Visitor Agreement.
I don't think it's possible for a 13.2 gal tank to hold 15 gallons without making a big mess.
They say that gas is most dense in the morning, and in the afternoon (or when it gets warmer) the gas molecules expand. So maybe if you bought gas early in the morning, it expanded to make the tank stay full even when driving??? It still doesn't make sense to drive 170 miles without the gauge going down at all. I'm puzzled.
I saw a few posts on this. I have a 2003 Civic with 8,000 miles on it, and it doesn't start all the time. Everything lights up, but there is no cranking. I have had it in three times and Honda told me they can't find the problem, and it starts for them. Yet, I pick it up and about the third time I go to start it, it doesn't start. Any ideas?
I dunno about the immobilizer; easy enough to check by using just the key w/out the key chain.
Other than that, I'd look at the clutch interlock (manual) or the shift interlock (auto) that keeps the car from starting unless the clutch is depressed or the gear selector is in either "P" or "N".
Since it's intermittent, use the technique known in the field as "wiggling" to determine the source of the problem.
Let the clutch in and out a few times and really stomp on it, then start the car.
Or: Shift from Park to Drive and back a few times, or try to start the car in Neutral.
Good luck; let us know.
-Mathias
East Lansing, MI
As far as the suspension, there are kits out there, but most of them are to stiffen the ride. I am surprized that you think that your 2001 is too bumpy. I know that Honda re-worked the suspension for 2002 because the 2001 were too bouncy. Are you riding on stock wheels and tires? Check the pressure. It may be too high.
Also, someone said earlier about the "bumpy" suspension in the 02 EX. I think that what he/she was referring to was the bounciness of the suspension. I think this soft suspension instead of providing a smoother ride makes the car gyrate constantly on the most minor of road dips. A firmer suspension would have actually improved this tendancy reducing the queasyness. Unfortunately, the 02 hardly improved firmness over the 01 and it still bounces and floats more that any other small car. Just look at the back of any 01-03 Civic (any trim level) and you can see the excessive up and down movement, while other cars remain well controlled. Very visible.
When the car is in idle position at D4 if I switch of the engine I could feel the lack of engine power and if i don't accelarate a bir it dies.
If i switch off A/c and restart the engine it starts immediately. My mechanic has checked and says everything is ok.
The problem started only after i serviced my oil change and filter change, engine tune up, new battery etc...
Intially the engine was dying when i switch on the A/C now it has become the opposite what could be the reason.Pls help.Thanks
When we got into my 2003 Civic EX yesterday, my daughter noticed a gash in the rear seat upholstery about 2 inches long where the fabric appeared to have melted!
It's been hot the last couple of days here, but only in the mid 90s. I have noticed that the metal seat belt latches do get very hot when the car has been in the sun, so all I can figure is somehow one of them got hot enough to melt the fabric. This clearly not a cigarette burn (besides which, no one who would have been in the car smokes)- the melted area looks more like someone took a hot knife to the fabric!
Has anyone else had this experience? Certainly, you would think Honda would design fabrics that could withstand the kind of heat generated while sitting in normal summer sun - I live in the SF Bay Area, not Arizona, etc.
P.S. Do you think this would be covered by the warranty?
I have an '01 Civic EX and just two questions.
1. Has anyone else had a problem with *occasionally*, after you shut the car off and take the key out, you go and barely start pulling on the door handle to open the door when all the doors suddenly lock? They weren't locked before, and then I have to hit the unlock button to get out of the car. It's not a big deal to me, just want to make sure it's not a sign of something worse.
2. When I set the air control to "feet" or "ground", whatever that is called, I can still feel a lot of air coming from the upper vents. I figured that should only happen when it's set to upper/lower, and just upper. I know it's not the defroster vents, it's the actual dashboard vents and it's very annoying because it's quite a bit of air coming through! Anyone else have this problem?
Thanks so much! Still think this is the best car ever!!
Let me know if you hear any more.
2. When I set the air control to "feet" or "ground", whatever that is called, I can still feel a lot of air coming from the upper vents. I figured that should only happen when it's set to upper/lower, and just upper. I know it's not the defroster vents, it's the actual dashboard vents and it's very annoying because it's quite a bit of air coming through! Anyone else have this problem?>>>>>>>>>
1. Do you have either OEM or aftermarket alarm installled? The only similar experience is that when you hit "unlock" on the remote, but don't open any doors in 30 seconds they will automatically re-lock.
2. When you set the air flow to "feet" you should not get any air from the center vents. The side vents, by the windows, are not controlled by the air flow selector. They have a little wheel on them to cut the air flow.
I find the best setting is "bi-level" or "feet and face" the system will automatically direct warmer air to the feet and colder air to face in winter. I think when you have A/c on, the temperature is the same for "feet" and "face".
If anyone knows please respond.
I don't believe the service guy at Honda and I'm about to take the tires of my car to check the brakes.
As far as the brakes on 01HX, I think they are drum in the rear, and may not have a sensor, chekc with your manual. The tech may have suggested to change brake pads as they were nearing the level where the sensor would make noise, it could be also that they are tyring to make some money. If you are the original owner of the car then you would kno wif the brakes have been replaced before. If you bought it used, then previous owner may have replaced brake pads with ones with out sensors. No there is no light in the dash that would tell you the brake pad condition. The "Brakes" light is for the hydraulic system only, to alert you of broken hose or clog.
Thanks for the reply. Not sure what OEM is but I have just the factory made '01 Civic EX, no extras, no alarms, nothin'. We do have the keyless entry though. I am aware of the re-locking procedure for the doors but we just shut the car off, open the passenger door, then within 3 seconds go to open driver's door and before it opens, all the doors lock and I must manually unlock them so I can get out.
