A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Perhaps they have a dino 5W50 in Europe? I know they have 5W40 oils over there ... but I don't know if this is dino or synthetic.
Anyway, I don't want to drag Europe into it. They are so full of weird laws and regulations about this and that over there. I don't trust the way they tell everyone to use a wide-spread multi-vis oil and extend their drain intervals as much as they do. I think they are more concerned with motorists using another gallon of oil per year (and disposing of it afterword) than people properly taking care of their cars. Of course, once the car wears out prematurely ... it becomes another disposal problem. Typical, foolish, short-sighted thinking. <|^(
Anyway, the point is that at a given weight of oil, say 5W30, a dino will require more viscosity improver than a synthetic will to meet that standard. At 10W30, most synthetics use ZERO viscosity improver while dino oils probably still use quite a bit. Synthetics are more stable at both extremes of cold and heat and so naturally do a better job. >:^)
As for the ultra-thin stuff, I'm just as mistrustful of 5W20 oil as ever. If it were MY car, I'd use a 5W30 full synthetic and no one would ever know the difference. The 5W20 oils I've seen (Motorcraft, mostly) are all at least semi-synthetic.
Oh, and don't forget the additive package with those 40wt 'heavy duty' oils. They have more crucial anti-wear agents such as ZDDP that newer SJ/SL motor oil formulations lack. That alone could make up the difference in the amount of wear on those tests.
I think Chevron makes a Delo 400 5W30 (heavy duty) that would be a GREAT dead-dino oil to use! Actually it's a blend of normal dino and "iso-syn" which is a heavily isodewaxed/hydrocracked petroleum which some people (*cough* Castrol *cough*) believe is good enough to be called "synthetic".
--- Bror Jace
Thank you for your inquiry.
Most car manufacturers recommend 5W-30 or 10W-30 grades for normal
driving conditions. Improved engine technology with tighter piston ring
and cylinder wall tolerances allows the use of a lower-viscosity oil
without increasing oil consumption. (A "loose" engine - or one with
wide tolerances - allows too much oil to get past the piston rings and
into the combustion chamber, where the oil is burned along with
gasoline.)
We recommend that you follow the engine manufacturer's recommendations
as indicated in your owner's manual. For maximum low-temperature
performance and maximum fuel economy, use the lightest recommended oil
viscosity. Heavier oils can impede engine starting, lower fuel economy
and steal horse-power.
He he mentioned the same as the Mobil tech guy that the newer engine tolerances were closer and use of the 10W-30 could burn out valves.
Personally, if you use a synthetic, the molecules are uniform and smaller anyway. I don't think a synthetic 5W-30 would void a warrenty.
On oil weight and analysis. I've seen many well run oils in analysis and they are generally heavier than what was put in anyway. I think it would be difficult after the fact to determine what weight was entered just by analylsis.
These designations 5w 10w are within the context of petroleums and their respective flowability properties, which the API has established.
Dino's are just adequate oil's don't get me wrong they'll do the job fairly. Maybe this analogy may work. If we had the option to choose which medium music gets recorded 8 track, vynl or cd we usually opt for cd's given the new technology cd's are crisp digitally mastered thereby enhancing the music's listening quality. Given that one would not resort to listening to 8 track or vynl without an expressed purpose in mind.
CD's are the way to go yes by todays standards the old medium to record music were and are adequate yet we alway's are looking for better.
Oil technology has advanced to a superior height synthetics seemed to have reached that height. Petrol can't cut it by comparison, oh yes adequate and that is as far as they will go.
Todays engines run hotter at higher revs to get the most power while keeping emissions low and fuel economy high. These conditions are murder on oil. A given dino oil from 20 years ago would NOT properly lubricate some of the newest, high-RPM engines of today and might be iffy at best on the rest.
As for synthetic oils at start up, I think their lower coefficient of friction and greater natural viscosity makes it harder for their film to get completely wiped off a given engine surface the first times the motor turns over during a cold start up. So, they should provide at least some additional protection until the oil system gets up to speed.
--- Bror Jace
But I still must conclude that petroleum based oils are more than adequate for most vehicle uses.
I have used 10W30 in an older Accord with 160K miles. Unfortunately, after my last
oil change, 5W30 was put in. When cold, the car emits blue exhaust until it warms up.
Previously, with the 10W30, this car was pretty clean burning with no blue exhaust.
Has the addition of 5W30 hurt the engine in any way? I'm assuming that due to the age
and mileage, the engine is pretty "loose". Will it hurt if I run 5W30 for at least another week?
I plan to switch back to 10W30 soon to protect the environment and avoid the embaressment, however its a pain waiting in line for 30-40 minutes for another oil change within a week.
depending on the brand, i know synthetic 10w30 is capable of pumping at around -40 celcius.
imo, unless u live where i live (hint: see flag) your accord should be ok on 10w30.
So far, I don't see an improvement over the PAO stuff (both Mobil & Valvoline).
