-June 2024 Special Lease Deals-
But the VDC has a rear-drive bias that would be fun, plus it a high-tech tour de force.
-juice
I've decided to go with Michelin MXV4+XSE -- available at Costco and with a $60 off on set of four coupon good next week. I have been pleased with the MXV4 on my other cars and have seen good comments from others on this board who have them. They are pricey, but I believe in getting the best quality tires possible -- engine, brakes, and AWD are meaningless if the tires don't hold.
K9Leader
On another note, while browsing Subaru's site (in anticipation of the new Legacy) I noticed the Legacy 2.5 GT is now available with a performance muffler for $375. No other models offer. Anyone have any experience/knowledge? Does this mean more performance parts may be available? Of course with the new Legacy models, there isn't quite the necessity.
-Brett
I am not a fan of the three spoke wheel in the new legacy photos.
We shall see
In all those miles only two issues: Engine oil leak and a rear wheel bearing died. Car runs like new with the auto and 2.5 DOHC--suspension is even still OK, body and interior still tight. If it ain't broke, why...?
As for style and handling, I love the flat roof, looks sleeker. I'm considering getting a second new Subie and drove the offerings. The Outbacks, and "L's" still leave me a little seasick after pogo-ing around the hills. I feel I'd roll one outdueling the local "rice burners", so The GT is still my pick.
DB
The ratings on Tirerack got me interested in the Michelin Pilot Sport A/S's. They were excellent in all categories. How could that be? Tires excel in some areas, but trade off in others. But as I researched them I realized they have a unique design that blends all the +'s from each type of tire category - performance, touring, winter, hydroplaning, etc.
I never thought I would ever spend that much on tires - I think they came to $150. bal./mounted/ etc. w/ a BJs coupon, plus tax. (I've been buying BFGoodrich Touring T/As H rated for years.) But they are amazing - I mean amazing in rain, dry cornering, every condition (can't personally say about snow). The are also quiet. They may be a tiny bit harder riding than the Firestones because they are thicker tires (not wider, but thicker rubber) - and a little little less plyable (I say alittle because I'm riding them at 32 - whereas the firestones were at 30psi).
Bottom line, if they get 30K (and they are good in snow which others here have said they are) I'll buy 'em again. My drive Sat. on the flooded FDR and Major Deagan felt like I imagine a drive in a Hummer would feel. Invincible (but w/out the arrogance, pollution, and poor handling!). The very knowledgeable BJs tire manager (he orders some performance tires for customers that run over $400. a pop) said he thinks I can get 30K+ if I rotate every 5K.
We'll see... and I'll keep reporting on wear, etc. I think they have 4.5K now...
Ralph
The other secret is "you don't have to do it all at once". I took several months doing a bit every third weekend or so. I was at 55k when I started with changing the plugs, finished it recently at 67k replacing the brake fluid. Was planning to replace the (original) pads but there's still 40% of the lining left.
A dealer did a minor auto tranny recall item on my wife's Jeep. Right after that - rear diffy leak! Hmmm?
Jim
As for your 99, it may depend on how many miles you have already, and your driving habits. For example, I still had relatively low miles, I drive a ton (28k/year)and wanted to lengthen time between changes, and I need to get a lot of miles out of the car over the long haul.
Jon
With your '99, you have a choice. There are no aftermarket publications for the newer Subaru products.
Steve
-juice
When I suggested that to my installer, his initial response was to get hissy because "these guys on the internet are not electronics experts." But when I picked up my car after he'd looked into the problem, he politely reported, "It works beautifully now. It was just what you said it was, sir."
Thanks guys. Thanks Paisan. And let this be a heads-up for anyone who puts an aftermarket radio in an OB.
Steve
Hey, we just share experience and knowledge, that's the whole point!
