Audi A8
I got the car without the stability control, but find that it corners well at high speeds on ramps, and does not exhibit any noticeable roll.
I chose the A-8 over the MB E-430 4matic, primarily because I would have to wait until April for delivery, and did not want to go through a Maine winter without 4WD. I did get the winter comfort package(primarily for the ski bag), and the Xenon lights, but did not opt for the Nav system as most of them do not have very good software for Maine. I also own an Infinity Qx4, but find the Audi to have more grip and control on slick surfaces. I particularly like the Tiptronic feature, as it is quite helpful in heavy snow and ice, and in dry conditions its nice to be able to shift at the high end of the tach once in awhile!
There are cradles available from third party vendors for specific brands/models of cell phones which may be what was pictured in your owners manual. Maybe it's something available in Europe or the pictures may have been taken in some Audi execs car that had an aftermarket phone installed. In either case I don't know why Audi would publish pictures (in a US manual or otherwise) of features they don't offer in that market.
is the the phone.
Audi is the latin (roman latin) word for the german word "Horch". Horch was the original car company later named Audi.
Both words mean "listen" in english.
Very interesting isn't it?
Sure, I could have a cell phone dealer install a cordless in the car using a different carriage, but this would render the "pop up" feature in the armrest useless. They must have the cordless carriage somewhere, as someone had to draw the picture!
Although I can understand your frustration with what you have seen in the manual, keep in mind, Audi is a car manufacturer not a cell phone service provider. The reason the A8 is a $60K+ car is mainly because the quantity of Aluminum used on the car and the cost of the R&D that went into developing that technology and not because you can get it with a custom fit cordless cell phone.
rjfiss, I certainly understand your frustration but ironically if you check the MB and Lexus posts you will find the exact same phone misinformation problem is occurring there as well (and at least in the case of MB I think it is the same Motorola phone setup).
-rdo
russell.ollie@erols.com
If you want to find the info I am referring to on the Nokia in an A4, and by the way I think this guy put it where the cup holder normally resides, You can go to the following URL:
http://www.mindspring.com/~edward.palisoc/a4-nokia.htm
I was referred to this URL by some folks who post on the A8/S8 forum at Audiworld.org (formerly A4.org).
Hope this helps
In addition has anyone had a problem with the following: Windshield Wiper chatter. After a full year of aggrivation the dealer finally found out the correct angle and repaired. The drivers side still chatters a little at the bottom. Switching to a Bosch 22" Microedge Excel helped futher, but not perfectly.
Does anyone get a electronic whining sound when first driving when cold ?
Does anyone have a radio head unit that displays incomplete LCD information ? This seems to happen regularly in the cold weather, especially when the car doesn't start immediately.
Re: noises in winter - I do get a "thump" coming from the dashboard. It thumps about every 15 secs when the car is at idle. Don't know what it is, but assume it is some mechanical part doing something normal.
-Concerning the wipers the only problem I have is a big dead spot when the drivers side returns and hits the water the passengers side has displaced. There seems to be poor contact with the windshield in the center area of the blade and there is little to no contact at the upper edge.
-Concerning the whining noise, I seem to get one from the sound system any time the ignition switch is in the on position. The engine does not need to be running. The level of the whine is constant regardless of the volume of the sound system so it is easy to hide it with a little boost in program volume but if I am listening to music with a quite passage, there it is. The dealer has replace the amp and the head unit but the whine remains. It seemed like it had gone away after they replaced the amp but it returned a few days later. replacing the head unit did nothing.
http://audiworld.com/faq/index.html
when the page has downloaded, click on:
"Cell phone integration with hands free II"
this was posted by the same guy who had the listing on mindspring. There is a link there to email him if you have any questions as well and he may have an updated URL for the one I listed previously. Hope this is helpful.
The new long wheel base models are due out in Feb. Dealer told me they could no longer order short wheel base, so those in stock or currently in shipment are the last! The long wheel base sticker will be $5,000 more. Nav system, Electronic Stability Program and Cold Weather Package are standard on the new model (which adds up to about $3300 list). Audi is supposedly working on the antiquated phone (analog and hard wired) but that probably won't change until the 01's are out. Dealer ordered me a long wheel base model "on spec" today. No obligation whatsoever to take it but he loaded it with all the options I want. We'll see if I can resist...
