The reason for getting the Outback now, even though our daughter doesn't move to Ohio till August, was Subaru's 1.9 financing on the last of the 2024s. The 2025 Outbacks are already pouring into dealer lots, and since my wife wanted Crimson Pearl, a relatively rare color, it was clear that if we waited till August we would have lost out on the low interest rate, and that would cost about $2k in interest charges.
As an aside, the $1k a year gas savings with the Camry would have been wiped out for at least five years by the $2-3k above list the Toyota dealer wants to charge + the interest charges for a higher loan rate. So that argument for getting the Camry halfway died. Maybe by the end of the year Camrys will be plentiful and discounted, but we didn't want to wait that long.
Back to the Outback. Something that's been aggravating my wife lately is the proliferation of speed bumps on our local neighborhood roads. She's a slow driver, and so it's not that, it's just that she doesn't like being bumped so much even at slow speeds. The new Outback does help in dealing with what we've joked is the "Speed-Bump Industrial Complex" because of its soft suspension and comfort tires. The Outback is quite a bit more comfortable on those bumps than the CR-V and even my TLX
Speaking of tires, the Outback's seem good—Yokohama Ascend Grand Touring. Reading a few reviews the Yokohama GTs seem to be above average oem tires, with good performance in most situations. They aren't "Three Peak Mountain Snowflake" tires like our CrossClimate2s, but with Subaru's Symmetrical awd probably they are good enough for all our weather situations. The Ascend GTs are considered 65k tires, and so we'll probably keep them at least to 50k. I looked them up, and they cost $170 + installation each at our local tire dealer, but aren't available at Costco. Here's Tire Rack's 2-minute evaluation of the tire, which is mostly positive.
Quoted from an Outback forum: "The Subaru spark plug replacement interval is 60k because its engines use a waste spark system. The plug fires twice per cycle, which means 60k is equivalent to 120k on a regular engine."
https://en.wikipedia.org/wiki/Wasted_spark_system
"A wasted spark system is a type of ignition system used in some four-stroke cycle internal combustion engines. In a wasted spark system, the spark plugs fire in pairs, with one plug in a cylinder on its compression stroke and the other plug in a cylinder on its exhaust stroke. The extra spark during the exhaust stroke has no effect and is thus "wasted". This design halves the number of components necessary in a typical ignition system, while the extra spark, against much reduced dielectric resistance, barely impacts the lifespan of modern ignition components.[1] In a typical engine, it requires only about 2–3 kV to fire the cylinder on its exhaust stroke. The remaining coil energy is available to fire the spark plug in the cylinder on its compression stroke (typically about 8 to 12 kV).
Advantages
Perhaps the most significant advantage of the system, compared to a single coil and distributor systems, is that it eliminates the high-tension distributor.[2] This significantly improves reliability, since many problems with a conventional system are caused by the distributor being affected by dampness from rain or condensation, dirt accumulation, and degradation of insulating materials with time...."
I guess if people are willing to pay those mark ups the dealer has no incentive to change.
Doing price research on the Sportage, in anticipation of a possible purchase later today.
Dealer has 33 Sportage PHEVs on the lot, 14 of which are the X-Line trim. And, of those 14, 3 are the blue color that is the preference. MSRP is $41,140 on each of those three, with a $799 dealer handling charge, and a small upcharge to take their price to $43,179 (OK, only $1200 over MSRP, but still...).
Edmunds says TMV is $39,660; I figure I'd start at $39,200 (plus the $799) for an even $40K before trade in, taxes, etc.
Quick review on Edmunds (Carmax) tells me the MINI is worth $9400 in trade. I've saved that offer - which is good for a week - to use in negotiations with the Kia dealer. Probably should clean it out and get it cleaned up, inside and out.
Anything else I'm missing?
Benjamin, smart getting the outback instead of versing your wife into a sedan she really didn’t want. That rarely ends well and most likely you would be picking between the Camry and Acura soon to keep 1!