-juice
Steve
Steve I inquired at dealer on books. they list 3 at $50 something each. I Know I don't want all 3 Just engine and drive train, but dealer didn't know which is which. thanks for help T
You will not see any horsepower or torque improvement, you may have a somewhat different exhaust note, and you will have that pretty chrome tip. If you think that's worth $375 be my guest. Otherwise save your money.
rgds,
-wdb
However, many people on these boards will also tell you that as long as you drain and fill regularly (at least every 30k), dino ATF is just as effective (and cheaper). For me, however, it's a question of getting every advantage I can to get high mileage out of my car. So, I'll be making the switch, and keep the same tranny drain and fill intervals.
In the motor, however, I'm using Mobil 1 10w30 with a 5k change interval.
Jon
AWD cars do drift if the road is highly crowned, but it should not be as bad as what you mention.
If I was in your position, I would be tempted to try another dealer. I did not buy from the first two Subaru dealers I visited either due to poor customer relations or bad pricing. I found another dealer, and have bought 3 Subarus from them in recent years. It's been a great experience each time.
Also, if you really liked the first wagon you drove, ask them to check the tire pressure and alignment, and take it out for another drive. Those are two minor adjustments that should not be discouraging you from buying the car. Clearly, however, it's up to the dealer to get it right; it's not your responsibility! I think they blew a sale.
Craig
If you bought it and take it back to fix, then they charge it to SoA and spare their wallet.
Don't think I'm too far off from making sense.
-Dave
Craig
-mike
mike
pauline: the "basic" model in 98 was the Legacy Brighton. If you can find one, they were very inexpensive and simple, and their 2.2l engine was quite reliable, perhaps even more than some newer powertrains.
Next up came the L, which added ABS IIRC. A GT would be pricier, but add some nice features. In your case, look for an L or Brighton, they should work.
-juice
The MXV4s were expensive, but I used a $60 off coupon for a set of four at Costco. They are very good tires, and the price includes lifetime balancing, rotation, repairs. I have been very happy with the level of service at Costco on my previous tires purchased there.
I noticed they hand-torqued the lug nuts -- good thing as I had forgotten to mention that I wanted them hand-torqued. It appears that they do that in all instances, as I heard no airgun noises the entire time I was observing/listening.
--K9Leader
Anyway the Michlins are good tires.
Greg
Steve
My Legacy's original equipment RE-92's got louder, handled quite a bit better in the dry, and handled QUITE a bit worse in the wet (I could tell tales about the tail end breaking loose under -very- mild cornering in wet weather), as they neared the end of their useful lives. I expect the Bridgestone RE950's that are now on the car to behave differently as they wear. They have dual compound rubber in the tread; softer, hydrophilic material will come to the surface as the tire wears, the goal being to maintain wet weather traction despite the shallower tread. I hope that happens (the tires are not yet half worn), and who knows what effect that rubber will have on tire noise.
-wdb
I own a 96OB w/ 113K and it still runs like a champ. I will be relocating to Bethesda, MD (Wash DC Metro area)from Nashville in August and will need a good dealer to keep the Subaru running strong. Any MD folks out there that can make a recommendation?
Outbike
The catch is it's there is a high cost of living here, so service prices tend to be high. I do the service myself, so I can't recommend any particular place.
-juice
Sometimes, unibody vehicles get dents and bent sheetmetal right around the jacking points, but this is normal and does not affect the rest of the structure at all.
The torque wrench would bother me, but don't lose any sleep over the flex issue.
IdahoDoug
Greg
Have others had this problem? Are my ramps designed too steep? Previous cars have all gone up OK and I'd have thought with its high ground clearance there'd be no problem. But it seems the overhang at the front is just too far ahead of the wheels.
-Brian
-mike
Do you by any chance know of any websites that I may be able to find descriptions of how the systems compare?
Thanks...
Ralph
For MY2005 we'll be getting an all-new Legacy and Outback. It should be here this time next year.
Bob
But forget the tech-speak, go drive a Forester XT, that engine is blessed with gobs of torque all over the rev band. I was shocked at how quick it was, and I was already expecting it to be fast!
-juice
I need a roof carrier but don't feel like spending around $400 for the Subaru brand. What are my other choices?
