Did the problem come on suddenly after you used the stop leak, or was it a slow developing problem? Give us a few more clues.
The owner's manual does not address the fuel filter but my Haynes repair manual recommends replacing the fuel filter every 30K.
Well???? Ok.
1. Dealer's service departments make money on repairs, have I actually found an honest one?
2. The service advisor doesn't know what he is talking about.
3. The filter is in such a difficult place that Honda is embarrassed at what they charge to replace it.
All filters collect dirt and dirt stays in a filter until it is replaced or cleaned. So does anyone have experience with the Honda fuel filter? I replace them on every other manufacturer's car.
Best Regards
Bill
I would be careful with that shop; the service advisor is clearly mistaken on a simple maintenance item that he should be familiar with.
The question was for the model year 1995. The year runs were 94-97. Therefore it is likely that Honda changed the filter for the 98 and later model years. That explains why your 2000 is different. I have a Haynes repair manual for the 94-97 that is available at auto parts stores and references the change at 30K. Maybe the repair manual for your model does not recommend it.It sounds like Spokane was referencing a Honda shop manual? for 94-97. I looking for some actual owners with these year models who have delt with the replacement. I am interested if Honda and Haynes are on the same recommendation.
Does anybody have any ideas?
When I shut off the fan the noise goes away. The squeaking seems to be triggered by road vibrations, though I haven't had the car long enough to test it and see if it happens when the car is idle or if it happens at faster fan speeds--I didn't hear it when I first looked at the car.
I'm wondering if the bearings are starting to fail since the noise goes away when I turn the fan off. Anybody else dealt with this?
The only symptom I have noticed at times when it doesn't work, is that I hear a slight clicking sound coming from my driver side door when I press the button. It almost sounds like a bad relay switch or something like that.
I know that this is an old car and I normally wouldn't worry about it, but I am about to trade this in towards a new Odyssey. Just curious to see if this a known problem, or better yet, an easy one to fix!
Thanks in advance for any helpful information!
Get it checked out. Who knows?
Also is it common for the transmission to hesitate when you accelerate moderately after slowing down. The engine revs up for a second and shifts into the lower gear. Please tell me this is OKAY or Is my Tranny giving way???
i'll post again once i get some answers from the dealer. in the mean time, maybe some experienced drivers want to tell me what's probably wrong? appreciate it.
http://www.thecarconnection.com/index.asp?article=4942
15,000 miles service took $130 out of my pocket, not very bad i think.
We have a "mass merchant" and a large chain muffler shop that loves to reccommend these, however. We probably replace one set a year and that's usually at the customer's insistance.
i still like honda products better than all the other brands but G35 and BMWs.
hope i'll be able to afford the redesigned TL when they come out in 2004, the currect one is my favorite car under 40k, but i want to see what the redesign looks like.
Yet, I've never felt the "vibes". As a result, I now use "threshold" braking even in panic stops. Its a very simple (almost silly) concept. The idea is to brake hard BUT stay just a hair off the point where your brakes will lock up. It takes some practice, but once you know where that point is (by feel), its very easy to do. And at that point, you can actually stop in a slightly shorter distance than the rated ABS stopping distance. For example, I think the rated 60 to 0 mph distance for my car is 143 feet (if memory serves). I'll bet I can stop in about 5 feet less than that amount. The major problem with this practice will occur some day when I really do "panic" stop in a surprise situation. Having said all that, I'd truly hate to experience what happened to beachnut. That would be an "Absolutely Bad Scene".
Also, the owner's manual for this car recommends Genuine Honda DexronII trans fluid. Honda doesn't sell DexII anymore, just Z1. Can I put that in it? It shifts just a bit hard, which is another trait they all have. Will using the current Honda ATF soften that any, or will it hurt it?
Thanks for any input!
You are way off-target with this one. shocks & struts do wear out, always. Although it is sooner or later depending on use. Generally about a 100K miles is the lifespan. If they never go bad then Sears, Midas, etc. etc. as well as car dealers wouldn't be selling them and advertising them on the television.
How do you know if your shocks/struts need replacing? Simple. Push all four corners of the car down, one by one, on the fender above the wheels. If that end bounces up and down 3 to 4 times, your shocks/struts probably need to be replaced.
Also at what mileage is it suggested to change the Timing belt?
Experienced people on the site please advise.
What I said, or meant to say was this...For whatever reason, it is rare for shocks/struts to wear out on a Honda even after many miles.
If you ask auburn I know he will support me on this or ask any Honda tech.
Or you can try your "bounce test" on any Honda you run across...you'll see what I mean.
Of course, the chain stores LOVE to sell shocks and struts! It's an easy "upsell" for them.
High profit and a job their low paid entry level mechanics can (usually) manage.
Sometimes they are really needed, other times it's just overselling.