Mileage may have even decreased a smidgen ... but I blame that on going with Redline 10W30 as opposed to having just come off using Valvoline 5W30. Also, the Redline doesn't seem to thin out when it gets hot as much as the others.
But, that should mean it's protecting better. >:^)
Anyway, I'm gonna switch to Redline 5W30 after Thanksgiving.
--- Bror Jace
for an average compact or mid-sized passenger car, a brand name PAO synthetic (thats also easily available ..mobil1/valvoline) is more than adequate.
the fine print on the back of the valvoline synpower bottle states that it's suitable for extended drain intervals.
the only thing i cant figure out is why synpower 5w-30 didnt manage to meet ilsac gf-3 specs while 10w30 did.
both 5w30 and 10w30 meet API SL specs though.
something to think about ..
i live in ontario also. Mississauga to be exact. So we will probably see temperatures around
-20 etc. I usually put in 10W30, however this time I forgot to tell the attendant.
I thought that its pretty standard to put 10W30 in a car of this vintage. In any case,
it just smokes upon startup with the 5W30. Once running its fine. Its just a little annoying. However I dont really want to spend the time waiting + money, on another oil change.
However if the engine is not going to get runined by using this thinner oil....I guess I'll wait for a while.
PLEASE HELP
If you lose a quart of oil through start up smoking, there's no reason why you couldn't dump a quart of 10-30 or even 15-40 into the mix to get you through to the next oil change. I don't think the problem is anywhere bad enough so that you'd have to change your oil.
So, I'm switching back to a 5W30 oil ... still Redline ... and I'll see if I can get back those few MPGs ... of course I will have to wait until next summer ... and the components on my car will have aged another 15,000 miles in the interim making even an imperfect comparison difficult.
--- Bror Jace
whats the harm in using 5w30 all year round, since it has the same viscocity as 10w30 during summer and also has the added advantage of flowing better than a 10w30 during winter.
or as a matter of fact, why dont they standardize on 0w30 to be used all year round.
on my mazda protege, i change oil every 5 months according to mfr recommendations, and everytime i have to try and take a guess as to whether 10w30 or 5w30 would be most suitable for the temperature range within the coming 5 month period. this also means that i end up stocking both 5w30 and 10w30, and i'd really love it if that could be avoided.
I have a 2001 Mazda Protege LX 2.0 Liter. Mazda apparently recommends against the use of full synthetic.
The car just turned over 3000 mi. I originally changed the oil at 1600 mi from the factory shipped with Quaker State to Castrol 5w 30.
Should I run like half Reg. Castrol and half Castrol Syntec to get the right blend going?
Is Castrol OK, or should I go with another off the shelf brand?
Thanks in Advance
The oils have the same viscosity when engine is hot. Not the same as warm weather. At much higher temperature, something like 190F.
sdayalani: as yurakm said the first number is its 100 F. viscosity grade and the second is its 200 F viscosity grade (approx) the "W" means its tested for Winter conditions. In general the lower the first number the less protection is offered in hot coneditions. Also the greater the range between the two numbers the more viscosity enhancer "goo" needs to be added. This "goo" can break down. More "goo" is needed in conventional oils than syn. Thats why (in my opinion) 10W-30 syn is the way to go.
For me, I have changed my interval to every 4 months. I still like 10W-30 for the hot summer months and use 5W-30 for the rest of the year. If I were using pure synthetic I would use the 5W-30 since it is tougher.
In cold months it's a definite advantage. I had 2 4 cyl cars last winter, one with 10W-30, and the other with 5W-30. The lighter weight oil started much easier, and the engine during warm up was much smoother.
I put in a block heater last year, and that allowed me to start the car, scrape off the windows, and have real heat. Love them when it is below freezing.
my mazda dealer helps me put in AMSOIL 5w30+mobil1 filter in my engine. He does not refuse nor does he advise me not to do so...and he is a personal friend and biggest dealer in Philly.
but once the car went inside the service bay, god knows whether he actually poured mobil1 or ended up using dino pennzoil, thereby pocketing my mobil1 for his own personal consumption.
The latest: The '94 Corsica I gave to my daughter. After $1400 is hanging in there.
The '92 Corsica got back from her after about the same $$is also hanging in there. (complete with new heater hoses __&^(*(*%&^$). I'm thinking that the water pump at 130K miles is next to go (%$@#%$). I'm plannng on doing it myself (groan). I priced a new one (wish I could remember the brand) at a local autoparts dealer for $45 with a lifetime guarantee- that seems far to cheap. Do you have a recommendation for a brand (and place to obtain)?? It looks like an ugly job and I don't want to do it twice. Should I go with the GM OE??
New Sentra is good with the "Old Remanufactured" auto trans. Just kidding. I'm glad I listened to you on that one.
Take care,
Al
re. asking the dealer to give me the empty containers back, i'm sure he has a bunch of empty containers back there and might just pour my mobil1 into one of them and give me my empty ones back.
http://www.gmpartsdirect.com/
Just have to see how the truck likes it, I guess.
tom
