Visitor Agreement.
This all took place last week, so we are still in the process of resolving it. I'm not too worried about it since it's a company car, but it's frustrating none the less.
I guess it's just luck of the draw on getting a quality installer. I'm sure most people have had good luck with Safelite. I'm probably the exception.
All posts related to the offending post will be deleted, even the thoughtful ones, because we have to clear the thread.
Anytime you see offensive posts, just e-mail me and let me take care of it for you. You do not have to respond or "fight back", this is the Host's job.
Please continue your discussion on Honda Accord and enjoy your visit here.
MrShiftright
I really cant believe that it is not the EGR ports as I see alot of them but I am not working on your car and they are. It is possible that an inner cv joint could cause the problem but they are rare unless all of the greese has leaked out. I can only tell you that if you have doubts take their diagnosis and get another opinion. Have them do the warranty repairs while you are there so it isnt a complete loss of time...Good luck
This is for the 4cyl auto, I assume it to be the same for the v6 auto also. Any v6 DIYers out there?
clint98v6at, THAT's exactly what you should use. If you can't get adequate leverage with the handle to "break" the plug loose, try a length of 1/2" pipe slipped over the handle.
I took my Honda to my local dealer, Goudy Honda in Alhambra, LA. I only have a verbal approval from my dealer. I have not gotten anything in writing. They said they are ordering the transmission parts and will let me know when it comes in. I will let you know if I hear any more details.
I took everyone's advice and did 3 cycles of drain and refill after my mechanic used a dextron fluid. I went 30K miles between the change and the fluid was really dark. It took 3 changes just to have the fluid appear that red color again.
Some local Honda mechanics told me to just change the tranny fluid every 15K miles. I'll give it a try!
And yes... the 3/8 driver will fit on the v6 drain plug.
Have yet to replace the crush washer either on my atf or oil drain plug and at 150K + and no leaks yet. Might replace both at 250K for the h of it.
good luck.
to properly address this problem.
A) Creaking noise that resonates from the driver side passenger window/ upper left windshield. The same noise is also heard on the passenger side window/ windshield. I browsed the forum and have heard this complaint from the following 03 Accord owners:
Martylaw, Bultman2,Sharyl, Mings98,4ztc524 and maxhonda 99.
Wonder if any of you guys have had this problem solved? If so could you help me out.
Also, Ronsteve and Auburn it seems you were having troubles with your moonroof. I am experiencing a rattling/clacking noise also. Did you guys have any luck.
I appreciatte all your help guys!!!
As for the sunroof, the only noises are usally due to the sunroof gasket being dry, we lube them with Shin-Etsu greese and it seems to work..
If anybody had this problem and it was fixed, PLEASE tell us.
Have you been gassing up from the same gas station or randomly ? Patronize the store where your car performs best after an empty-to-full refueling. Chances are the gas quality will be consistent and so will be your car's performance.
If this isn't an issue, try to get the dealer to do a dynamometer test (power at the wheel is measured) to establish a "baseline" reference value when the car is running at its best. When it runs sluggish again, return to the dealer for another test. If you've been getting gas from the same source, the dealer will know that you've virtually eliminated gas quality as a cause and therefore the problem lies in the car.
