Visitor Agreement.
"..(1) Remove the fright front air vent using a thin flat screwdriver with making tape wrapped around the blade end and insert it between the air vent and dash board at approximately the 4 O'clock position and pry some out (the entire air vent should come out rather easy). When removed you will note a black lever extending from the wheel location to the rear air vane. Carefully pry this lever (rod) off and insert a very thin piece of felt between the portions of the lever (rod) and the hooking assembly. The felt must be thin enough so that the rod can be snapped back in place. The entire air vent can then be easily snapped back into place..."
I never tried it. If your car is on warranty just take it to the dealer. I just turn up the volume on the radio.
Batteries seem to be more and more mystical these days. I had a Taurus a decade ago that would not start, it wouldn't even turn over at all. The lights burned bright and the windows went up and down fine, the seats went up and down etc, so I was sure the problem was not the battery (it was only 3 years old to boot). The guy comes to tow the car, and first thing he says is "its yer battry boy". I explained that there was plenty of juice to no avail. He tried to jump start and that didn't work. Got the car to the Ford dealer, and sure enough it was the battery. I am ashamed to admit that in a moment of anger towards Ford batteries, I went to Sears and bought a diehard and installed it myself while the car was still at the Ford dealer.
1. Got the two screws out underneath the radio and was able to get the black molding out of the way. However, I am missing something (probably just a clip that I was afraid I might break if I was wrong) that is connecting the right side of the console with the left side of the lower dash panel. It is out of the way enough to where I was able get the 3 screws out from underneath the dash and the one screw in the middle below that.
2. When I try to lift and jiggle the glove box out of the dash something on the left side of the glove box is still connected to something and preventing it from coming out. Had to quit last night when I lost my patience and started to jerk the damn thing out.
Sure would appreciate any help from anyone that has gone through this process. It was really easy until I got to this point.
Can anyone give me pointers on how to remove the radio/cd player from a 97 SE?
TIA.
I have a HONDA ACCORD EX 4 cyl 2001 with 11200 miles. I usually drive in Northern Virginia area, 1000 miles per month.
5000 miles = First oil change
8000 miles = 2nd oil-change + tires rotated
1) What maintenance cycle should I use for oil-change ? My maintenance manual says 3750 miles.
Or Should I change oils every 3000 miles ?
2) What about any other maintenance schedules ?
Should I get the 15000 miles service from my Honda dealer or any other local Goodyear service center ?
3) Any other TSBs I should care about for 2001 Accord EX.
Harry
hbund216: Thanks for typing out the rattle fix! I marked it for future reference. I probably will have the dealer fix it, but sometimes it's such a hassle.
SC
The clunk has nothing to do with CV joints. In 2000 Honda changed the specs on one of the intenal components of the trannies on their V6 cars and minivan. That change resulted in premature tranny failure. Many people reported the failure shortly after buying the car, in which case Honda replaced the tranny with a USED rebuilt one. Why? because all the new ones had that same problem. They actually blamed their parts supplier for the problem, but who knows?
I would ask my dealer to replace the tranny if I were you. With 6k miles left the warranty will be over soon, and next time you visit the dealer they will tell you that you need a new tranny.
When you say "the center glove box", you mean under the box under the armrest, right? I'll start there and see where it leads me. Thanks again!
My tranny has performed very well and I'm not a slow driver. And my moon roof only rattles when its open while I'm driving on a dirt/uneven road. Then again, I made very sure my car was produced during one of the last production line runs of 1998. Never buy any car in the beginning of a production run.
Question: I still have the original battery and am wondering when I should replace it. The little light is still green, but I don't want to wait until the last minute.
And oh yes, the air conditioner filter. I'm totally amazed that we're got to remove half of the front dash to get to it. Why, why did they design it that way?
1. car manufacutured in Aug. 1999.(not 2000)
2. tranny problems had to do with clunking AFTER starting to roll in reverse. A loud banging I believe.
3. I'll tell my dealer you said I need a new tranny.
4. Got 7y/100k warranty so no real hurry.
Thanks for your insight. Guess I need to go the Daewhat board and repay the favor.
Guess the long predicted demise of Daewoo has made you even more bitter than before?
Second problem, annoying creaking sound coming from driver's side door jam. This one is much more difficult to pin-point, just wondering if anyone else is having this problem.
Thanks in advance.
Try coating a paper towel or rag with silicone spray, and go over all of the rubber door seals with it. This may cure your creaking noises.
Bullethp: 20mpg? Too low. My '98 EX V6 gets between 24 to 27.5mpg on my daily commute depending upon traffic conditions. Also, I haven't heard any creaking sounds (yet).
Refer to my earlier posts about the Brake problem. I took the car to the dealership and they diagnosed it as air in the system. They bled the system and now the brakes feel fine, they just have around 1 inch free play. This is inspite of the fact that my old mechanic told me that he had bled the system twice. Is there something I can do about that?
Thanks everyone esp. Auburn for the advise.
As far as the advise about the timing belt, all I want to say is that I am a student and due to financial reasons, it will have to wait.
I am wondering how much free play is normal for the brakes ? I recently drove an Olds Alero and it has like 0 inches of free play in the brake pedal.
My second question is rather tame, when you check the engine oil, should the engine have been running or should you check it like the first thing in the morning ? When I checked it in the morning, it was exactly in the middle of the 2 spots where as when I checked it after driving around for a mile, it was just touching the lower spot.
Thanks in advance.
Running the a/c hard.
Cold weather starts.
Sunroof open (hey, it affects the aerodynamics)
Windows open (ditto)
How long is your commute (short will probably give less mpg's)
Night time driving - headlights on.
Personal driving style - most days, I'm pretty mellow and am not racing from light to light.
Tires not to proper inflation.
"Boutique" oxygenated fuel - supposedly doesn't give the mileage that non-oxygenated does.
I keep pretty meticulous records...in the 34,000+ miles driven, we're averaging 24.4 mpg. The best mileage run I personally had was 34.6, all highway, filling up just before getting on the interstate and refilling when I got off (no suburban or city driving). This beats the EPA mileage estimate for highway driving.
I have been as low as 15 (cold, cold winter, lots of idling) up to that almost 35 mpg. I get my best mileage in the spring and fall when the weather is cool enough that the a/c is off, the windows are still up and the moonroof is closed, but not so cold that the car takes long to warm up.
I have about 3 gallons of fuel left when the fuel light comes on, at about 350 miles since the last fill.
Fuel economy-wise, our Accord has been great.
YMM truly V...:->
Any suggestions on which oil and filter to use on a 92 Accord auto with 102k miles? Its been more than 3 months since I changed it and even though I have driven it for only 1800 miles, I am planning to get the oil changed.
Am I doing it right?
I tried shifting to neutral before slowing down and I did not notice the noise. I have not yet tried the method you described, but I will. I've also heard that mild acceleration while driving in a tight circle could show if there is problem with outer joints. Am going to try that also.
My car has been averaging 26.7 mpg city/suburban driving. 135K.
Flashing lights? 'About' 2 gallons left in the tank?????
You are never going to know what your actual milage is.
2.Air conditioner barely works ok for here in Washington state. Can't imagine it being adequete
done south. Does anyone know how many degrees the
a/c should cool under ouside ambient temp?
3.Backing up a fairly steep but short driveway you can smell the clutch. Doesn't happen going up in 1st gear. Does something need to be adjusted? Also unless you really mash the clutch down car won't start. Possibly related? Also mileage pretty poor but I don't drive this car much.
Thanx for any advise.
