Mystery car pix
1138613871389139113921482
  • stickguystickguy Member Posts: 54,530
    look how much space that spare tire took up.
  • tmarttmart Member Posts: 2,434
    That’s one fully packed 57 Chevy!
  • Lostwrench3Lostwrench3 Member Posts: 847
    Spare tire position countermeasure of driver's weight position.
  • fintailfintail Member Posts: 58,972
    Wirtschaftswunder:
    Several Bugs and a Benz.
  • explorerx4explorerx4 Member Posts: 21,220
    A couple of Ford Taunus(oval headlamps). Red BMW Isetta on the left. Quite a few Opel Rekord's.
  • laurasdadalaurasdada Member Posts: 5,332
    A lot of junk in that trunk...
    That Citroen thing in the middle is hilarious. .
    The funny little van is a DKW Schnellaster
  • bhill2bhill2 Member Posts: 2,649
    On a slow day you could have a drag race between the Citroen and the Isetta. It would have to be a very slow day, however.
  • ab348ab348 Member Posts: 20,837
    That should have been a character in one of the Cars movies. :p
  • andys120andys120 Member Posts: 23,689
    Chinatown, San Francisco>
    I’ll take the tu-tone 57 Ford.
    1961 Plymouth taxi.
    That taxi company is still in business, since 1928!
    1961 Plymouth taxi.
    Luckily for those with sensitive stomachs, the front end of the Plymouth isn't in the frame.
    Blue wagon is a 1961 Chevy (Kingswood?)
    edited August 2023
    Flattop>
    a 1960ish Cruising Vessell.
    1959.
    Yep a 59 Buick.
  • texasestexases Member Posts: 11,248
    bhill2 said:
    1961 Plymouth taxi.
    Aww, what's not to like?
    That is quite possibly the ugliest front end ever put on an y car! MoPar styling went from the best in '58-'59 to the worst in '60-'61. The pressures of annual styling changes led to some strange looks.
    The Fast Times car was a 60.
    "Six more payments, gentlemen, and this beautiful blue four-door luxury sedan is all mine"
    texases said:
    bhill2 said:
    1961 Plymouth taxi.
    Channeled by Lexus 55 years later.
  • MichaellMichaell Moderator Posts: 269,742
    I thought I read somewhere that Judge Reinhold bought that car after filming was completed.
  • tjc78tjc78 Member Posts: 17,647
    Gnarly! 😎
    -Enlargeable-
    Lots of iron visible in this one. I'll call out the white Jaguar coupe to the left bottom.
    Consensus at The Old Motor.com is that it's likely an XK-120 FHC.
    I think that's right. in front of it is a Mercury with those "flatiron" tailight housings ((1952/3?)
    Buffalo NY. 58 Ford two cars to the left of the Jaguar, 57 Ford to the left of the red Mercury.
    56 Ford wagon 2 cars to the right of the Jaguar, 55 Ford to the right of the wagon.
    59 Coupe DeVille driving on the street. I see no newer cars.
    2 tone blue rambler wagon up in the middle backed into a spot
    To the right of the Jag is a Pontiac, possibly a '53 but also could be a '54/'55'/'56.
    Directly to the right of the Caddy, in the parking lot, is a mint green two-door sedan (next to an older Buick) that looks to me like a 59 Plymouth. the rear end is hidden so I can't be sure. I too see no newer cars.
    Yep looks like a 59 Plymouth to me too.
    Ferrari 365GTB Daytona. A 70?
    Wonder if that one has a rear view mirror?
    That's a Eurospec early Daytona with the perspex headlight covers. Later ones and all USDM versions had popup headlights. The Borrani knock-off wire wheels were unusual too. Most had the 5-spoke alloys.
    edited August 2023
    Take a good look at the hood emblem before you call this one.>
  • kyfdxkyfdx Moderator Posts: 273,893
    Daimler?
    Daimler?
    It's the Daimler clone of the Jag Mk.2 sedan. Body and interiors were identical except for the fluting on the Daimler grille surround and the flying "D" in place of the leaping cat.
    Instead of the XK six the Daimler version used the same Daimler 2.5 litre V8 used in their SP-250 Sport.
    I'm not sure if any Daimler V8-250 Sedans were ever sold in the US. Daimler was a prestige name in the UK
    as it was once used by the Royal family.
    F registration suffix on the Daimler is for the second half of 1967 onward, assuming it has that plate from new, it is a final run car.
    A couple of Capri's in the background, silver and green.
    I'm having difficulty with this one. Anyone else working on it?
    Looks GM-ish, not so much Ford or Mopar
    The blue one reminds me of a 52-54 Ford. The white flat top is definitely GM.
    Not with that reverse-slant A-pillar.
    I am still stumped on that. The shape of the vent window is unusual.
    I'm putting my bet down on a 59 Chevy. From the single side spear it's either a Biscayne (sedan) or a Brookwood (wagon). Even then it seems to be missing the door part of the spear.
    BRAVO! bhill, BRAVO!
    Yes, and the close proximity of the key hole to the door handle is the clincher.
  • imidazol97imidazol97 Member Posts: 27,818
    Good sleuthing!
  • magnettemagnette Member Posts: 4,242
    edited August 2023
    Sorry - I've been missing from this site for ages.
    This one is somewhere Italy but I have no idea where or when it was taken - I just thought the two cars depicted would be of interest...
    ps - neither of them is a Fiat
    I think the SR code on both plates is Syracuse in Sicily
    On the way to the state fair, the other Syracuse:
