Visitor Agreement.
A knowledgeable tire salesperson told me that my X-Ones had worn down below the level with all the siping and I had lost a lot of a my traction on snow because of that. He stated a percentage that was gone below 7/32 or 5/32 of depth left. The Symmetry tires on my other car have worn a few 32nds and a lot of the siping is gone and I can tell when I drive it. The tires don't grab like the did the first two years.
If you look at the tires on your front wheels now and compare to a new version of that same tire you may see that a lot of the gripping ability is gone due to normal wear. MXV4s are pictured on Michelin's website. It says they're not offered any more.
The Hydroedge is rated 8 vs Harmony at 9. Other versions of the Harmony are sold at Sears and Discount Tire in our area with different names (Agility and Destiny)and slightly different treads. They both rated 8 on the Michelin website for snow. Agility only has 10/32 tread depth instead of 11/32.
Honda Service Bulletin 03-057 - Wind Noise at the Front Window
Applies To:
2003 Accord L4 – From VIN 1HGCM5...3A000075 thru 1HGCM5...3A010500
2003 Accord V6 – From VIN 1HGCM6...3A000072 thru 1HGCM6...3A006800
Honda Service Bulletin 03-085 - Wind Noise From the Upper Rear Corner of the Front Door(s)
Applies To:
2003 Accord L4 – From VIN 1HGCM5...3A000001 thru 1HGCM5...3A132549
2003 Accord V6 – From VIN 1HGCM6...3A000001 thru 1HGCM6...3A097398
Was it the bulb or something more serious?
When I turn on the heat and select "auto" then select "dual" after turning off the heat the dual light stays on. I have to then deselect it to turn it off. Has anyone else had this problem or is this the way it should be?
We currently own a '05 Accord 4cyl/ Navi, and out of being compulsive, I checked out the Navi Diagnostics menu. With the car's engine started, and with the car outside, I touched the "F-Can" (it might have been the B-Can) button. On the top row, above the four green boxes, there is a line of text saying "Error Active".
It does not elaborate anymore about what's wrong, but should I be concerned? Anyone else's car have this displayed on their navi diag screen?
Glad you think my idea about sharing info has merit. I haven't taken mine in yet -- am going to wait until the 3000 mile oil change appt. to do it because the dealer I bought it from (Roebuck Honda - Birmingham, AL) is in another city and I won't have time to make the trip up there before then. If they are able to fix it, I will post their solution here on the board.
Do you mind posting the number you called to file the complaint and get a claim #? The more complaints & claims Honda gets, the sooner we may get a solution.
Thank you so much for the information! When I take mine in to have it checked out if they don't have a solution or tell me they can't hear it (they'd have to be 100% deaf!) I'll have the service mgr. call your dealer.
1. above 50 mph, when braking, the car rumbles and vibrates like wheels were loose.
2. above 60 mph, the ride also bumpy, noisy, vibrated, steering wheel shakes. At slow speed, 15-20 mph, I can feel the car moves up and down like tires out-of-round ?.
For the first problem, dealer replaced front brake rotors which seems to fix braking problem.
For the second problem, dealer rebalanced all 4 wheels which not help. Dealer later did "road force balance ?" tires and replaced 1 bad tire, but the second problem still exists. Tech says could not find any thing wrong.
Any suggestion or advise how to handle this problem will be appreciated. Tomorrow, I will talk to service manager.
I am so unhappy and very desperated with the problems. The car was in dealer lot for 4 months before I bought it. I did not test drive it when purchased (stupid me)
Thanks for help again.
At 80k my 2001 started leaking the fluid. The fluid leak was drastic... from nothing to almost 1/4 quart a day. I knew nothing of the extended warranty at this point and I figured I was out of luck.
Took the car to the original dealer and within 2 hours they had diagnosed the bearing problem in the differential and ordered a new tranny, covered 100% by warranty, and had a rental car waiting in the lot for my use while the car was fixed (about 7 days).
Honda pulled through and earned my respect.
About 80% of the purchase was for the car and the other 20% was buying the integrity of the company that made it.......Richard
2003 Accord EX-L, 4AT, 16K highway miles
I've noticed that if I travel via the highway after I've used the brakes where the ABS kicks in (as today, with the snow pack following the blizzard), the car (can't localize the source) vibrates pretty badly for the duration of the trip at speed.
