Visitor Agreement.
indtnvu
On another note, what does everyone think about '05 being the last year for the Park Avenue?
What can be done to identify the condition of the supercharger?What kind of mileage would I expect from this vehicle. I did notice the cruise control doesn't work. I also noticed a noise coming from the left front,I think is related to the traction control as when I switched traction control there no noise. I was impressed as to how this vehicle handled in the snow and ice. I many miles would I reasonably expect to get out of this car? Should I expect to get 200K or better?
Can anyone point out any other inherant problems with this vintage?
Thanks in advance for your advice.
As far as the supercharger goes, the one on her SSEi is intermittant meaning sometimes it'll kick in and sometimes it won't, leaving the car to be very anemic in it's acceleration. It also rattles very loudly and sounds like the waterpump is about to go. There is a special GM Supercharger oil that you should buy (I think it's close to 10 bucks for a little bottle of it) that will prevent this and keep the supercharger working properly. The major concerns I would have with this vehicle would of course be the supercharger, and the transmission. Other than that, if everything seems to be working well, I don't see why you couldn't get it up to at least 200k.
What kind of oil would cost $10?Is this just synthetic?
I am a little nervous about the supercharger from what I have seen on previous posts.Do these transmissions have a lot of trouble?
From what I've heard, this generation had several transmission issues, but I think most of the failures occured at less than 150k miles. I'd check and see if this car has ever had the tranny replaced. Once you take it to a mechanic, have him check the transmission, and the first thing I'd do if I got it is have the transmission flushed and a conditioner added. Good luck.
rick or rpraborn
In reading the various posts on front end vibration - mine ran great for about 70k then developed a vibration - the cause was belt slippage in a tire. Replaced tires and the problem was fixed - I'm using Michlen Symetrys. My wife had a similar problem on her 97 PA and the fix was the same.
Next don't sell the car, it probably is a nice car and was voted best large sedan recently by consumer reports above even Lincoln Town Car. The resale is horrible on the Park Ave, so you'd loose you butt.
Hoped this helped.
Since this is a front wheel drive car, it's likely that your problem is the constant velocity joint (aka CV joint). These are normally replaced as a pair, ie both the passanger and drivers side at the same time. I've never done the job myself, so that's about as much as I can tell you.
1. The fuel Indicator took around trip and stuck in the other side, not coming back.
2. Whenever I start the engine it doesn't recognize me and says UNRECOGNIZED DRIVER and the Trip odometer reset. All meters trips to the maximum then settles.
3. Sometimes, While driving all the lights in the dashboard glows, headlight stops and then comes back again, all meters trips to maximum, then settles. All these happens momentarily. Engine runs fine.
4. Yesterday gave me a hard time starting the car after I drove some time.
Any idea about these problems? Your suggestion will be much appreciated.
Here's the problem. My wife will be driving at hwy speed and she'll all of a sudden lose power. I've been doing a little research online and think it might be the crank position sensor. Would I be correct and if I am, where is this part located under the hood? Any info you may have is dearly appreciated.
Chad
Meanwhile, we'll see if anyone here can answer your question about high mileage. Let us know how it goes.
Chad
