Chronic Car Buyers Anonymous
15354565859191
  • explorerx4explorerx4 Member Posts: 21,120
    edited March 2025
    Went for my walk this morning before the rain started and what did i see in a driveway?
    A Mazda 5 pretty much like the one on BAT, very nice condition.
  • corvettecorvette Member Posts: 11,736
    Those iX xDrive50s on Leashackr for $650-ish per month sure look tempting as an Ariya replacement, if they're still available at that price nine months from now.
  • kyfdxkyfdx Moderator Posts: 272,614
    That's a big jump up from $179/mo
    Have ridden in one at an auto show, and the iX is a big jump up from a Talltima.
  • jmonroe1jmonroe1 Member Posts: 9,824
    And from what you told us the other day, you’ll be able to afford it more easily.
    Good luck with both of those events.
  • nyccarguynyccarguy Member Posts: 17,827
    Got some positive news on the Prelude. The oil that was leaking was coming from the steel transmission cooler lines. The mechanic suggested I buy (4) new rubber hoses and (2) steel tubes. The problem is that the Honda dealer he gets parts from as well as the Advanced Auto Parts he deals with doesn't have any or can't get these. Same thing with the Blower Motor Resistor for the Air Conditioning.
    Not for him anymore. Maybe he should change his handle to Moneybags. B)
  • stickguystickguy Member Posts: 54,323
    I thought all the plants going in lately were in places like Alabama and SC because they were non union?
    Not even sure if they can find enough skilled workers for the relatively few jobs actually in factories now since most work is done by robots.
    If the leak is somewhere in the middle of the run, as opposed to the end where the fitting is, the tubing can be cut and spliced in with a new piece of suitable length tubing using 2 compression fittings (1 for each end of the new piece of tubing) that are rated for the correct pressure. Swagelok and Eastman make high quality tube compression fittings that will easily handle the pressure of the system.
    As for the resistor, if you know the resistance and wattage, an electrical supplier might have it but it will more than likely have a different mounting configuration.
  • ab348ab348 Member Posts: 20,715
    edited March 2025
    I would assume there are Prelude-specific forums online that might be helpful in sourcing parts that a dealer can’t/won’t bother to find? Blower resistors are a pretty common item needing replacement. A quick Google search revealed numerous choices.
    I doubt labor would be a concern. Even a skilled worker would need training for the specific modern systems in plants today.
    Got this today from the dealer in VA where I bought the MDX. Conquest or loyalty needed. Obviously excludes the usual variable costs but not a bad deal.
  • suydamsuydam Member Posts: 5,190
    At the time, getting 2 new cars in one year seemed kinda crazy (unless you’re breid). Now I’m glad I did.
    Depending on extra costs that is interesting. I might consider that.
    edited March 2025
    It's Virginia so the doc fee is or was in the neighborhood of $800 when I purchased from them and the temp tag was a nominal fee too. The rest were fees from PA. I don't know how this stacks against the brokers on LH but it has to at least be competitive.
    A lot of sales tax... All of the incentives are taxed upfront in PA.
  • sdasda Member Posts: 7,739
    Do you have a salvage yard that specializes in Hondas and Acuras? I got a TCS module that was no longer available thru Acura, and a used wheel from a similar yard. They guaranteed the TCS module as well.
    edited March 2025
    @28firefighter said:
    The TDI got a clean bill of health, but for the fact it needs both front and rear brakes. Wife wants to know if we could lease an SUV and avoid that expense.
    Why, my specialty.
    Did you mistakenly discuss this with Mrs @breld ?😎
    Isn’t the lease acquisition fee about the cost of TDI brakes?
  • 28firefighter28firefighter Member Posts: 9,953
    Audi quoted me $3600. Local Indy quoted $2400.
    Ouch. Expensive rotors and pads.
    VW GTI calling your name.
  • MichaellMichaell Moderator Posts: 268,706
    Pads and Rotors, front and back?
    Yikes.
    Front pads and rotors for the dear departed MINI were around $850.
  • tifightertifighter Member Posts: 3,866
    Also punch pending a test drive.
    Just got my popcorn…
    Funny how many vehicles are the best ever until they're not.
