Visitor Agreement.
http://www.finishing.com/230/16.shtml
I'm new to this site and need some help. Every time I depress the clutch pedal, at around the threshold point, it makes a weird noise. Its kind of hard to describe the sound of the noise, but its like a tiny squeak. I checked the transmission fluid, checked to see if the clutch is slipping and nothing seems wrong except for this noise. It has only started today and the car is only a year old. Do you guys have any suggestions as to what is wrong with the clutch pedal and what is making that noise? Any help is appreciated. Thanks
Mrbill
Thanks for the information, I appreciate it.
Next time you have you car serviced, if it still squeaks, they can add some lube to quiet it down.
Mrbill
Rod
I had mentioned previously my fans werent working. After i changed the water pump they were both working fine. They would go on after i turn the car off too though... should it do that.?
I got through the trip and the car was ok for a couple of days. all the sudden im getting a strong vibration while im slowing down and coming to a stop. The car has now stalled out. It stalled when i was going to park, I stop, and it stalled. I tried it up and it was dropping and going off, unless i really gave it about 25-30k rpms. there was alot of smoke coming out when i got it going and it overheated over redline.
I dont know what it could be. I had to put about a half a jug of antifreeze before this last time whenit stalled. The thing is it really doesnt steam from the radiator and the fluid is bright green, im pretty sure it isnt mixing with the oil.
Any Suggestions...
Regarding the steering wheel radio controls, as with FM and AM, you can only change the XM presets from the wheel. You cannot scroll through all of the channels.
Clocks run off the car battery.
Mrbill
Sounds like a snow job to me!!!
Why do you say they need adjustment? Something the dealer just recommended?
Watch out, the next thing they will recommend is having your muffler bearings rebuilt.
Mrbill
I do recall looking at the setup months ago, and the springs have only a few notches for adjustment, which is probably there for tweaking the lid during assembly.
You might not want to have the lid open up all the way on it's own since it appears not to be designed that way. If it flies up too quickly, it may cause some type of damage after many cycles.
Mrbill
Geesh, what a maroon! Everyone knows muffler bearings are sealed for life and have to be replaced - which is generally done as a matter of course during a headlight aim adjustment . . .
(By the way, Hondas of your car's vintage (and perhaps current models, too) had/(have) their radiator fan relays wired directly to the unswitched "hot" side of the electrical circuit. The fans can and do come on when the engine is shut off if the engine's still warm enough, or temporarily spikes warm enough after shut off, to "trip" the thermostatic switch that activates the fans.)
Any suggestions????
My take is your head gasket around the coolant gallery is leaking which allows the coolant gets into the piston. That's why you saw white smoke at the tailpipe. If any one of the pistons is not firing, you experience engine vibration.
The oil hasn't got into the coolant because the gasket around the oil gallery hasn't leaked yet.
It's time to replace the head gasket.
My XM and fm/am work through the steering wheel controls. You need to setup the pre-set stations. Then cycle through it to find the station you want. I've become XM addicted by the way. Why don't you read the manual. Its very easy to figure out.
I think that may be what the owner was trying to get to work, and I myself wish was available.
Mrbill
at first the d4 light started flashing and check engine light came on. then speedometer stopped working. might have all happened at once...i was stuck in traffic so i couldn't tell. figured it was the speed sensor and was hoping to ignore it until i could afford to get it fixed.
a couple days later i couldn't get out of park without using the shift lock release. seems to drive fine but none of the gauges or indicator lights work. the power windows and clock aren't working either. when i open my door it starts beeping like when you leave the lights on. the break lights do work fortunately.
i checked all the fuses and #1 (interior fuse box) was blown. manual says 'back up lights/meter lights'. i replaced it but as soon as i started the car it blew again. i don't even have to put my foot on the brake or try to shift before it blows.
is there a way to unplug the gauge cluster without taking the dash apart to see if it's causing a short? how could this affect the shift lock? not sure how to tell if they're different issues or the same. since the brake lights work can i rule out the brake switch? only thing else i can think of is speed sensor (original problem) or maybe shift lock solenoid.
any thoughts will be greatly appreciated.
thanks.
mark
If and when your transmission does fail, and dealer noted something like "normal operating state" on the work order, there'd be strong grounds for a future goodwill repair.
Even if it has to be replaced now, and the kit hadn't been installed, imo you still have a case for goodwill repair because the transmission was under-engineered to start with.
With the V6 Accord's abnormal transmission failure rate, one can't be too careful.
Just want to know the exact position to put the string in.
Is it where the thin top edge of the glass window hit when closed?
My understanding is that the cross-section of the run channel is an inverted U, and it is the top of the inverted U, NOT the two sides.
Is it the foam tape (weather stripping, foam with sticky tape at the back) that you used?
I have enough with this too in my 2004
Thanks a lot
TTB
Bob
The length goes from the side mirror to the upper corner.
The one I used doesn't have stick tape on the back.
Don't use tape or glue when you put the foam inside the run channel. In case you make a mistake cutting the string too narrow/thin, you can take it out easily.
If the timing belt hasn't been changed, it's time to do a complete timing belt job (all belts, water pump, and oil seals). Call a couple dealers to give your the estimates.
The difference could be in a hundred dealer from dealer.
