Acura Integra - (All years/styles)
V-Tech engine? But anyway, says its a woman single owned vehicle with 110,000 miles on it with records of all maintanance done by acura with replacement of timing belt at 96k miles and recent 112k miles tune up all by acura. And to top it all off it has a 6 cd changer in it
Don't forget to check the CV boots and joints, the trunk under the floor (for moisture or staining), and eyeball the radiator fluid while it is still cold. Hopefully the leather and the paint are in good shape.
If you are lucky, that is also the source of the water in the trunk. Do that repair first and see what happens. Also, make sure that if your year has a drain under the floor, it is free of junk and can actually drain. If it does have a drain it is where the spare sits and is there to deal with this exact problem.
If that is STILL not it then the next problem is the weatherstripping around the hatch or trunk lid itself. Even if it looks intact, it is not. It loses elasticity over the years, and when the door comes down on it, parts will flatten out too much allowing water in. It is cheap to buy, but a pain to install (at least it has been for me the couple of times I have tried to do that over the years). I can't imagine a shop charging you more than an hour's labor or so to install it. Also, the gutters around the hatch/trunk lid tend to accumulate junk like leaves and dirt, which causes water to overflow into the trunk - clean all that junk out.
Good Luck!
wanted to know if the timing belt needs to be changed now or at some mileage. and there is noise on turning sharply, starting, stopping...is that the cv joints as you say above...what will it take to get fixed?
also what is your opinion on online warranties from 1source autowarranty or warrantydirect...1source is giving a bumper to bumper 48m/48k miles warranty for 1550!
I am very surprised if you already have broken CV joints at that mileage - they do not deteriorate with age, unless the boots crack and all the lube drains out. Broken CVs sound like a clicking that speeds up to sound like loose pebbles in a can when you are on the roll.
The warranty probably is not worth it - these cars are rock solid, but it might be worth it for you to get a thorough inspection from a mechanic so you can be aware of any issues it might have right now.
khov, your message is more perplexing. Yes, if you have a '96 LS with leather, it is an SE, and you should know that, because it should have a little silver plate just below the right rear taillight that says "special edition". If it doesn't, there is always the possibility it is aftermarket leather. I don't know the miles, so I can't tell if $4000 is a good deal, but if it has been hit badly, $4000 may well be too much. How does the front seem odd?
this car is really nice to drive...its like falling in love with a car!!
yes nippononly i think there is no clicking/ pebbles in can sound so jts seem ok
and i'll wait till 60k for the timing belt
i did get it checked by a firestone mechanic b4 buying...there is an oil leak; and brake and auto trans fluids need to be changed
what is your take on maintenance...dealer vs friendly corner mechanic?
and this car was not driven much at all for last 6 weeks since the owner left the US nd left it to stand outside in the snow...anything special i should look into?
thanks and will enjoy this ride i am sure!
$9000 for a five year old GS with 45K is a good deal, at least in my area, but so is the I30 deal you mentioned. Integras last forever and a day without a lot of trouble. Common repairs are not notably more expensive than for an Accord. Remember that keeping up with timing belts is crucial for the Integra.
Obviously, even with a commute that is mostly free-flowing highway, you will save a goodly amount of gas money in the Integra.
I have the same thing happening to me on my 1997 Acura Integra GSR coupe. I have owned mine since it was brand new. Over the years there was that rattling noise around the 3500 or so rpm while shifting. To me it sounded kinda iffy like i should take it in and check it out. I did, the dealer said the same thing as yours did, it was the A-pipe, and he said its nothing major, but the sound was never there before. I guess its nothing major as they said it was. If i had fixed it the whole labor and everything would cost me about a $300 price. So, not to worry, my acura is in perfect condition, it just sounds like theres some exhaust on it or something...but It'll do fine, this was 2 years ago, and it still makes that sound.