Definitely some good air coming out the side vents, too much. Shouldn't be more than a trickly coming out the top when set on floor. Maybe I should have them check this out. Scared for them to get too into it and mess something else up trying to fix this one!
Is this a problem many people have with the 2002 Civic, or is my suspension just shot? (I have approximately 25,700 miles on the car.)
I have a few earlier post here and haven't taken the time to review them or refresh "exact" facts from my maintenance log, so forgive me if I'm off by a few miles on some of the maintenance items.
This is a 2001 Civic EX coupe, manual 5 speed purchased new in either July or August of 2001. If color has any significance, it is Black hawk pearl.
I changed the tires from the Firestones to Michelin at about 6000 miles. I work for Michelin, so that decision was fairly easy. The tires that went on were stock size, "Michelin X Plus". This is a tire that is normally available at the large Discount stores. I put 80,000 miles on this set, still had plenty of tread left, but uniformity (balance, variation in radial forces, out of round, etc.) and wet traction were becoming an issue. I rotated the tires every 10,000 miles. They were replaced with the exact same tire at 86,000 miles.
I started experiencing some vibration issues in the 45,000 to 60,000 mile range. I finally diagnosed this as leaking front struts. The driver's side had just about leaked all of the oil out but the passenger's side was still pressurized, it had leaked very little if at all. I didn't look closely for oil on the top of the strut, my final determination of the problem was when slowly going over speed bumps, I would hear a strange noise, at the end close to a scraping sound. When changing them, the drivers side strut had leaked oil down the side of the housing.
I elected to go the cut and insert option using Koni struts inserts. I only did the front and have been pleased with the results, still running original stock struts on the rear. At the time (maybe now too, I haven't checked) Koni was one of the few options available other than Honda parts. I was leery of Honda struts, not certain they had the problem fixed.
I had used Honda maintenance for all of the service intervals up to that point. Before starting work on the struts, I purchased the factory maintenance manual and have done all the scheduled maintenance since the strut replacement.
Other than the struts, I have not had any other unscheduled maintenance.
I am still on the original front brakes, with about 1/4 inch of pad left. I haven't bothered to pull the hubs to check the rear brakes, based on experience with other cars, I expect the rear drums will last longer than the front disk brake pads, but remain attentive for any abnormal noises. I do downshift, but not aggressively. I row down through the gears, at a leisurely pace, slowly letting out the clutch in each gear.
I still average 35 to 37 MPG. My driving is mostly interstate with a round trip commute about 190 miles each day. The speed limit is 70 mph for the majority of the distance and I set the cruise at 76 mph.
I have the normal squeaks and rattles that most people report. The rear deck is rattling again, after 2 "repairs" under warranty by the dealer. It is fine on smooth roads but fairly noticeable on rough surface roads. Fixable, but it hasn't bothered me enough to tackle the job.
I have had a trim rattle since new around the sunroof interior trim. Again, only on rough surfaced roads. Probably an easy fix with screwdriver but I haven't bothered.
It seems like the doors and sunroof may be a little looser in their frames now. I mention this because I can hear some movement of the weather-stripping against the body as I go over bumps. Then again, a good spray of silicone may eliminate this.
The front end of the car has taken the most beating. The paint has been sandblasted, bugblasted and has a few dents from flying objects. I was not able to avoid a truck retread recently and ran over it down the center of the car. It pulled part of the rubber fairing under the front lip of the car loose and busted a couple of the plastic fasteners that hold the splash guards in place under the car. The only other damage was knocking a muffler hanger loose from it's support. No damage there, just replaced the hanger back on the support. All of this has been restored.
My next maintenance interval will be 105,000 miles. I am debating how much of the scheduled items I will do at that interval. I will probably pull the spark plugs and check them. I have no reason to believe they need replacing at this point due to smooth idle and gas mileage that is the same as new. I will probably wait until the coolant interval change to change the timing belt and water pump. Again, no reason to believe there are any issues here, but will pull the cover from the belt at 105K to check the condition.
When I purchased this car new, I needed a car that would give me good service for 5 years, in my case 250,000 miles. At the time, I thought this was the right car for the job and still believe this today. I have driven the car and cared for the car with that goal in mind.
This is not the perfect car for everyone. It is sporty in the coupe trim, but not a sports car. It drives and rides well. It rides better with groceries in the trunk than it does with me by myself. I'm not surprised at this. The last Honda I owned was a 1979 Civic wagon, that indeed rode like a wagon unless there was a load in the rear.
Remember, these are economy cars, depending on the trim level you choose, fairly nice economy cars. These cars are not for everyone, no car is. It meets my needs and hopefully will for some years to come. Should you pay the premium for one over the equivalent Hyundai, etc.? For me it made sense based on my goals and the reputation for quality that Honda has. If it takes me to 250,000 miles without a major maintenance incident, it has been worth it for me. If it makes it further, so much the better. Your needs may be different than mine, evaluate them and buy what you believe will meet them. At the same time, don't buy this car, turn it over to your teenager and expect the same results that I have had.
When you are close to your loan end, you get a thing in the mail suggesting that you should see your dealer about getting a new car. I am starting to think that all car manufacturers want is to have you buy a new car every 3 years or so.
Personally, I stick with the "severe" schedule in the manual when performing services on the vehicle. But in the back of my mind I always wonder if that is what "they" want you to do.
Dunno what you're thinking, but
Honda designed the car, and
they tested the car, and
they have a good idea, IMO, about what it takes to keep the car going smoothly.
So, following their recommendations about maintenance makes great sense.
20X$25.00=$500.00, 33x $25.00=$825.00
Good thing the car comes with a manual, owner's and tranny.
The 3,000 mile interval suggested by the dealer just puts more money in the dealer's pocket, as you noted.
