Visitor Agreement.
Let me know your observance of your instrument cluster during the DARK hours...and if the trip odometer appears disproportionately bright compared with the rest of the cluster. Thanks
Also, when I turn the wheel to either extreme, I hear a weird grinding noise. Must be related tot he suspenion, but was wondering if anyone had the same experience.
That is what I generally do every 4-5 years. I purchase a 1-2 year old w/ some warranty left and keep them for about 4-5 years__120-135K. The factory bugs are generally gone by the previous owner and I have a little peace of mind for a year w/ the remaining warranty. Buy the extended warranty contract on these cars is a waste of money.
Normally, I have the expense of belts/hoses/shocks/battery/Brakes/Change Tranny fluid every 35K/Change oil every 2-3K/and that's about it.
The ride and mileage for this size car is very good and cost per mile is great!
If the noise is only present with the steering wheel turned to the stop and is not the p.s. fluid pump, it is probably the steering stops scraping that you are hearing; the steering stops are welded onto the back of the lower control arms - look for a shiny worn spot where the stops are making contact - you should be able to just apply some thick grease to the contact surface of the steering stop and test if the noise goes away.
I don't know how to contact you other than posting a message here. Ever since the "Ford Crown Victoria and Mercury Grand Marquis" -part one- topic was archived and this -part two- topic started, this topic no longer appears on the main Sedans Topic List page. New visitors who may be interested in this topic will not know we exist. Kindly add "Ford Crown Victoria and Mercury Grand Marquis - 2" to the list.
I usually drive with no passengers and no cargo, I have never heard of using different tire pressures for this situation. Will this help keep the rear on the ground and produce a better ride. Does using different tire pressure for this driving condition really make that much difference.
The tire pressure decal on some FWD cars list different pressures for the rear tires depending on whether the car is fully-loaded or half-loaded. Different tires carry different amounts of your car's weight. It makes sense to me that tires carrying more weight need more air pressure.
L8_Apex
Sedans Host
I ran into the same situation. I ordered a deep wedgewood blue CV with dark denim cloth seats on Jan. 17. On the seventh week of hearing nothing I started bugging the fleet manager I was working with. When he didn't call me back in a couple of days as he promised, I called him again and got his answering machine leaving a message asking if any action had been taken in trying to track my car. He called back a few hours later with the bad news that my CV had not been built yet. This was nearly two full two months after the order! He said the St. Thomas, Ontario factory was currently overloaded with government orders - I guess FBI, CIA, cops, whatever. That may explain Rea98d's siting of all those trucks loaded with CV cop cars.
That really worried me because the $1500 rebate was to end 3/31 and I wasn't sure what it would be after that. I decided to call him back and do a dealer search with the options I wanted but I would be more flexible with the color. I ended up settling for Harvest Gold and now I'm thinking that color will not show dirt easily like the dark blue. So things turned out okay.
So maybe you should bug the saleman somemore to find out if they even started on your car yet. By the way, they are transported via rail out of St. Thomas.
