That engine was also used in Saab cars of the late '60s after Saab's 2 cycle, 3 cylinder engine was dropped.
See site below......Richard
http://en.wikipedia.org/wiki/Ford_Taunus_V4_engine
I just had my 05 tinted and did some research before going to a tint shop. It turns out Honda had been using plastic where the windows rub on. The tint shop covered the plastic piece up with a scratch resistant fiber so the tint won't scratch. It cost extra but the alternative was that it would eventually scratch. I confirmed this with my dealer because I thought the tint shop was just selling me more stuff but it was confirmed by the service department. A tint shop that has worked with Hondas should know this by now....it probably doesn't help you since in 2003 they were just figuring this problem out. If they redo it again make sure they add something to cover up the plastic piece.
Thanks again!!
Gwen
I can't turn it off/on, but it will accept (and eject) cds, of course they won't play.
I have not altered the stock wiring harness at all.
Any thoughts??
*Driver's window has rattled since 1K miles. Now the passenger window rattles and creaks are coming from the rear windshield. The pesky noises drive me nuts!
*Rotors resurfaced at 19K (mostly hwy miles) under warranty.
*Brake pads replaced and rotors resurfaced again at 36K miles (I have never before had to replace brake pads on any car I've had or have rotors resurfaced, even up to 50K miles!) NOT under warranty, but the dealer split the cost w/me when I complained about never having these problems w/any other vehicle, especially a Honda.
*O2 sensor replaced at 42K miles (malfunction indicator lamp came on at 38K miles) NOT under warranty.
I called Honda Motor Corp. to complain about the O2 sensor failing just a few thousand miles outside the 3/36 warranty. Much to my surprise, they sent me a check to reimburse me for the entire amount - close to $300!
My husband also has a 4-cyl. '03 Accord EX, new in Oct. '03, and has had similar problems with the brakes. At 16K miles had to have rotors resurfaced (under warranty) and his CD changer quit working. Thankfully that was also covered under warranty - that would have run us about $1000.
After having 2 newly redesigned Accords, I'm not sure if I will get another brand spanking new Honda right after it rolls off the assembly line. I think I'll wait a few years until they work out the bugs.
I almost want to say it sounds like a speedometer cable vibration (sounds like its coming from behind the speedometer dial), but I'm not sure if modern cars even have one. I'm thinking maybe its a fuse or relay starting to go bad.
Vehicle is under extended warranty so I plan to have the dealer look at it, but wonder if anybody here is familiar with this problem. :confuse:
Many suspension components under your car are mounted in rubber. Over time, the rubber will wear which can cause more movement. When that happens, squeaks can start. Very rarely does that mean the car is unsafe, it just means the car is showing it's age.
Eventually you may want to have the car inspected just to make sure there isn't something more serious. Some of the major auto service places will do free inspections.
Now, can you put up with the noise without having it fixed is another question.
At any rate, what I have noticed on my new car is what I would call a "clunking" sound when either shifting into drive or the AT shifting from first to second. It only occurs once and only on a cold engine. (Usually after it has sat all day or all night.) I did notice a duller noise once after the car had sat about an hour. But nothing after the initial noise while driving or after short stops. Like a couple of other posters, I also had the impression that I could slightly "feel" it through the gas pedal, but frankly I'm not sure if that's my imagination or not. I can definitely hear it, however. Also, unlike one other poster, my noise does not sound like "grinding" but more of a clunk like something is loose.
At any rate, I have an appointment with my dealer. Will let the board know what they say. (Though replicating the problem, unless I leave it all night in the future, may be a challenge. I'm planning to let the car sit at the dealer for about 1 1/2 hours prior to my appointment.)
The dealer called and said the car is ready. The airbag light mysteriously turned off, they checked the sensors, they reset the computer codes. They had no acceptable explanation on why the airbag light came on in the first place or why it turned off. They did say that the driver's side bag was not operational when the light came on, however. That was indicated by their diagnostic computer. I go in with the service manager, demanding an explanation...that I didn't want a car back with a SAFETY problem that they couldn't diagnose or repair. Just because the light turned off doesn't mean the car is fixed. He acknowledged that the light MIGHT come back on again! He asked if we used a cell phone in the car! Well, yes, sometimes we have a cell phone with us, like the rest of America. He said that a cell phone can interfere with the air bag sensor/system, effectively turning off the system. Can you believe that? If that's true, SHAME ON HONDA and every '05 needs to be recalled! Can you imagine how many people might be out there with non-functioning airbags if this is the case? This is a SAFETY ISSUE!
Well, we pick up the car and the light turns on again, about 1-2 miles into our journey back. My cell phone is resting in the cupholder area, which is exactly the feature the Honda salesman pitched to us before we bought the car... plug in your charger in the 12V socket in the middle console, guide the wire out the specially-designed gap, and be on your way. What a crock.
So the car's back in service again. They're going to call "Honda Tech" this time. Well, they said that the first time. We've been without the car almost 1/3 of the time we've owned it. Less than 1K miles on it.
I'm complaining to Honda, the Honda Dealer, and any other state/fed agency I can find. This is not at all funny.
