Have a 97 dodge neon with factory alarm and remote start. how would I disable the alarm so I don't need to use the remote control device anymore? thanks. btw, it has no toggle switch under the dash.
Of course that is not a fix.
Any luck with your problem?
I'd be embellishing for the good if I called it only a :lemon: :sick:
The recent problem started this Sat.8/4/07.
The fuse for the the turn signal blew.(15amp) I replaced it several times since then, but it still doesn't work. The signals would work for 1-3 mins, then blow again. (Yet again I have to carry packets of fuses in my car).
I have dealt without having any back-up lights for a year but not having any turning signal, is ridiculous. I just can't deal with that. I have tried everything to get it to work, but have not had any luck. If there is anyone out there that can give me ANY advice, it would be greatly appreciated.
As trust me on this, fuse/electrical problems are the most minor problems you will have to deal with on your Neon.
The key is to have the head milled before installation and don't let the dealer mechanics near it and it will probably will last a long time.
thx
kent747
also...i too have the rediculous "not turning off dome light" issue..i have replaced the door jamb switch which made the "door fuse" stop blinking, and now it still wont go off and it just blinks fuse...i have checked all the fuses inside and under the hood and nothing is blown..PLEASE HELP ME!
I can do the work if I had some prints on the Cruse and electrical. Can any one help me? Any one want about a engine compartment full of acorns?
Im gonna wait for some answers, this is my emails too.
thanks, Marcelo
www.jmarcelo1970@yahoo.com or jmarcelo1970@msn.com :confuse:
The 96 Neon has 196,000 miles on it and still runs well !
Hope this helps.
farout
I even does it with the cruise control on. WEIRD!! :sick:
farout
Have been calling to local salvage yards and they are out of stock (only a 96 Neon cluster without Tac will work according to the repair guides - cannot use other model years). The Gas and Temp gauges work fine.
Am ready to call the dealer for the part but was curious about the parts cost.... if it is more than a $200 bucks, I may be better off getting a portable in car navigation system for the same price. One of it's features is a speedo display.
Your thoughts?
I acquired my instrument panel at spaldings auto parts in Spokane Washington for around 80 dollars. That was not the end of my problem. The wiring harness fried so I had to replace that. My old instrument panel works. So you might want to have the harness looked at. :shades:
farout
