Visitor Agreement.
Second, they charged you $350 for sparkplugs and an oil change? Time to find another shop! For the add'l $150, I might have gone for the injector cleaning (in for a penny, in for a £). Or am I not reading this correctly?
A little more detail about your car would be helpful. Are you the original owner? How frequently has the oil been changed in the past? This is the 2.8 V-6, right? If so, it has a track record for consuming oil, but a quart every 3,000 miles is not all that bad, in the grand scheme of things (there's people dumping in a quart every 1,000 miles). What viscosity of Mobil 1 are you using?
Once you give us a little more info, perhaps others here can help you. Personally, I'd look at either having the car checked over by another dealership (some are better than others) or search around for a VW specialty independent shop for further help. I'd also buy a couple of bottles of Techron and run those through the fuel system and see if that doesn't help.
I had my 2k1 GLX in for its 40k tuneup. I started getting the emissions workshop message and the car started stuttering. Turned out that the dealer put in a broken sparkplug.
Most recently, this week, the message came up again. I took it to a VW mechanic (I've given up on the dealer) and the 'puter said that the secondary emissions valve faulted. He checked it and said it was fine. He reset the 'puter and told us if it happens again to let him know. It's happened again....
Has anyone had a similiar problem and what was the cause?
In your owner's manual, in the Maintenance section, it will tell you every 2 years.
Also have had grinding noise from wheels, dealer says both front wheel bearings are going. $500+. Seems a little early in the car's life cycle. I've owned Toyota's, Honda's well into 100k miles, never needed to replace wheel bearings.
These expensive problems conveniently start after the short 2 yr warranty expires.
Is it me, or are these failures a little much for a vehicle pampered to 53K miles?
Now that I have had it for almost a week I have noticed that when I start from a dead stop gently pressing on the accelerator, trying to start smoothly without gunning it, it starts off sluggish until I press hard and seems a little jerky. After I get going it seems fine.
I have skimmed/read all the previous posts and get the impression that this is just how it is. Something about fly by wire or something. Is this true or does it sound like I should take her in for a look?
Paul
Drive by wire means there's no throttle body. A sensor at the gas pedal and other sensors will dictate how the engine performs at that instant.
The "throttle position sensor" is a sensor is at the pedal which determines the simulated throttle position.
Any thoughts?
Thanks for help in advance
NateP