While I'm waiting to hear back from the dealership, any thoughts? Related to TSB 03-069 (http://www.northcoasttuners.com/TSB/03-069.pdf)?
My 89LXi vibrated so bad at speed >60mph this morning. Never had this vibration before. I thought there was somthing with the front end. Got to the destination. Going to check the front end, but noticed powder snow packed & covered the two front alloy rims enough to cause the wheels off balance.
So check to make sure your wheels are not covered with packed snow.
Yes, it was quite a snow
Your idea is a certainly good one, but this isn't the first time I've noticed this. It's happened before when there wasn't snow (although there was ice, which was what kicked the ABS on that time).
thanks!
Leather in a car, although it looks damn good...over a period of 2 - 3 years it will DEFINITELY crack and start looking horrible...especially on the drivers side because of the constant sliding in and out of the vehicle.
If you have the finances to THROW good money away then by all means buy a car with leather, but if you have kids and live a practical life then cloth will be the way to go....
One thing to consider, if you plan on leasing then hell yeah lease a vehicle with leather cause you're going to give it back to the dealer for a new one in a few years anyway.
Here is some more information about the problem which someone out there may help me find a solution, the erractic idle will go from about 700 rpms to 1500 rpms then back down to about 700 and constantly does this until I add throttle.
Heeeelllppp.... LoL
Not to say the Main Relay can not be the cause of your problem, but changing one out is a royal pain in the azz, and the starter is a less expensive way to go. Plus you can change a starter out yourself by removing the 2 mount bolts, disconnect the ground on the starter and disconnect the ignition wire. Install new starter, connect and mount it back up and you're off and running. Takes about 30 mins to an hour.
Brake Disc (Rotor)
Honda Accord/Prelude 1984-1995 Repair Guide
1990-95 Accord
Loosen the lug nuts, then raise and safely support the vehicle on jackstands.
Remove the wheel.
Remove the steering knuckle from the vehicle. Please refer to Suspension & Steering for procedures.
Remove the 4 bolts retaining the hub unit to the steering knuckle and remove the hub unit.
Remove the 4 bolts, then separate the hub unit from the brake rotor.
To install:
Assemble the disc to the hub unit and tighten the bolts to 40 ft. lbs. (55 Nm).
When installing the hub to the knuckle, use new self-locking bolts and tighten them to 33 ft. lbs. (45 Nm).
Install the steering knuckle.
Lower the vehicle and check for proper brake operation.
Anyone have any idea?
Your question was
"I have a 1997 4Dr LX Honda accord.I had a problem with my check engine light and emission test.i got my check engine light fixed and sensors replaced.After that there is no check engine light coming.After the sensors are replaced i drove the car and it was fine.The next day when i started the car after 3-4 mins ,i heard noisy groans and RPM fluctuating.I drove my car to a mechanic and saw the car getting over heated.Mechanic has observed the same and said water is drained out and there is a problem with water pump.He filled the radiator with water and it drove fine for 10 miles without any heating.
The mechanic says it is a problem with Water Pump and needs to replace it.He suggested to replace the Timing Belt,Bearing Shaft belt,crank seal,cam seal,water pump,balance seal and Tensioner as part of 120K mantenance.The current miles on the car is 116K.I approached another mechanic after filling with water,he said there is no issue better replace thermostat or radiator.
I am confused on what to do?Should i replace Water pump and all parts or only thermostat or radiator.
Generally should we replace all the above parts as maintenance for every 60,000 miles.
What would be the cost for replacing all?
Can i drive the vehicle in this condition,if so how long and how many miles daily?
I have this observation on my 03 Accord.
There are times when I need to completely ease off the gas pedal, either to apply the brake or prepare to slow down. When I then press the gas pedal to accelerate (even slowly), the car kind of shudders (bounces up and down -- tsug, tsug, tsug). Although some "shudders" are light, they are very noticeable and quite annoying because the drive becomes rough and not smooth. Has anyone experienced these shudders or bouncy acceleration?
ramida
