Late ‘50s Facel Vega, HK500?
The last version of the large FV with a non-fishbowl windshield, no fins on the back, and the big-block Chrysler V8 backed by a TorqueFlite was a really attractive car.
Here’s more information on the FV/FVS/HK500
https://en.m.wikipedia.org/wiki/Facel_Vega_FV
The other did a good job of classing up an Aspenlare:
This one's a bit early for me, late 1950s, but it's something I've never seen before. I also very much like the log buffet table.
Haystack Rock, Pacific City, OR. Pic expands for a better view.
A 56 Ford and two 58 Fords.
Far right an Edsel?
Hard to ID it exactly.
And at the far left in white/black/green a Nash Rambler 1957?
I imagine it is not very much fun to drive, but the mint green early-'50s Plymouth wagon would be considered a very sensible car back then.
@ab348 - are you referring to the wagon behind the Ford? Looks white on my screen, and I can't find a pic of an early '50s Plymouth wagon that matches.
Believe you’re confusing the white 58 Ford Fairlane , far right, for an Edsel.
When I looked for one without the split windshield the rear fender doesn’t look right.
The white sedan on far right is definitely a '58 Ford. Edsels had thinner tailights.
This is Leicester in about1956 and I think it might be the other side of the more famous car park which at this time was the undiscovered resting place for King Richard III
Should expand a bit
Morris Minor rightmost in front row, leftmost in front row Austin A70, Daimler Conquest beside that.
@texases
Most of our post WW2 was were either reheated pre-war models and the rest tended to resemble Jelly Moulds. (ie Austin A40 Somerset which is all curves like a Nash but smaller.
The nearest car in the foreground (LBC 253) is a Somerset and we had loads of those and even sold a number in North America
@fintail
The car to the right of the Daimler Conquest is a pre-war Morris - probably a Morris 14 hp
I think I see a few semi-obscured Morris Minors there.
Hi ab
The car registered ERC 341 is a Daimler Conquest and was registered in 1953/54
Daimler called it the Conquest because it was sold in the UK for £1066 (before tax)
1066 was the date of the Norman Conquest and is one of the few dates anyone in this country ever remembers from history class !
I think they were based in the Coventry area which is near Leicester.
The first small picture above is a Utilcon wagon probably based on a Commercial chassis
The second one is a Utilicon based on a Ford Chassis
in the second picture you canals see a Daimler Regency which was the larger predecessor of the Conquest. It's the car to the right of the "Dinky toy " van
and the 64ish Mopar in the center looks so modern compared to the late 50's Caddy and Imperial it is parked between. Like an entire generation newer, not just a few years.
Car to the right of the walkway, white, looks like a 62 Dodge, It's a Mad Mad Mad Mad World style.
