it.
Thanks for the tip. I have a few of those down here.
