Visitor Agreement.
I don’t mess with springs under tension. I had someone out to replace it.
My opener is also on the way out so I’ll need to deal with that this week.
OK, just for you.
You said one spring so that tells me you have the older design with a spring above each side rail. Those are easy to replace. Just leave the door in the UP position and use the good spring as a guide for how to replace the broken one. Then CLOSE the door to see if it works.
Then put the door back in the UP position and replace the good spring. It’s a good idea to change in pairs because the one that didn’t break is well on its way.
You’ll save money and by the time you called “the guy” and he gets there you’ll be on your second 6 pack.
When the door is in the UP position there is very little tension on the spring. I doubt you’d have to pull the spring more than 8 inches, which is very easy to do, to get the S hook off of the metal link attached to the wire rope on the spring that’s not broken.
In the time it takes to explain this you could be done.
Again, when replacing side springs make sure the door is in the UP position.
Our beloved mutt (LabraHound; Bassador) turned 14 recently, actual birthdate unknown but he adopted us in 2010 when he was estimated to be one.
He still gets walks of 1-3+ miles a day and that still isn't enough for him.
It is also just about time when first insurance price increases finally pass through the state reviews (it takes some time to get them approved) after digesting the Surfside collapse by them. It is not exaggeration to say that if things continue this way parts of Florida may quickly approach New York City in terms of cost of living and the migration trend may actually reverse and flow into other states (Texas, No./So. Carolina, Georgia, etc), which have 30-40 years ahead of them before Florida's problems will show up. But our governor clearly has more important thing to do, like using power of his legislature to save our souls from eternal woke damnation. We clearly need that much more than keeping our homes...
2018 430i Gran Coupe
I never saw that type of installation before. Do you have a door that’s very heavy? It would be interesting to see if the door would still work if the torsion spring broke while the two side springs were still good.
They are very careful when they replace one. They stick a rod in a hole and turn the spring so many times. They put a chalk mark on it and wind it up. I don't know all the details. They always come and look at it and go back to the shop to get what they need. I assume there are different strength springs. I imagine if it let loose it would do a job on you.
If I was ever in the market for a condo, the reserves account is one of the first things I'd look at after the current monthly dues. I believe CA has a law that you can't increase the dues more than 20% per year, but of course, the way around that is a "Special Assessment."
Also lucky is that our 2.5 car garage has a regular access door to the side of the garage, so tech could go in and out easily as he worked. Otherwise he would have had to tramp through the house to get to the garage.
I replaced both springs. It's like bending a paper clip repeatedly to break it when these spring wind tight and relax. If one broke, the other will break as soon as the tech leaves the driveway if I only replaced one spring! Lol.
That looks like the standard installation for a torsion spring operated garage door.
I have a double door too and the spring on mine is about 3 inches in diameter and the pipe is about 1 inch in diameter.
There are different strength springs and the colored line on the spring designates the spring strength.
When the spring breaks the pipe contains the spring. Which as I understand it is better than relying on a 1/8 inch wire rope that passes through the center of the springs on the side mounted spring design.
The disadvantage of the torsion spring design is when the spring breaks. Most people ain’t gonna mess with that sucker whereas side springs are a piece of cake to replace.
And of course our opener failed this morning - I'm sure that's no coincidence.
I need to ask what the new house will have. Hopefully the torsion springs. That is going to be an 18’ single door so I assume plenty heavy! Need to also make sure they get. Heavy duty enough opener.
I put on torsion springs two changes ago. It's very simple when you consider the laws of physics. I had two
steel rods that fit into the holes on the flanges at the end of each spring. You loosen the nut that holds it to the rod. You start twisting the spring using one steel rod and then the other. Always be careful not to stand in front of where the steel rod would be thrown if you slipped in your process. Very simple. LOL
BTW the last two times I called "THE GUY" and let him do it. That was about 5 or7 years ago and then last summer.
It's so easy, your wife can do it.
I have seen that. Makes a lot of sense. The bar that the springs turn fits into the opener, like an axle going into a differential. No belt or chain.
I’m pretty sure I saw that type of garage door opener when @breld showed some pics of his 6 car garage a good while back after he moved in. Ask him to get you a few close ups and while you’re at it ask him how he likes it.
I don’t know anyone with that type of installation nor how much they cost.
I can’t get over (really I don’t believe it) that one of the subsequent videos showed a guy installing 2 torsion springs that he charged $1165.xx but then he gives a 10% discount. Whoopy, I don’t think I paid that much for my new double door installation about 10 years ago. The guy is actually a salesman trying to get you to sign up for his garage door training program so you can make a couple million dollars a year doing garage door repairs, yeah right.
In a way that’s kind of clever because I never saw a video do that before.
I don’t get all the hype about how quiet a garage door opener is. I care less about how quiet a garage door is than I do about how quiet my dishwasher is. But if that’s your thing go for it. Frankly, I want to know when my garage door is moving.
Our bedroom is above and behind the garage and you can hear it loud and clear.
My living room is above the garage. That room is rarely used (so glad the furniture gets to hear it. It cost enough so it should be able to do more than just sit there and look pretty).
A lot of homes today have very high garages with nothing above it other than space for storage. I wouldn’t mind a garage like that.
Ordered one last night. I have myQ for my other garage so I wanted to stick with that program. Getting a Chamberlain unit. Just one to make sure it works for me, then I’ll get the other.
Pet complaint.
Grub hub and uber eats delivery drivers parking in handicap spaces to pick up food at Chick Fil A.
That's along with some clearly capable folks with handicap parking mirror hangers, which likely belonged to a relative.
Do I start carrying an electric drill?
A couple weeks ago a Chem Tech or similar name lawn service parked in one.
I saw the same as a college student picked up food at Chick Fil A. I pointed out to him that he had parked in a handicap space. He said “I’m sorry”. I replied that he was both sorry and pathetic…
"What's the point of having a car you can't drive anywhere?".
They had set up some group outing to Milwaukee, about 90 miles away.
2 of the group have Tesla's but didn't want to drive because they thought they couldn't make the trip without a stop for charging.
Guessing range anxiety since any Tesla model should be able to go 250-300 miles, as far as I know.
2023 Tesla Model Y
260 to 330 mi battery-only
2022 Tesla Model 3
272 to 358 mi battery-onl
2023 Tesla Model S
320 to 405 mi battery-only
Let's say the guys have Teslas with a range of 300 miles. You should only charge them up to 80%, so that reduces the 300 to 240 miles. It shouldn't go below 5% charge that makes the range 225 miles. If you are using the heater, a/c, wipers, radio or if you get caught in a traffic jam that could easily cost 10% more....that is below 200 miles. You have to leave some charge for getting to a charging station and hope they have a working charger.
btw, Tesla over calculated their mileage figures too
A supercharger would take about an hour to charge the cars....but superchargers will probably degrade the battery if you use them too often.
It is easier and you'll have less anxiety if you go in an ICE car.
It would look something like this.
Charging to 80% is a good practice, but if you need the range charging to 100% once in awhile isn’t hurting anyone.
Ninety miles one way with 250+ miles on a charge wouldn’t bother me at. It’s not like there wouldn’t be several chargers along the way
We drove the new electric over 200 miles the first weekend without charging it.
As do many other things.
2013 LX 570 2016 LS 460
Sounds like someone didn’t want to drive.
I’m guessing they have discovered AI systems which post this nonsense everywhere for little cost to them.
