Visitor Agreement.
1. Dust, Salt, Salt Air, High Humidity, long periods of heat, extended weather below freezing.
2. Driving intervals. I.E. Granny's style of driving of only short trips is murder on oil. Road miles vs City miles.
3. Engine Design.
4. Type of oil in the engine.
The best way to figure out the proper interval for your vehicle is to go a certain interval and send it in for oil analysis. Then go a longer interval and send it into the same lab so they can do a trend analysis.
The large issue in my opinion is how the Toyota engine design shears with the more modern oils in extended short trip driving. If I personally had a Toyota I would err on the conservative side and follow the dealer recommended interval to start out with.
I would probably also use Auto-RX annually just to clean out any residual slugging.
The only thing Toyota did to "remedy" the situation was to make valve cover drain holes larger. Not enough to convince me that their issue will go away.
Do I consider this a problem? Not if I'm purchasing a new vehicle. It's simply a weakness that you have to watch out for, like Ford and Chrysler transmissions that have to be babied. The oil changes have to be babied on a many Toyotas.
P.S.: No bad results, ever. Just silly anxiety!
I have one vehicle that works well on 75% syn 25% high mileage and that goes 6K.
You're not talking to an extended drain person here.
-David
But, I maintain 5 cars and it is too much of a hassle. So, I go anywhere from 5000-12,000 between changes depending on the car and type of driving. Two go a year (filter at 6 months (although 1 went a year on oil and filter) and analysis is fine. I do get that uncomfortable feeling at times but then I put a few drops of oil from the car in question on an aluminum foil type backing a let it dry. Amber color, no noticeable dirt or particles and I leave it in. But, oil analysis has also supported the drain intervals.
Maybe, that as far as Exxon-Mobil is concerned, this type of oil doesn't fit their in marketing plan. Then again, maybe they just want the old packaging off the shelves.
Enjoy your comments. Thanks for your interest.
-David
I am pushing the Mobil now in my SentraI';m 9K+ with one quart of makeup (15W-50 SuperSyn) when I changed the filter. It really didn't use any oil, I just Siphoned a quart out when the old filter went away. I'll sample at 10K when I change to who knows what-either Delvac 1 or Shaeffers Moly Pure Synthetic. I know-too much time on my hands.
About Redline and engine seals: My only long term experience was with a 1986 Harley-Davidson FXSTC I bought new and switched to Redline after the first 2000 break-in miles. I used Redline in it for eight years. It never leaked a drop! That's not an automotive equivalent, but close.
Now, tomorrow, I'll help a buddy (keep him company) changing the thermostat in his 205K Chevy Chevette.
First 15k miles, used conventional SJ oil. 15k-40k miles, used synthetic blend SJ oil (Castrol Syntec Blend or Valvoline Durablend). 40k-50k miles, used Mobil 1 Tri-Synth and Mobil conventional mix. 50k miles to present, used Mobil 1 Tri-Synth SJ.
I'd like to switch to Chevron Supreme or Citgo Supergard, both well-regarded SL oils. Can I safely switch at the next oil change, or should I ease gradually from one to the other? If so, how?
(no flaming from syn users please, not bashing synthetics here). I just can't imagine that easing into a different type will make any difference. But fleetwood should know about any pitfalls, he's actually done it.
1. This sounds wild and would love to see one up close. I'll have to ask some friends if they know of anyone with it.
2. I would think a good highway run of 10 miles or more each day would evaporate the moisture in the oil due to high operating temps.
3. As ADC says, the additive package depleting is more of an issue with 'spending' the oil than the actual cleanliness of the base oil, IMHO.
TB
You confirm what I've suspected about lubricating quality as opposed to cleanliness. I intend to keep Blackstone busy, especially during the first duration of use. I'm sure they can help me determine the safe extent of oil 'life'. Thanks for your comments.
malachy72 & caesarslegion
No, it's not the toilet paper filter. I remember seeing those things back in the 60's, usually in a booth at a county fair, between a booth on one side with a guy sawing an old boot in half with a serrated steak knife and on the other side a guy selling a carburetor attachment guaranteed to double your gas mileage. :-) I would never, ever, ever (read definetly not) put one of those things on my truck. It's almost a year old and I still baby it like it was new. You can check out the one I'm using at:
amsoil.com/products/bf.html (someone may kindly describe how to make a URL a hot link)
-David
If anyone is interested in Castrol Syntec 5W50 and how it holds up,well,check it out.I'd like to hear about it.Thanks
Ron
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=forum&f=3&submit=Go
Did they also lengthen the drain intervals?
Here is why I ask. If I recall, an oils viscosity increases with age and use.
So, from a viscosity point of view only, (I realize additives wear out, dirt is suspended, and so forth) you could run a 5W20 oil longer before it turned into peanut butter.
Not saying I'm planning to do this, but I was just curious if the drain intervals were lengthened.
TB
Who thinks 5W40 Delvac 1 or Rotella Syn is a good choice this winter for the 87 LeSabre.
By the way, Ford's 5W-20 is aware of this thickening issue, and requries for their 5W-20 specification that it have no more than 50% thickening for 120 hours under the oil thickening test. SL standard is 80 hours.
But I agree that a 50% thickening would leave a 30 weight oil.
My personal view would be to use a synthetic 5W-20 for the duration of the guarantee.
A point favoring this idea is the addition of STP to any and all weights of oil. The effect is to thicken the oil, and in recent years to add ZDDP as well.(:oß
I posted a copy somewhere on the forums at www.mpvclub.com if you would like to see what engines Ford approves/recommends use of 5W20 oil.
TB
But I have found better mileage if I use a mix of 5W-40, and 10W-40 rather than a 5W-50 and 5W-30. Just my experience on one vehicle.
Rando