Yes I do think you can get the A8 for 5% over invoice. My dealer says that the A8L will not be available until past february and that both the A8 and the A8L will continue to be offered. I have the nav package on the 2000 A8 and there is no separate compass.
Thanks very much for your comment; as someone on the A6 topic said, it seems pretty "lame" that audi does not offer a simple compass display for those $s. Anyway, it still looks like a fabulous sedan. And you were right on: today, first offering at one of the 3 dealerships I'm going to consider was 1.055 over invoice for one with MSRP of 66,805.
But --- I weight driving experience by 50%, reliability by 30% and all these other things by 20%. I now have 5500 miles on a 2000 A8 and driving is still incredible. The only dealer issue has been a slight reaiming of the headlights. I'm very satisfied, irregardless of the quirks. Good Luck!
funny but i have a 2000 A6 2.7T and i get an annoying vibrating sound from the headliner. it is above the sunvisor. if i put my thumb up there the sound stops. if i let go, it starts up again. it can be heard when i hit small bumps or moderately rough roads. sounds like the exact problem you have but i've bee afraid to take it back to the dealer for fear that they will make it worse by ripping open the top of my car.
but i guess i'll have to take it in if the rattle doesnt stop. i'll let you know what they have to say and if you find out before i do, please let me know.
Also ? to spenser44: have you had any difficulty getting seat positions memorized? Altho I seem to be following the instructions to the letter, I can't get it to work right and "stick" or ... when I touch the number and the bar all at once "it" will send seat and mirrors to the previously set parameters for that setting. Thanks...MJC
there are 4 drainage tubes that run from the
sunroof gutter channels down the pillars. 2 of
these were clogged when I took delivery, they were
blown free with compressed air and its been trouble free since. Strange as it sounds I believe these gutters are the main factor in headliner noise and wind hiss.
Good Luck.
Also, I solved memory seat problem (I was just touching incorrect bar...now will be working on having the remote memorize the correct memory setting.
Has anybody heard of "upgrade" of driver's sun visor to one with homelink built in...as A6 has. It looks to me like it coould be an easy swap-out.
M
just wondering, are you in the US. As far as I know the 3.7 engine was never available in the US although maybe it was in '97. I have a '97 4.2 and my $.02 worth would be get the Audi Assured certification. If you are buying through an Audi dealer they should be willing to do this at no cost. Actually if the car is coming off a lease I think you need to buy from an Audi dealer to get the certification. It will extend the warranty to 5 years/75K miles but the free oil changes end with the original warranty. The other two things that I can think of off the top of my head to consider are the fact that the 3.7 does not have the quattro all wheel drive and the '97 model year did not have the tiptronic feature. If you live somewhere that gets any kind of substantial winter weather, the quattro drive train is hard to beat. As far as the tiptronic goes, It's a matter of preference. I test drove an A6 that had it and found I would for get that I had to do the shifting since there was no clutch pedal. There is some suggestion in Audi's lit that indicates that the tiptronic has better programming for the electronics that control the tranny. Best thing to do is drive both and see what you think.
Bill Mills
Does anyone know about this way of getting cars from overseas to the US legally?
JON
M
First I thought the 8L but the dealer quoted me full list. Said they couldn't get enough to meet demand. Do you think this true? I hate to pay full list. Rather than that I'd buy the a8. Previous notes on this board said 5% over invoice was doable for this car in 1999. Is it still? I live in the Cleveland area, any thoughts on dealers? Any help appreciated.
the trimmings. I need to know what to look for in
a used car like this one.In other words the good and ugly side. The car has 33,823 miles on it and is coming off a lease program, and has be purchased by a dealer at auction to resell at 40,975. Please if you have any insight on this type of model, please let me know. Any advice would be help full.
a used car like this one.In other words the good and ugly side. The car has 33,823 miles on it and is coming off a lease program, and has been purchased by a dealer at auction to resell at 40,975. Please if you have any insight on this type of model, please let me know. Any advice would be help full.
