1310531063108311031113236
  • ab348ab348 Member Posts: 20,651
    I always liked the Triumph Stag. Glad I never owned one as I understand they are incredibly troublesome.
    A fellow I used to know restored a TR-6, spending a good amount on it but it turned out beautifully. Emboldened by that, a couple of years later he decided to take on a Stag. He had the original engine rebuilt at huge time and money cost, but he could afford it, and while that was going on the body and interior were being redone. Finally after a long time and lots of $$$ it went back into the car and promptly blew up, literally within a couple of months. It went for another rebuild with lots more time and money expended, at a different shop. By the time it went back in again, he was afraid to drive it very far. I've lost touch, so I don't know if he still has it or if he foisted it onto some other unsuspecting fool.
  • xwesxxwesx Member Posts: 17,970
    Speaking of bad noises... the front left wheel area of my Forester started making some noise last Sunday. Now, only six days later, it is REALLY making some noise! I have to guess it is either wheel bearing or CV joint in the axle, but both of these were just replaced last July, so I am feeling very angry about this failure....
  • cdnpinheadcdnpinhead Member Posts: 5,642
    Back in about '72 or '73 I was looking for a replacement for my wonderful (but worn out) '65 MGB. What I wanted was a roadster (two-seat with a drop top, for those who don't know) with independent rear suspension. Or I could (let's say pee) up a rope. The finalists were the TR6 and the 240Z. Well, those who have been paying attention know I ended up with the zed. Quite a few years later I got my first Miata, and the beat went on.
  • stickguystickguy Member Posts: 54,197
    You should yell at the mechanic that did the job for such poor workmanship.
  • corvettecorvette Member Posts: 11,677
    Better yet, take him to small claims court!
  • oldfarmer50oldfarmer50 Member Posts: 24,569
    Brake backing plate rubbing against something?
    Suing yourself, you have to win!
  • MichaellMichaell Moderator Posts: 268,007
    He didn't mention if his son did the work, or not....
    well, probably a minor, so same result.
    edited March 2024
    You guys are too funny. /sigh
    I might not be able to say anything about the mechanic's work, but I can certainly question his choice of parts!
    So, I thought may be I would just try the old move-the-wheel-back-and-forth trick to see if it might be the wheel bearing. And, with the car still on the ground, I could easily feel play in the bearing. Seriously! That thing must be about ready to come apart if I can feel it sitting on the ground. In. Sane.
  • jmonroe1jmonroe1 Member Posts: 9,730
    Whoa, feeling play without jacking it up means it has to be really bad. You’re lucky you were able to get it home. The good news is it wasn’t the CV joint.
    I’m sure you’re not buying that brand again. Although at that young age it could be covered under warranty.
    Oh, man. It was so bad. I pulled it apart this morning and am waiting for my wife to get home so I can run to the parts store and get a new hub assembly. The good news is that it was incredibly easy to remove because I had just installed it seven months prior! I unbolted it and just pulled it out with my hand. The bad news is that there's no bothering with warranty.
    I bought the original parts from RockAuto, and they're basically impossible to work with when something doesn't go as planned.
    @28firefighter - you’re asking here? :D
    I’m surprised you had a problem with RockAuto.
    Years ago when I still had my first Genny (‘09) my Son suggested that I go to RockAuto when I couldn’t find wipers at any of the local auto parts stores and I didn’t like the dealers price. They arrived pretty fast but they didn’t fit, so I called their customer service. The woman I spoke with apologized up and down and said they were going to credit my CC (and they did) but they were also going to send me the correct wipers at no charge. They showed up right away too but they also didn’t fit. I gave up and finally went to the dealer.
    Sounds like they don’t operate the same way anymore but then who does?
    So, I have an opportunity to pick up a 2017 Forester XT Touring with 55k miles. One owner. Meticulously maintained for about $19k. No eyesight option.
    It would be a 3rd car winter runabout now that we’re skiing almost every weekend with my son.
    Worth it?
    well, I am always off now on used car prices (living in the past I guess!) so while it seems pricey, maybe that is the going rate out there. But functionally, it sounds like the perfect solution to your problem.
  • 28firefighter28firefighter Member Posts: 9,939
    It’s not a problem, per se…
  • kyfdxkyfdx Moderator Posts: 271,618
    Didn't go for the high-end quartz, evidently? ;)
    Oh no. We did. By no means is this good timing. But since I know the car, figured I’d ask. Smarter choice would be doing winter tires for the Tesla.
    Hard to lose much with the Forester. If you decide to dump it, later.
    I can confirm that committing huge amounts of money puts a damper on car shopping. If we weren't building now, our recently received bonuses would have pushed me to go out looking at something nice. At least to browse!
    the house, and the pending list of wedding items (nuptials in August) that we agreed to cover. Anybody else rent out an entire school for a weekend lately?
    Don’t they have firehalls in your new hood?
    ...and the pending list of wedding items (nuptials in August) that we agreed to cover. Anybody else rent out an entire school for a weekend lately?
    I assume congrats are in order... Sorry about the hole in your wallet, that may leave a mark. ;)
  • qbrozenqbrozen Member Posts: 33,821
    Worth it?
    Market says yes.
