2023 Porsche Macan Lease Numbers
1356
  • kyfdxkyfdx Moderator Posts: 271,488
    DR_KM82 said:
    Could I get 36 - and 39- month/10K miles per year Res and MF for a 2023 Macan located in 97209? Any incentives?Thanks much!
    .00340 MF and 65% residual
    Either term
  • coolbluesicoolbluesi Member Posts: 81
    Could i get numbers on 12mo/15k, for 2023 macan gts, zip 92618. Also, are MSD’s possible? (If so how much does each reduce the MF by?) thanks!
  • MichaellMichaell Moderator Posts: 267,936
    .00340 and 81%
    No info on an MSD program from Porsche.
  • Ezam1987Ezam1987 Member Posts: 64
    Good morning.
    Can I please get MF/RV/Incentives for 2023 Porsche Macan
    Base, S, and GTS, please?
    Looking at 12/24/36- 10K mileage
    Zip Code- 85008
    Ezam1987 said:
    Good morning.
    Zip Code- 85008
    10K mileage not available for 12 month term
    .00340
    Base / S - 74% / 65% for 24/36 and 10K
    GTS - 75% / 66%
  • BetoAlonsoBetoAlonso Member Posts: 2
    Can I please get 36-39 months / 7.5 -10k miles Res and MF for a 2023 Macan S located in ZIP 33143?
    Can the dealer mark up the MF?
    For either 36 or 39 mo, 10K/yr
    Yes, the dealer can markup the money factor.
  • sd_jcvansd_jcvan Member Posts: 1
    Can you please let me know the MF and RV for a 2023 Porsche Macan Base for 36/10k and 36/12k in Zip 92091? Much appreciated!
    .00340 MF and 64% RV
    Either 36/12 or 39/12
  • carhelp111carhelp111 Member Posts: 22
    What is MF and Residual for 36/10k in 92604? Thx so much!
    Ooops, sorry, looking for Residual and MF for 36 or 39 months/10000 miles. Macan T. Zip 92604. Thx!
    Either term
  • DamandanDamandan Member Posts: 1
    residual/MF for 2022 Macan S for 12 and 24 months at 15k
    residual/MF for 2023 Macan S for 36/15k
    edited February 2023
    .00340 MF
    80%, 71%, 62%, 62% residual
    For: 12, 24, 36, 39 months
  • MbfranckMbfranck Member Posts: 6
    Could I please get 36 - and 39- month/10K miles per year Res and MF for a 2023 Base Macan located in zip 12159? Thanks!
  • garylamgarylam Member Posts: 12
    Hello, may I get the MF and Residual for 2023 Macan "GTS" 10k/yr and 39months and zip 11021 ? Thanks.
    .00340 MF and 66% residual
  • danipersingdanipersing Member Posts: 5
    Hello, looking for MF and residual on a 2023 Macan S, 10k/yr and 36-39 months, zip 99016? Thanks!
    Either term
  • CoopershuCoopershu Member Posts: 51
    Can you please provide MF, residual and any incentives for 2023 Macan GTS 36/10 or 39/10
    zip code 15203..thanks in advance.
    Either term
  • ssamad786ssamad786 Member Posts: 1
    Can you please provide MF, residual and any incentives for 2023 Macan, 36/10? Zip code 14221. Thanks.
    For either 36 or 39 months
  • jennifervsunnyjennifervsunny Member Posts: 1
    edited March 2023
    can i get the mf and residual for a base macan 2023 zip code 33131 also any incentives as well 36/10k
  • greenjackgreenjack Member Posts: 8
    Can I get the mf and residual for a Macan-T 2023 zip code 98004 36/10k? Thank you!
    Either 36/10 or 39/10
  • Cyoung97Cyoung97 Member Posts: 1
    Can you please provide MF, Residual and any incentives for 2023 Macan S, 36/15? Zip code 37331. Thanks
    62% residual for 36 or 39 months
    We don't have the MF yet for April. Might be Tuesday before we get that info
  • rattixrattix Member Posts: 52
    No question here, just commenting.
    Between the inability to get a discount off MSRP, and the insane cost of money, the monthly payments have gotten crazy high.
    In the case of Macan, residuals have gone up a little (maybe 4% on a 36/12) which helps, but the cost of money is over 8% at base rate, and the dealers can and do mark it up because you have no leverage. Good shopping you all!
    .00340 MF
  • alexkwitalexkwit Member Posts: 102
    Would please let me know MF, RV and any incentives for 2023 Porsche Macan and Macan T in 90049 with 10k/year and 36 months. Thanks.
    .00340 MF and 65% RV
    Either trim
  • okiepiperokiepiper Member Posts: 25
    Greetings! Could you share the usual details for 36/39 mo 10k and 7.5k Macan base in 94062? Please and thank you!
    Thanks! Any info on 7.5k?
    66% RV
  • pkk20pkk20 Member Posts: 8
    edited April 2023
    Hi, Would please let me know the Tier1 money factor, residual value and any incentives for 2023 Porsche Macan and Macan T in 07310 with 10k/year for 24/36/39 months. Thanks.
    .00340 MF
    74% / 65% / 65%
    Either trim
  • ConiConi Member Posts: 43
    edited May 2023
    When you get in the May numbers, can you please let me know the MF and RV for:
    Macan / Macan S / Macan GTS
    12 month / 15k miles
    24 month / 7.5k miles
    All in 90046
    Thanks in advance!
    All in 90046
    Thanks in advance!
    Porsche numbers are valid through the end of June.
    .00340 MF
    Base / S - 80% / 75%
    GTS - 81% / 76%
  • CR5CR5 Member Posts: 1
    Hello, can you please provide below for Porsche Macan base model?
    MF: ?
    RV: ?
    Incentives: ?
    Term: 39 mos
    Miles: 10K
    Zip Code: 92101
    Thank you 🙏
    MF: ?
    RV: ?
    Incentives: ?
    Term: 39 mos
    Miles: 10K
    Zip Code: 92101
    Thank you 🙏
    .00340 MF
    65% RV
    Either term
    Hi, Would you please share the latest tier 1 money factor, residual value and any incentives for 2023 Porsche Macan and Macan T in 07310 with 10k/year for 24/36/39 months. Thanks.
    .00340 MF
    74%/65%/65%
  • BlzfanBlzfan Member Posts: 23
    Would you be able to share the latest RV and MF for a 2023 Macan for 10k/39 in 60062.
    Was really just curious if anything changed from the last post. If I read it correct it would be .00340 MF and 65%
    No changes