I just purchased a 95 LS 2dr 5-speed, 125K miles. The car is in excellent condition and runs extremely well. However, when it gets cold (around 50 deg - okay, chilly - cold for southern California), the front suspension squeaks noticeably when you go over a bump. The sound only lasts for a moment (the time it takes the suspension to deal with the bump). When it warms up (around 70, say), there is no noise at all (well, you might get a little if you go over a big speed bump). The woman I bought it from (middle aged, original owner), never noticed anything. She garaged the car and never drove it hard. Can I grease this squeak away or is it something more serious?
www.insurancepoliciesonline.com go on left side to car warranties, clicl on cars, for your car you can get a 48/48 zero deductible for 1085.00 check it out, as i bought a 99 integra LS with 15,000 miles in december...This warranty is underwritten by AON Corp, a Virginia surety company, in business over 40 years. Carmax's extended warranties are underwritten by AON...I have heard mixed things about 1source, and it is $500.00 more...GOOD LUCK!!
:shades: :shades: :shades: :shades:
It basically is the first type of variable valve timing Honda ever used. It has now been supplanted by all sorts of more modern controls that continuously vary the valve timing, some on the intake and exhaust valves, as well as varying lift and all sorts of other stuff.
But originally, VTEC just did two-stage valve timing, with a crossover point way up high (like 5000 rpm) where it went to a different cam that changed the timing to allow for better high rpm breathing. Consequently, you got a huge power surge as it went onto the hot cam above that engine speed. It was loads of fun! The i-VTEC that most Hondas have these days is nowhere near as much fun, although of course it is much more sophisticated and provides for power at lots of engine speeds, even low ones. The new ones never take off like jet engines above 5000 rpm like the old ones did.
B.
B.
The t-belt and water pump would not affect oil loss, but the cam seals behind there could be leaking.
If the dye test turns up nothing, I would start checking the oil more frequently - say every 1500 km or better yet every couple times you fill it up. Track the oil consumption to see how much it is.
there is one other thing of course. If you are not changing your own oil, or even if you are, it is possible that it was not filled properly after the last oil change. Did you check it right afterwards? I always do that, even when I do it myself, and certainly every time someone else does it for me - it has been low numerous times, and even too high at least twice I can remember. I am assuming you have checked the oil drain plug and it was not just leaking from there?
OK, I will stop writing now! :-P
:confuse:
But in your case if you have spotting on the ground then you are right - you have some kind of leak. It would have to be leaking fairly fast to fall off the dipstick in 4000 km - you should do the dye test and see about sealing it up. Good luck!
:confuse:
Re: 97 Acura RL with 140,000 mile on it.....
So far as I know (this is what I was told by the dealership), the ABS Modulator is faulty. We were told the ABS sensors would also need to be replaced. The ABS light comes on intermittently and this is why I initially brought the car in. The dealership "fixed" the problem once for 1,000$ and the light still continued to come on. The total cost they quoted me to replace the sensors and the modulator is more than the car is worth at this point. I was wondering if the car is safe to drive with this problem.
Also, I am wondering, if this happened, is it typical to see other things stat to wear down (i.e. will my dashboard start lighting up like a christmas tree because other things are wearing out)?
Thnaks for your help!
Sound#2: After the car has been driven for an hour or so, there is a "click-pop" noise from the rear wheels when braking at slow speeds, approx. 15 mph, for example, stop+go traffic. Does not happen at higher speeds and does not affect braking ability.
Any ideas, anyone?
The dealer mechanic said the rotors are always in tension and so "couldn't make that sound", but we'll check it out...
quick supplemental question: what should we expect to pay for the timing belt/ water pump / camshaft seals as far as labor? any ideas? She got quoted $600 for the timing belt alone, sounds like a little much
Labor is about 2.5 hours, as I recall. Have them break down the costs item by item for you.
Has the alternator failed and I am only going on whats left on the battery, or is there something else quite possibly that could be the issue?.
Anyone have an inexpensive way to troupleshoot this problem as I currently am not working and a trip to the garage will end up up with me abandoning car.
regards
dp
Kinda sucks that your alternator died after only 16 months - any chance the place that sold it to you would help out a little with replacing it?