I also wouldn’t be without one utility vehicle of some kind (pickup, wagon or CUV). We often enough need the boxy capacity that it would be a hassle to not have it available. This week I had to pick up a bulky wine fridge at Lowe’s and it sat fine in the back of my truck. And would have laid down in the RDX. And would not have gotten into most of my sedans, if any. The 20 bags of mulch also worked better in a truck bed.
My wife also likes the higher driving position. She dislikes low cars. She also has only regularly driven a minivan or RDX since about 1995 so is certainly used to the view from up there.
Maybe a Carvana quote. Otherwise make it shiny and wear your Kevlar boxers.
Since charging is free and we don’t drive much I do not have a home charger (yet). Our car tops out at 300 miles at 100% charge.
At the superchargers (150KW) - 30% to 80% is a half hour. The last 20% takes another half hour.
Bradd.. big congrats!
In case you are carrying something, you can also wave your hand or elbow across the Subaru star logo on the back, and then the power tailgate will lift up.
Reviews of the new Camry commented on how all the materials for the back seat Camry doors are hard plastics, but the materials for the rear doors on the Outback are the same as the front, and have cushioned fabric and soft touch materials.
The power driver's seat is 10-way, instead of 8-way for the CR-V as well as my TLX. Surprisingly luxurious station wagon. The power with the standard engine is adequate for our needs, and mpgs seem good so far.
On a side note, we are not only Chronic Car Buyers but also Chronic Cat Adopters. Below is Odie, who is the fifth cat that one of our grown kids has literally rescued off various streets. Odie was a kitten wandering the streets of Columbus, Ohio, eight months ago, perhaps about to be run over, when some college friends of our daughter rescued him. They couldn't take him, and neither could she (already has a cat, who actually doesn't get along with Odie), and so we got the guy. He bonded with my wife right away, but at first he wouldn't let me pet him. After a month, however, he began to warm up to me, and shortly after that we became good friends.
I don't think it's something we'd ever use, but...who knows?
Another weird quirk of it is that one screen shows the oil temperature, and not in terms of cold, medium, or hot, but very specifically—151 degrees Fahrenheit, or whatever it is at that moment, and I'm sure it can be changed to Celsius/metric as well. We don't need to monitor our oil to that degree lol, and so we put instead the "widget" screen level (as Subaru calls) on to the temperature and weather where you are, with forecasts for 3 hours later, and also 6 hours.
The Blazer does that one better by integrating Google Assistant into the system. We have had great fun by asking it the wing speed of hummingbirds and who is favored to win the U.S. Open. I think we will enjoy that on a long road trip which we will be taking later this fall!
On the C43 I have engine oil temp, ATF temp and boost on the left of the speedometer/tachand on the right I have average speed, average mpg and range.
In both vehicles the guages readout the exact temperatures/pressures and are not buffered- unlike the useless gauges on modern BMWs.
The other day [my wife]caught me scanning wild eyed on the computer (as I tend to do for hours) looking at all sorts and brands of classic cars. She just finally says "why dont we just go and get a Challenger or a Charger since you want another car so bad and forget about going with some Toyota Rav4 or Camry or Honda CRV etc.... Now she has put all the pressure on me because I been trying to do the right thing here by going with a sensible / economic keeper daily driver and she is dangling the sports car thing in front of me again..... I have a feeling I will do the common sense thing
Currently the poor sod owns a 200k mile 2009 Accord and a 99k mile 2018 Accord.
I replied:
If your wife is in favor of buying an entertaining car over a soul-slaughtering appliance, then I say GO FOR IT! I've been blessed with a wife who has never attempted to curtail my automotive purchases and activities and I could not be more thankful. I know too many people whose spouses do their best to eradicate any interesting vehicles in their garage under the guise of practicality. A pox on them.
One page the RDX has that the Tiguan doesn't is the individual tire pressures. It's a good chance to check regularly and adjust as needed, which I have two that seem to lose a couple psi before the others.
