Heads-up observation! Engines aren't the only things subject to break-in. Brake pads "hone" themselves against the rotors for the first 200 miles or so, and maybe the material Honda uses is a tad "sticky" when new. Maybe that's what the issue is.
I'm an audio engineer. The sound system is VERY adequate. I look forward to "settling in" with this car. I am, however, troubled by the comments on potential brake problems. I'll definitely be paying attention to any "warning signs." I'm glad this discussion page is here to keep me informed.
I got the LX 4 CYLINDER. Thanks for the recommendation of "being smart" with "training" my brakes.
I would love to have gotten the alloy wheels and sunroof- none available, plus I was glad to save the money.
Question: is it a bad idea to downshift (auto transmission) when coming to a stop- to save on brake wear? I know it shouldn't be done all the time, but sometimes??
Personally, I don't believe it's a good idea. Repeated forced manual downshifting puts undue stress on the clutch disc packs and synchronizers in Honda automatics. (Internally, Honda automatics are more like manual transmissions than traditional automatics - think of Hondamatics as a hydraulically actuated manual transmission behind a torque converter and you won't be too far off.) New brake pads are much cheaper than a transmission rebuild (~$2,500.00!). My advice? If you're driving in steep mountainous terrain and don't wanna lose braking effectiveness to heat fade, shift to 3rd and leave it there for engine braking until you're out of the hills. Just remember to not allow the engine to rev past the tachometer's redline.
The EX with leather seats has power adjustments that move the seat all kind of ways, but my wife said the seat would not go as high as it would in the model with cloth seats.
I wish Honda makes seat memory available for the Accord like the 06TSX.
1. for such a powerful V6 sedan, pickup is fine but I could feel the hesitation betw. gears very easily. almost each time I need step on gas a little bit harder to get it going
2. upon a red light I moved my foot off the gas padal (to let the car slide), I would notice sudden (but subtle) slow-down. If I would watch RPM carefully, it actually went down then up in a split of secod...
Is it normal during break-in ?
This effect is normal In Hondas with automatic transmissions. What the seat of your pants is telling you is that, as the car slows during coasting, at some point the trannie will automatically downshift. (All automatics do this - it's just a bit more noticeable with Honda automatics.) That's the point at which you notice the revs briefly increase on the tach display. The brief, subtle, vehicle speed retarding effect is from related engine compression braking as the momentum of the car's mass forces the engine rev increase after the downshif.
those acid-based wheel cleaners that you spray on and rinse off, with
no problems. However, I remember others telling me that newer alloys
have delicate finishes that can be worn down with certain wheel
cleaners? Has anyone found this problem with their newer Accord alloys?
Both are petroleum distillates with solvent properties on many rubber compounds.
Just wanted to let you know that Accords come with ceramic brake pads, not metallic (confirmed by Honda Customer Service).
2005 Accords came with metallics, but you could request ceramics. At some point in the production cycle, ceramics became the standard equipment.
This may be the reason so many drivers report Accord's brakes as being touchy at first. The great part of this is that we won't need to worry about brake dust!!!
just thought I'd share this with everyone since I'm such a happy guy right now. almost spent 100 on ceramic pads but now I dont need to!!!
This looks great on tires it is a little pricey.
Sammy Castagna
The finish on the wheels keeps the dirt and brake dust from sticking.
You know, I think the Accord and Acura alloy wheels are beautiful. Much nicer than other cars I see.
The steering pinion seal needs some lubrication.
"i have the same problem as you in my 91 accord. but i have a bonus. on really hard turns at speed, my oil light comes on!! lol."
big problem today.
got into town and looked down at the dash finally, as i was on my cell phone speaking to my attorney about my recent custody battle, my check engine light was on.
ok.
then the car starts to bog down a bit at the light and the oil light starts to flash.
uh oh!
i look over at the temp gauge and its threw the roof.
oh no.
i parked and headed into work fearing the worse. so ill check it out further on my lunch break, so at least the motor will be cooled down by then. :surprise:
Initially the "squealer" tangs riveted to the brake pads to warn of wear will only sound off during braking. However, as the pad material additionally wears, the noise will become constant. None of this proves you need your front brake pads replaced yet, but if it were my car, I'd sure have a specialist check it out before assuming the noise is unrelated.
Not good. Check the engine oil level - I'm betting it'll barely register on the dipstick, if at all. Engine damage is swift and severe in the event oil pressure is lost and the engine isn't shut down immediately. Even if the sump proves to be full, or no more than a quart down, an oil pump failure would still cause the same symptoms. A third possibility is severe sludging of the oil galleries that finally caught up with you from extended oil changes and/or using the wrong type of oil. (By the way, oil not only lubricates, it's also responsible for nearly half the engine's cooling since there's virtually no direct coolant flow around the pistons, crankshaft, and main bearings.) Best of luck.
If you're stuck in the traffic long enough and the cooling fan is automatically turned on, you will experience the same thing. When the AC is on, the cooling fan is also on. The fan makes the MC hotter.
My 89LXi experiences the same thing when the cooling fan is on.
Allan
Sammy Castagna
You have a short circuit or crossed wires.
I just got my honda accord a month ago. I started driving it 3 days ago. Last night, while I was driving, I heard some loud lunk clunk noise on the front passenger side (sounds like there is something inside the door). Today, when I am going at high speed (60mph to 70mph), i heard it, but softer than last night and more consistant. Has anyone have this issue? Any advice on what could it be? This is my first time buying a Honda. I am a Toyota person. I had own two toyotas, & I never seen such a problem.
Ada
It's the passenger seatbelt metal insert-lock making contact with the vinyl side of the car!
ramida