    Another reason why I continue to drive Toyotas;)-
    Hey, we traded in our CX-7 for the Outback to avoid the cost of the 60,000 mile service...
    edited March 2025
    +1 Pass the butter
    Highest parts price for 4 rotors, pads and sensors is $615 ish. Labor must be a killer
    https://www.fcpeuro.com/Audi-parts/Q5/Brake-Kit/?keywords=Brake&partial=true&year=2015&m=3099&e=3844&t=5&b=11&d=5029&v=
    There’s probably a specialized tool or computer they need to remove or reinstall.
    My SIL traded in an accord on a Volvo because it needed wiper blades and the cassette deck heads needed to be cleaned.
    carnaught said:
    The recent punch:
    2025 Hyundai Tucson Limited, Amazon gray, light gray soft leather. Impressed with the technology in this thing, the smooth 6 speed Turbo Hybrid lacking the CVT drone, the smoothness, zip to it, surround view camera, surprisingly good Bose audio and the Michelin Primacy tires. To our poster buddy who had Tucson remorse: “it ain’t your father’s” Tucson. So far I don’t know if it has a clown horn toot 🙄.
    Love it. My neighbor has the Tucson PHEV, fully loaded. It’s a very nice vehicle and looks sharp. I like the color too.
    If those prices aren’t enough to get you interested in doing your own disc brake work nothing will. I’ve said it at least a dozen times on these forms, changing disc brakes is a pretty simple job compared to the old drum brakes.
    Watch a few YouTube videos, then get to work and you’ll save yourself hundreds of dollars less than the indy shop.
    Labor is a killer, but most shops are also going to mark up the parts substantially.
    edited March 2025
    My Mustang GT is 34 years old.
    I'm going to get the brakes done for the first time in the next couple of months. :o
    And that’s if they can remove the caliper bolts without breaking them. You must be the only guy that gets 34 years out of rotors and pads.
  • anonymousposts2025anonymousposts2025 Member Posts: 44
    @nyccarguy said:
    This would be to replace your RAV4 Hybrid or in addition to the fleet?
    An addition. If we were to get rid of anything, it’d be the 14 Odyssey, but the kids are somewhat attached.
    Thanks to Trump / Musk, I’m on a hiatus from work and am actually driving again. The RAV4 is really the only good daily driver. Civic is too small and Odyssey is too much. Gee would prefer an EV. Pickings are slim if we eliminate Tesla. ZDX deal is appealing, but scared of the problems being reported on the Ultium group of EVs.
    edited March 2025
    @jmonroe1,
    Back when I was younger, I used to do what I have since then termed 'Google Earth Smoke Shows'.
    There was no Google at that time.
    I took this picture about 2 years ago.
    Notice on the right the original shock, muffler and tailpipe.
    For the record, you need an Audi computer to release the pistons. Not everyone has them and you can’t DIY
    Wow, that sounds high even from the indie garage. July 23, we had the front and rear brake pads and rotors replaced at the Audi dealer. It was less than $2k. I was expecting it to be around $1k. I was told because we had the upgraded 19 inch wheels, different rotors and pads were more expensive. I have an appointment on Monday 3/31 for service. The Q5 has just over 75k and drives great. I wonder what additional services they will say is needed.
    There has to be a way around that. Maybe an auto parts store can help with that.
  • roadburnerroadburner Member Posts: 18,614
    I can retract the rear pistons on a BMW with my Carly app. I'll have to pay extra to be able to use it on the C43.
    edited March 2025
    Audi has VagCom free app with a PC and a VagCom cable to retract the electronic parking brake. Otherwise was a straight forward rotor and pad job.
    You can actually disconnect the connector to the electronic parking brake and connect clips and 12 volt power and retract the rear pistons with no special tools.
  • au1994au1994 Member Posts: 3,803
    We’re WAITING…
  • graphicguygraphicguy Member Posts: 14,242
    carnaught said:
    The recent punch:
    Very nice! Congrats!
    carnaught said:
    The recent punch:
    That interior looks an awful like my stepdaughters Sportage Hybrid SX-Prestige.
    Love the light colored interior.
    carnaught said:
    The recent punch:
    And very different from both the Sportage and Tucson PHEVs. I like the light interior too. Hard to find nowadays!
    Hyundai does do stylish interiors with lots of features for the money.
  • oldfarmer50oldfarmer50 Member Posts: 24,628
    That kind of plays to the old joke that the time to trade is when the ash tray is full.😅