Decided that retiring again is not what I want right now, think I'd go nuts really. I like the social interaction plus I do like to drive. But don't want to make any major changes right now so hoping to get the doctor's note releasing me to drive on Thursday and go from there. And will play it by ear then. I'll know soon enough if the dizziness comes back and if so, I'll turn in my keys, so to speak. But, it's got to be my decision here, mine & mine alone. I won't be a safety hazard to others or myself going forward. So, plan on keeping the Golf a bit longer and revisit things at the end of the year. It'll need an oil change/rotation come September which will probably get done. It'll be 10 years old come December and doubt it'll have 80K on the clock. As long as nothing needs to be fixed, will shoot for another year. Tires are in great shape though might have the brakes checked over since everything is still original. No longer trips are planned this year, wife has a couple of conferences in Orlando this summer and early fall, but I'm going to keep on working and see what happens.
Yesterday I got a mailer from the Kia dealer offering me a $500 discount just like in the old days. Then this morning the local multi line dealer was advertising $1750 off on any Hyundai on the lot. I’ve also heard radio ads offering $6k off on Silverado trucks.
Now of course these may just be the come ons to get you in the door where they can hit you with ADMs or bogus mandatory dealer installed options but it at least sounds encouraging.
Just look at how full the lots are. Seem to be back to relatively normal.
Helped my buddy pick up a BMW i5. Discounts are back! He’s down in NorCal and I was able to get him 14% dealer discount plus rebates and buy rate MF. He got a loaded up eDrive 40 with M performance professional and is thrilled - even has massaging seats.
Not the kind of BMW I want to drive, but he’s happy!
I see people talking to their phones or their cars and I just don't understand why my voice is apparently a dialect they can't decipher. But IMO they look dorky doing it so I take some comfort from that.
My Mustang has voice commands for various things but I got bored with it after a week and never used it again.
Happy Father's day! This looks like the ultimate cruiser. I saw it this morning at the Cadillac dealer.
I haven't seen this lot so full in years. They have a good selection of all models
I imagine Cadillac sales are not that great lately.
FINALLY got the correct brakes pads and compressor. Was able to button it up today. What a bear getting that compressor replaced. And, since I was under there, I crafted a replacement tray for the missing one. And took it for a spin. What a fantastic car to drive. I can’t understand how they make it feel so light.
I really think, if the Alfa fits me and meets expectations, I may sell the Charger.
That has to be Mrs. j talking. As long as her car starts, moves when it’s put in gear and gets her back and forth from the grocery store/mall, she’s all smiles. She doesn’t care what I buy for myself since she’s never going to drive it anyhow. The best part is, I didn’t even have to train her, she came wrapped up for me like that.
As for her general knowledge of cars she probably thinks a V6 is twice as big as a V3.
She does though care what I buy, because she has to ride in it. as long as she can get in and out OK and it is comfortable enough, then it is all up to me.
This place is HUGE, 22 acres per their web site (Norwin Elks Lodge No. 2313). My Son told me it starts at noon but you better get here early. We got here at 11:30 and drove around to find a parking. You name it and it’s here. Not too far from where we parked there was a 1953 Packard in the original color of light cream green. Last year they said they had 1400 cars. Almost all were show cars and it looks like that today too. I’m trying to convince myself it’s this BIG. Bigger than any car cruise I’ve ever attended. You gotta see it to believe it.
I’m debating on whether or not to have paint correction done on the convertible. There is some checking on the clear coat mainly on the trunk but I can see some blotchy spots in a few areas. I just wonder if it’s worth it and if I start down that road will I be tempted to put a new top on or do other “more than it’s worth” stuff.
My Son is in a small group of Holden owners, maybe 10 guys. One of the guys had/has 2 SS’s and he re-badged everything with Holden badges. No one else wants to do that, at least not yet. My Son jokes with the re-badged guy that he wants to keep his car original. Just like it came off the line.
Washing and polishing? Yup, did some of that today.
