Visitor Agreement.
Mrbill
Sooooo, we're to be happy now that they've lowered it to $2.00?
You just got took if that was their reason to replace them.
Mrbill
If not, I just drive until you hear a wear-out indicating sound. Then I replace both the rotors & pads.
Does anybody know any solution to this? Is there any way I can install the other speakers? How much it may cost me? Would have been better to get the LX with 6 speakers and pay 2K more to avoid this problem? Ane help I will appreciate.
Thank you,
kansas4451
I called crutchfield after I read you message. They don't have in their system the 2006 VP, they had the DX,LX and EX. So he wasn't sure what to tell me. Maybe I'll try HH Greg or Best Buy.
About your question, in the back there are 2 6x9 openings below the grids where the sound it's supposed to come into the car. I don't know if I'm explaining this very well.
Thanks for your help.
What's called "city driving" is so inaccurate, so unpredictable, and varies so much, including a driver's personal driving habits -- that I wouldn't rely on it at all.
And btw, "a little over 20 mpg" is not that outrageous to make you worry anyhow...
Has anyone else noticed this problem?
Have any dealerships found a fix for you?
Joe
(Some owner's manuals suggest the glycerine treatment once a year to keep molded foam door seals soft and pliable, too.)
The sun visor is made to set in the clips when it is forward on the windshield, which means it is not extended. If it is extended and brought to the regular position, then it will interfere with the rear-view mirror...any type. I have the auto-dimming mirror and experience no problems when the driver's side sun visor is latched on the roof mount correctly.
In the interim, we should have a gasguzzling Federal tax of at least $1,000 a year for those Autos/SUVs/Pickups that cannot even manage an EPA number of 20MPG on the highway. If the vehicle is proveable to be used for busines, the the tax would be forgiven.
In addition, to curb excessive gas usage, speeding fines need to be drastically increased; for example, being caught going over 100MPH should result in a 10,000 dollar fine and permanent revocation of a driver's license.
The only way that would make any sense is if all cars got the same mileage. If there are cars like the 300C SRT-8 that can't get rated at over 20 mpg under any circustances, why should I get a ticket for driving my Accord faster. Even at 100 mph the Accord will top 30 mpg making that "speed penalty in the sake of efficiency" moot. The SRT-8 driver should be ticketed every time he/she starts the car. Not to mention any Italian supercar driver.
Now that I have programmed my defrost to be able to turn off my A/C, how do I go about resetting it to factory setting (original setting)?
I just got my first oil change and my mechanic rotated the tires. He said he filled the tires up to 34 psi on each tire. Is this what the tire pressure should be at? I am really hoping for improved mileage! I also made sure that he replaced the drain plug washer when he changed the oil.
Thanks everyone for your help.
Lea
Raising the pressure may give you a slight increase in gas milage, (I doubt you could really measure it) but with the higher pressure, your car will ride rougher, and you might not be able to stop as quick. This is because using a higher then recommended pressure alters the tire's contact area to the road, and Honda is the best source to decide what it should be.
Don't worry about the drain plug washer, I have an 88 Accord, and I think I replaced it only once during the 50 or so oil changes I did on it.
Mrbill
The problem was not the transmission but the DISTRIBUTOR and another smaller element that's attached to the outside of the distributor box, forgot the name. Once both were replaced -- everything went back to normal.
Honda actually reimbsed me for the repair, part of the major recall for my model.
Why were you so worried about the oil drain plug washer? I usually changed them after 3-4 oil changes but it's not that big of a deal. The main concern it over tightening and ruining the threads on the oil pan. Doubt that will occur. Granted, it's only 69 cents or so but...
It's not terribly critical if caution is used when tightening the plug but for the small amount of moey they cost, I would replace them as Honda reccommends.
I've noticed that the AC compressor cycles on occasionally while I have the heater on, with the ventilation system set to the position where all the air flow goes to the bottom vents (floor position). I understand the logic in having the AC come during defrost. But what's the point of having it come on with the heat directed at the floor?
Steve
BTW, the other item attached to the Distributor might have been the "speed sensor", but I am not sure.
You haven't mentioned your car's odometer reading. However, it could be several things:
The car may need a major tune up.
Air filter could be too dirty.
The transmission may not shift to overdrive. Or maybe YOU shift it to D3 instead of D? Check the RPM at high speed... 4,500 RPM at 65-70 mph means the tranny is stuck at 3rd gear, wasting gas.... At that speed it should ran around 2,500-3,000 RPM.
Check your tires' pressure. Higher pressure (addtl. 3-4 PSI) than offically marked would get you better mileage.
Please come back with your findings.
is it repairable? and is there anything else i should look at? the engine SEEMS OK. my friend was telling me something about check the alignment to see (blah blah blah) kinda didnt understand him lol. but the steering wheel is a little to the right, but not much. any suggestions or tips that i should look at for that car?
Is a security system worthwhile, or is the standard Honda security that comes with the car (not the optional one) sufficient?
Do you recommend Honda's unit or another brand of security system?
Does anyone have experience self-installing a security system? How difficult is it? The folks at H and A - Accessories sell a Honda unit for self installation.
FYI, I had two cars (one was the Accord) parked in my unlighted driveway along side of my house. I cannot see the driveway from my bedroom window. One night last week while I was home sleeping, thieves stole a Kenwood radio/CD from one of the cars. (The car was unlocked, but it was my driveway, for Pete's sake!) I have Honda's alloy wheels on the Accord, and I am afraid I may get another visit from those guys.
Mrbill
