Ford Crown Victoria and Mercury Grand Marquis
Welcome to the continuation of the Ford Crown
Vic/Merc Grand Marquis topic. Those of you joining
us from that topic are welcome to continue your
discussion. If you're new to this topic, you may
want to follow the above link for additional
archived posts.
L8_Apex
Sedans Host
archived posts.
L8_Apex
Sedans Host
The Marquis name is from the mid-late 60's, with "Grand" moniker, as I remember, appearing about in the mid 70's or later in response to the "Grand" Bonneville from Pontiac.
Dad owned both a 54 Ford Crestline & a 72 Marquis Brougham....Prior to the Marquis the top Merc was the Park Lane.
the interior quality in the Grand Marquis is a little better. And even if some say the 3800 is a good motor, I know from owning one in my Tbird that the 4.6 v8 Ford is bulletproof. Now I know why law enforcement professionals rave about the CV.
Otherwise it just boils your preference of v6/fwd vs. v8/rwd.
Either way, they are solid cars for decent price.
If you are planning on doing a little spirited driving in the Grand Marquis should you purchase one, you might also want to consider the ride and handling package. It won't turn it into a Ferrari, but it does firm the ride up a bit (especially around corners) without sacrificing smoothness.
IMHO, even though the Grand Marquis is a better value, I like the styling of the '00 Crown Victoria better...
Seriously, though... You shouldn't worry about what others think. As Steve said, you're recognizing exceptional value when you see it. If you're like me, you're also looking for practicality... And the Grand Marquis certainly has it due to its ample interior room and cargo space.
Oh, and pay no attention to kinley... He thinks that Lincoln Town Cars should perform like Ferraris... (No offense, kinley. *Smirks*)
He does make a couple valid points, though. I'd insist upon ABS, traction control, and the ride and handling package for the benefit of the rear air suspension. Those improvements will make the GM all the more enjoyable.
One last thing... The Buick rode harder because it's FWD, as opposed to the RWD drivetrain of the Mercury. Let's face it... RWD cars will always ride better than their FWD counterparts. :-)
3.55:1 rear axle ratio (aids in transmission downshifting)
Larger diameter rear stabilizer bar (aids in vehicle stability during agressive cornering or emergency maneuvers)
Goodyear BSW “handling” tires (nothing really special, here, and good if you choose to do without whitewall tires)
Uniquely tuned rear air suspension (must make the ride a little firmer, but still be able to soak up bumps with no fuss)
16” lacy-spoke aluminum wheels
Dual exhaust (ups engine output to 215 h.p. which wouldn't hurt)
So in other words, this package will make the Grand Marquis more stable in quick maneuvers, but the ride should not be harsh. In fact, it should still be as soft as you experienced it when you test drove that other GM. If in doubt, just ask the Ford/Mercury/Lincoln dealer to test drive one with the ride and handling package, and see for yourself if you would rather do without it.
At the very least, though, order it with the rear air suspension... It not only keeps the tail from dragging, but accounts for the smooth ride without the car pitching and rolling all over the place.
I wish they married Ford's superb rear air suspension to my Cadillac. You'd then have the ultimate luxo barge. :-)
http://www4.ncsu.edu/eos/users/j/jjyuill/www/Personal/agape.htm)
Any advice on purchasing such a CV would be most appreciated. Additional info:
1. The state auction for cop-cars is nearby. They have '96 CV's with 95k miles. Those with 75k miles have a minimum bid of $8,200. Would it be better to get a non-police CV that looks like a police CV? I can spend $7k to $11k.
2. How many miles can you get out of a CV, before it's more economical to replace it? Once over 100k miles, are the maintenance costs high?
3. We need to haul kids between the home and our shop. How many kids fit in a CV?
4. We need to haul plywood using a small trailer. Is the CV ok with trailers?
Again, any advice most appreciated!
Jim
jimyuill@pobox.com
I want a car with side air bags. The government doesn't check for head injuries in their tests, so the 4 star side impact results apply only to pelvic and thoracic injuries. The test dummies head could fly off, and the Crown Vic would still get 4 stars for side impact.
I thought I had the answer when I looked at the Lincoln Town Car. It is supposedly built on the same chassis as the Crown Vic. The government gives the Town Car 4 stars frontal and 4 stars side impact. How can that be?
I would think the Town Car would get the same 5 star rating for the frontal test, and at least improve on the side impact test due to the side air bags.
If you want a car with side head air bags, excellent crash test results and for it also to be affordable-- good luck. I've looked, too and I can't come up with a good choice without jumping up another $10k+ in price over the CV. Personally, I'm hoping that the next Crown Vic redesign will bring all that together. Meanwhile, the only thing that even comes close is a Ford Taurus. Or you could wear a helmet
On the other hand, for the price of a Towncar, maybe you are in price range of a Volvo. You might want to check out the S70 or S80.
I've looked at both the Saab 9-5 and the Volvo S-80. I think these are probably the safest sedans on the road. I would buy one today if I could get the seat belts to fit properly. The seat belts in both these cars fit way up around my neck, and I can't adjust them.
I test drove the Lexus LS-400. The seat belts are adjustable and the car drives like a dream. The Lexus has a fairly good safety rating, but it's too expensive for me.
I like the BMW 528i, but I feel cramped in it.
I was hoping Ford would add more safety equipment to the Crown Vic. I would love it if they would add side air bags, and Volvo S-80 seats.
The only reason I can think of for not doing that is maybe Ford doesn't want to invest in boosting sales of the CV due to the CAFE restrictions. I think they would really rather sell the Focus, Taurus and Trukasaurus Gigantus.
http://members.aol.com/tocool4u26/ranchero.htm
Can anyone else confirm this? It's really bothering me. Thanks,
Steve
I picked up my new 2000 CV last Friday. Everything works great except for one minor annoyance. During night driving the trip odometer on the lower half of my speedometer is much brighter than the rest of the speedometer area. If I dim the cluster lighting enough to tame the brightness of the trip odometer, the speedometer and other gages are too dark. The light source is coming from an area below the trip odometer and it seems that there must be a light deflector missing or mispositioned. Any similar observations out there?
cut the bottom piece off(you'll end up with about a 12 inch long straight piece). at one end turn it up at a right angle("L" shape). with this tool you can remove and install the filter. you'll see
where to use the hook part of the tool(under one of the three bent over tabs of the little filter).
