EGR valve = Common problem. Check out
http://www.blueovalnews.com/ubb/ubbhtml/Forum50/HTML/000179.html
There was an EGR question/answer here.
Also, I am considering purchasing a new CV with the PH package, but am leary of the reduced mileage. Is there any chance of getting the package with the standard rear? If not, is replacement with the standard rear a foolish thought?
I've been checking this forum intermittently and staying quiet recently. But your discussion of gearing got me thinking. I switched my 99 from the P&H 3.27 ratio to a 3.73, and added a Superchip. 0-60 time improved from about 9.5 to 8.2 or so. Gas mileage dropped from 17C/22H to 15C/19H.
When I still had the stock 3.27, I noticed I could pretty consistently spin the tires off the line (punching the accelerator only-- no brake torquing). However, with the 3.73 and Superchip (which were installed simultaneously, it is actually _less_ prone to light up the tires, despite the improved 0-60. Granted, I'm _not_ a habitual smoky burnout fan (an expensive puerile indulgence). But I am curious what might have changed.
A theory: does this have something to do with the fact that the torque converter spins up sooner now, and I no longer get as much of the torque-multiplication effect of the impeller pumping against a stalled turbine.
Or perhaps my Superchip (which my mechanic told me was programmed to take advantage of the 3.73) deliberately cuts the torque of a full-throttle launch from a dead stop precisely in order to avoid a cloud of rubber smoke. Such reasoning, if it is true, could be consistent with the goal of a better and more driveable 0-60 time, but at the cost of losing the entertainment of wild tire burnouts.
Your thoughts?
http://www.corral.net/tech/maintenance/eecivtest.html
This link has another link to a page with an error code translator, but I've seen others that are easier to use with a table of all of the codes.
Exterior Changes:
1. Arizona Beige and Chestnut Clear Coat have been added.
2. Harvest Gold CC has been deleted
3. 16" Lace Spoke Cast Aluminum Wheel added to LX Comfort Plus Group
Interior Changes:
1. Oxford white, Light Graphite deleted
2. Digital clock deleted from instrument panel and moved to radio display
3. No dim daytime dash lights
4. New front door map pockets
Functional Changes:
1. New available adjustable pedals, move up to 3 inches toward driver for improved comfort
2. Traction control switch moved to instrument panel for easier access
3. Headlamp-on switch incorporated into windshield wiper control
4. New horn system
5. New power mirror switch
6. New standard Personal Safety System includes crash severity sensor, safety belt pretensioners, dual stage air bags and seat position sensors
POWERTRAIN CHANGES (THE BEST PART)!!!!
Power improved 4.6L 2V engine, horsepower improves from 200 to 225 .
Dave
Jim
Mike
Mike
Jim
Mike
Jim
Mike
Mike
Can carry a tremendous amount of stuff, especially with P+H.
We traded our 94 GM LS w/ about 130K and had little problems. We bought it as a program car. I am a maintanence nut and changed Eng oil every 2-3K and Air Filters 10K, Trans Fluid 35K, etc.
Now, the Operators Manual says 5K w/ 5W/30 year round oil, 30K for Air filters, 100K for Rear oil, and Plugs at 100K. My question: Can Ford be believed for 150K miles of trouble free driving?
dmers
I too had a loud "buzz" or sort of "rumble" in the dash of my 2000 CV in a headwind and at freeway speed. I took the car to an auto glass shop (I was on a business trip and away from my dealer) thinking it was the windshield seal, WRONG! It was simply the plastic cowl-cover which is screwed on sort of underneath where the windshield wipers park and is in direct contact with the lower part of the windshield. This was just ever so slightly loose and allowed a strong wind to get under it thus causing a very loud noise in the dash. He tightened everything up and no noise since! Hope yours can be fixed in the same manner...JW
The reason is that there was rust present on fasteners and components. I have a 99 GM purchased in Sept. of '98.
Should there be so much noticeable rust this early? I am concerned about longevity as I plan to keep the car for 10 - 15 years. I am happy with the car otherwise.
Then I had the car inspected by an independent mechanic who found alternator problems and some other stuff, minor but needing repair. The dealer told me he would knock off $300 for me to get the repairs and we had a deal. That seems like an OK price for a car with 26K miles. Thanks, Internet!
Dave
70,000 miles later I feel the same way. Those parts were obviously pre-rusted at the factory. The rusting was too consistent and evenly done to be the result of moisture-- the rust coating looks almost like it was brushed after it was done.
In any event, rust is not necessary a bad thing. If your suspension bars are flaking away, you've got problems. But these pieces are completely solid and as strong as they day they were put in. They have an outer coating of rust, not unlike a railroad track or a bridge support.
Can't speak for the squeaks and groans, however. Unless I'm driving over some serious holes, mine is pretty quiet (except for these new cheapie brakes I bought). I do a lot of driving in Philly, and our roads are very bad too. Do you have all the recommended locations greased?
I was also hit again by the guy's argument thinking it had been flooded or underwater. He did squirt liquid lube on other steering components in an attempt to eliminate the squeaks. My car DID have the noticeably rust colored components from the factory, but now many more of the metal items under the hood are showing rust. The car is outside year round here in MN because I have no garage.
Guess I'll have to wait and see how the car holds up. My 27yo. Mustang is still rolling along, but it is stored for the winter.
On a separate note, I also sent a note to the brass at Mercury with suggestions of about 20 items which I thought should be standard or optional on the GM. It didn't occur yet, but maybe if more of you try sending this feedback we'll get results.