Have you tried this setting? Turn on AUTO, leave dual control off. Turn the temp knob all the way to LO. Do you feel the cold air blowing from driver side vent?
That's not a "Crunching, grinding noise". It is your Antilock Brake System (ABS) self-test. Your car will perform that self-test every morning within the first few seconds of slow driving. It is completely normal to the seventh generation (2003 and on) Accords.
P.S. How does the ABS system know when it's morning???
____________
ABS Grunts When Doing a Self-Check
Are owners of vehicles with a "compact" ABS complaining of hearing a short grunt or groan when backing or moving the vehicle forward after its been sitting awhile? It could just be the ABS doing its self-check. A compact ABS has a modulator, a pump, and an accumulator all rolled into one. (Later model vehicles don't even use an accumulator.) The system is designed to do a self-check when the vehicle reaches a speed of at least 7 mph either forward or backward after sitting. So the grunt is normal; it doesn't mean there's a problem with the ABS. On some models, you'll even feel a vibration through the brake and accelerator pedals when you hear the noise.
You can show your customer just how this ABS self-check works by connecting the Honda Diagnostic System (HDS) to the 16P data link connector, and running the ABS function test. (This test cycles the ABS solenoid and runs the ABS pump.) The noise from the test may be louder than the noise made by the actual ABS self-check, but it lets you customer hear the noise and helps you to determine if the noise is ABS-related or coming from another source.
___________
Even though the noise is "normal", I still feel like its a terrible system. Whatever happened to Honda being so concerned with the NVH (noise, vibration, and harshness) characteristics of their cars? I don't know about others on this forum, but I'm starting to wonder if Honda has lost a step or two? Their cars just don't seem to be as well made as they once were. Maybe its time to take another look at the American manufacturers.
Thanks to everyone who posted a reply.
REALLY HATE THESE LOW-QUALITY HONDA. :-(
Disappointed big-time,
ramida
Sad owner of a stuttering, horsey, weakling 03 Accord
But then again there IS the Malibu or G6 or even a Ford 500. I mean somebody has to buy them. Might as well be the people that can't stand the ABS self check in the Accord.
I've owned 3 7th gen Accords. Can't complain.
But just checking to see if Honda has any new TSB's or updates to fix the sunroof rattles that plague some of the accords on this board. Any info would be great. My patience with this noise maker is running out, 5th time to dealer for a fix.
Thanks in advance.
It would be nice (for once) for people posting to (a) search the archives to see if your question has come up and been answered (how many times has the ABS self-check been discussed?); and (b) once the question has been answered, not to continue on writing about how awful a car your Accord is and that you can't wait to get rid of it, even after problems have been remedied.
Nothing made by humans (which includes Hondas, so far as I know) is perfect. People are going to have problems with Hondas. Accept it. This board is for us to discuss solving those problems and relating experiences in that regard. But it has degenerated into such a Honda bash-fest that the value of the board is significantly diminished.
Any one out there with a "grunching" 4 cylinder ?
1. I did a self-diagnosis on my cold engine by removing the ABS fuses prior to start-up (#17  on my model).
- When I started the car and took a short test drive, the noise did NOT occur.
- When I repaced the fuses and took another short test drive, the noise DID occur.
2. I took my car to my Honda service department for my previously scheduled appointment (I let it set for more than a hour prior to the appointment) and had their specialist (who was very knowledgeable and helpful) go with me for a short test drive.
- The noise DID occur, and he confirmed that it was the ABS system doing an initial test of the system. (He also replicated an A/C compression "clunk" that regularly occurs on start-up if the A/C is on.)
-The specialist also explained WHY the ABS noise occurs (and why it didn't on prior generation Hondas or on many other types of cars), and it apparently has to do with the engineering specs that enable Honda to get a "lot of engine" into a very small space and the need to make everything very compact. He said this approach is what led to the transmission issues in earlier 7th generation Hondas, but that they fortunately have not seen these types of problems in the 2005s because Honda replaced/upgraded the most troublesome parts.
Hope this helps.
Anyway, live with it or leave it. That is the conclusion.
Finally I can pos
I am thinking of keeping it. Repainted and do the small repairs. I wouldn't mind to spend a thousand bucks ...I really like my car.
Do you guys think it is time to change or I should keep it?
I just changed the timing belts.... What else should I change at thispoint?
Thanks in advance....and thanks to Joe for the help!!!
Dry out the trunk, spreak newspaper under the area where the tail lights are. Turn on the hose or go through the car wash---check to see if the newspaper is wet just there and nowhere else.
As for "how much to spend"---your problem is that your car is 15 years old and getting rusted---so you have to get into cost control here.
Why don't you shop the classified and see how much a clean 1990 Honda can be purchased for? Maybe you are better off buying a really nice used one instead of sinking money into a rusted car, which really has very little value....or at least be very careful how much you spend on it.
I think $1,000 is just about the limit I would advise you to spend---if that makes it 100% safe and reliable, sure, okay, you can't buy much in a used car for that....but if it's more, you might be better off putting that $1,000 towards a cleaner older Honda car in the $3,000-$5,000 range.