    Personally, not for me. What would I get instead? No clue. If just 3 people with skis, probably something smaller and simpler.
    it is our son, and others are taking a much bigger hit. the school will also include the rehearsal dinner and really was not that bad.
    Like “marked” off the list of car buyers anytime soon.
    Worth it?
    If you know it was well maintained and with low milage the only question is if it’s worth the price. What do the guides like Edmunds TMV say?
    The only thing I know from recent experience is that the days of cheap bargains is over.
  • explorerx4explorerx4 Member Posts: 21,063
    You can tell he doesn't really want it, especially for ski trips.
    Needs something more bougie for the ski area. :p
  • roadburnerroadburner Member Posts: 18,580
    edited March 2024
    I took the C43 on an overnight getaway, keeping it in Comfort mode with the exception of the exhaust. The route consisted of fairy deserted two lanes, and I was able to keep it around 60-65 mph most of the time. It returned nearly 29 mpg. I have never owned a car that effectively fuses laid back cruising with superior performance capability. In many ways it reminds me of the 2007 B7 I drove to Fort Worth.
  • tifightertifighter Member Posts: 3,852
    Where are you going? Stevens or Snoqualmie?
    Worth it?
    Market says yes.
    Smaller than a Forester for three people?
    Even a Kei car can do that. My Wagon R carries 4 people, 2 dogs, and stuff for a day at the beach on the roof rack.
  • nyccarguynyccarguy Member Posts: 17,778
    Worth it?
    So you’ve obviously made up your mind that this is a good car, well maintained, and a fair price. I know you aren’t specifically looking for used 2017 Forester Turbos of this vintage, but how does the price compare to others in your market? You are mostly work from home & drive your son to school every day. I’m assuming you have an extra $19K in ye old bank account. How far away is the skiing from you? Is range with the Tesla an issue?
    @tifighter Snoqualmie and Crystal primarily.
    Decided to pass. The Tesla can and has been doing the job just fine and, if I really felt strongly, I could easily throw on a set of winter tires and wheels. Range isn’t an issue, space isn’t a huge issue, etc.
    edited March 2024
    I haven't had problems in the past. But, they have zero customer service now. They even say "in order to provide you with continuously low prices, we do not provide customer service." Or, something along those lines (paraphrasing).
    It's good to go now, though. Here's a little summary video, for those curious:
    https://www.youtube.com/watch?v=6Vqll5aZiig
    You’re lucky the spindle wasn’t destroyed. Did you count how many roller bearings fell out?
    Still a lot better than the CV joint. I’m sure you’re happy about that.
    I can't imagine that any bearings actually came out, as the unit didn't fall apart and it didn't have any clear openings on it. It just seemed like the bearings were starting to eat themselves, but wasn't so bad that it didn't still have hold of the internal race. If I had ignored it another week or two, though.... Who knows. Probably not good things.
    And, YES. I was quite glad that it wasn't the axle. I told my son the same thing. "The cost would have been about the same, but it is a lot more work to get the axle out than the hub assembly. At least, it is after only 15,000 miles!"
    @xwesx - great video, but you forgot to do the "like, share, and subscribe" self-promotion at the end.
    edited March 2024
    Which do y'all think would be more desirable here in the US?
    1. '98 Toyota Progres with ~55k miles. Good: RWD, 1JZ engine. Bad: automatic
    2. '98 Honda Torneo SiR-T with ~36k miles. Good: manual. Bad: FWD, hood replaced (but good inspection score so it must have been done right).
    I feel like the Honda fanboys would scramble for that, but RWD 1JZ is a compelling combo in sedan guise, even with the auto. Honda has lower miles but Toyo is in better condition. I guess the Toyo is like an IS250? While the Honda is an Accord, of course, but with the Si engine (F20B; 2.0 DOHC VTEC) and has a manual.
    I assume both are RHD.
    As much as we love our manuals, I'm not sure there is a big market for them, if folks have to learn to shift with their left hand. I'll admit having been tempted by a nice low-mileage (kilometer-age?) JDM import, but I cannot envision myself rowing my own gears while trying to navigate from the "wrong" seat.
    Therefore, I vote the Progres, as I suspect the market may be fractionally larger.
    I just did a quick google search. 2 completely different cars. That Progres looks like it is much bigger than the Torneo. The IS250 you are thinking about was the Toyota Altezza in Japan.
    Coming from someone who is constantly on the hunt for Honda parts from that era, I can tell you they are getting more and more difficult to find. Maybe F20B parts are more available, but it is tough to say no to a RWD 1JZ. Lots of parts & maintenance items.
    You make a compelling case for each. I suspect the Honda will be more desirable in terms of the audience size, but the Toyota will likely catch the eye of a few folks who know what you gotz!
  • ventureventure Member Posts: 3,200
    My sentiments exactly.
    Get them both.
    My wife would not support tying up $10k for a few months.
    Oh, I forgot to mention: yes, I know they are different types of vehicles. My MO is to click each manufacturer in the auction listings and then narrow to everything '99 or older with auction scores of 4+. That usually shows me less than 200 total listings a day. I quickly scan those for interesting things that aren't terribly expensive. I rarely come up with more than 3 I'd even try to bid on.
