2024 Toyota Grand Highlander Lease Deals, Incentives, Rebates, and Prices
12345679»
  • MichaellMichaell Moderator Posts: 268,829
    Ajja said:
    Can you please provide the MF and residuals for Grand Highlander XLE AWD and LIMITED AWD for 12/36 (and 48) for zip 91950:
    .00249 MF
    65% and 63% residual
    Longer terms not supported.
  • manbeanmanbean Member Posts: 15
    Hi there and thank you for all of your guys' help here.
    Can you please help me with MF and residual on a Grand Highlander Hybrid XLE as well as a Grand Highlander Hybrid Limited with the following terms?
    36 mo/10k miles
    Zip 90048
    Also, are there any incentives? Of note, any loyalty?
    Much appreciated!
  • kyfdxkyfdx Moderator Posts: 272,621
    36 mo/10k miles
    Zip 90048
    Much appreciated!
    .00284 MF
    67%/65% residual for XLE/LTD
    For either 36 or 39 months
    No info on loyalty
  • Hello,
    What is the Residual/money factor for the G.highlander XLE and Limited?
    Any rebate?
  • 01905 area code
    Any rebate?
    01905 area code
    .00280 MF
    66% and 64% residual
  • marco_buffalomarco_buffalo Member Posts: 10
    Given the rate cut, is there any change yet on the MF/residual for 2024 Highlander Grand XLE Hybrid 36/39 months for 14214.
    Lease programs are not tied to the federal reserve actions - at least, not immediately.
    New programs will start in the new year.
  • hwesthwest Member Posts: 5
    Hi, what is the MF and RV for the GH Hybrid Max Platinum 36/10 in 22213 please?
    .00284 MF and 62% residual
    edited December 2024
    Hi there.
    Can you please help me with MF and residual on a Grand Highlander XLE as well as a Grand Highlander Limited with the following terms? (Both of these are for the all gas/non-hybrid versions.)
    36 mo/10k miles
    Zip 90048
    Much appreciated!
    manbean said:
    Hi there.
    Can you please help me with MF and residual on a Grand Highlander XLE as well as a Grand Highlander Limited with the following terms? (Both of these are for the gas/non-hybrid versions.)
    36 mo/10k miles
    Zip 90048
    Much appreciated!
    .00249 MF
    XLE: 66% residual
    LTD: 64% residual
    Sorry just 1 more follow up -- what would the residual be for the grand highlander platinum gas/non-hybrid?
    36 mo/10k miles
    Zip 90048
    Thank you so much again!
    36 mo/10k miles
    Zip 90048
    62% residual for Platinum
    Thanks so much!
    The dealer is claiming that their buy rate is supposedly 0.00280 for the gas Grand Highlander.
    They're marking this up, correct?
    manbean said:
    Thanks so much!
    If you have top tier credit, yes.
    Or, they are using a different bank - our numbers come from TFS.
    Extremely helpful and thank you both.
    And yes, they're supposedly saying that's their buy rate from TFS that's "Tier 1+".
    Hmm.
    Tier 1+ is only .00010 higher than Tier 1, which is what we quote.
    Rarely do we see Toyota dealers marking up the MF for extra profit, but yours could be the exception.
    .00280 is the base MF for the 2025 model.
    Toyota dealers rarely markup a subvented money factor. It's usually a communication issue.
  • gharezlakgharezlak Member Posts: 2
    Hi! Sorry you're getting virtually the same question from everyone with different zip codes, but could you please provide the 36/10 MF/RV for a 2024 Grand Highlander Limited gas/non-hybrid in zip 85255?
    .00280 MF and 64% residual
    Thank you so much! Big Two Toyota in Chandler tried to quote me .00290 MF but they changed it to .00280 because I had this answer :)
    Good deal!
  • tencarshoptencarshop Member Posts: 25
    Can you please provide the MF and residuals for gas Grand Highlander XLE AWD and LIMITED AWD for 36/10 or 36/7.5, for zip 98052?
    .00280 MF
    For either 36 or 39 months, 10K/yr
  • audikupaudikup Member Posts: 153
    Hello. Can you please provide mf and rv for 2024 Grand Highlander XLE AWD zip 80206? 36 and 39 months, 10k per year? Any incentives? Thanks,
    .00280 MF and 66% RV
    Either term
  • joshdubbyajoshdubbya Member Posts: 5
    edited January 2025
    thanks!
  • Rg17RgRg17Rg Member Posts: 4
    Can I please get the MF, residual, and any incentives for a 2024 Grand Highlander Limited, lease 36/12, in 29072? If possible, can I see it for 2x4 and AWD?
    .00295 MF and 57% residual
    Either drive
  • carinquisitor111carinquisitor111 Member Posts: 1
    Hi, looking for the MF and RV for a 2024 Toyota Grand Highlander XLE or Limited near 07653 for 36months 12000 mi.
    The supported lease programs for the 2024 GH have ended.
  • Yankee1234Yankee1234 Member Posts: 3
    Hello, can I please get the MF and RV for a 2024 Grand Highlander Hybrid MAX Limited AWD for 36/10 in 11230, Thank you
    .00304 MF and 63% RV
  • rob625rob625 Member Posts: 21
    Mony factor and residual for 2025 Grand Highlander hybrid platinum, zip 11530
    .00305 MF and 61% residual
