I went to pick up the car and did not get out of the shadow of the garage door when I decided to see if the problem was remedied. I quickly duplicated the problem, left the car and drove off in the loaner. Can I respond on the official Volvo service records that "customer duplicated the problem in 3 seconds"?
They are very accomodating but the car seems to suck!!!!
Scott
Now comes the 2000 S70, which I bought with 12,100 miles on the odometer in May. I've put about 5,500 miles on it since then and here's what's gone wrong:
Turn signal switch failed -- replaced under warranty
Antenna ring in steering column (for encrypted ignition keys) started going bad, making car-starting problematical -- replaced under warranty
Crash-impact sensor for airbags failed -- replaced under warranty
And the latest: Right-rear electric window doesn't work, either from the master switch or the door switch -- it will be fixed under warranty
None of these problems (with the exception of the failing antenna ring) has been disabling, but coming as they have with low miles on the car and in fairly steady succession, they've been disconcerting.
I bought this car based on my experience with my two other Volvos. Maybe I would have gotten something else if I'd researched it. Now however, I just have to hope that I'll be able to find and eliminate all the little gremlins in it before 50,000 miles or 2004, whichever comes first.
I do not like the newer style Volvo's - they just don't seem like Volvo's to me anymore. Anyway, once I settle on my house in mid-september, I am considering a 2000 model S70. I know that the S70's are really just refined 850's. For a 2k model, all of the bugs should be worked out, correct? The car had basically been produced the same way with the same parts for several years, correct? Also, I know the GLT has more power, but does the turbo mean less reliability? Any advice, things to look out for on low mileage 2000 model S70 or S70 GLT's? Maybe a dealer still has a brand new left over somewhere?
Also - with the Light Turbo - do you HAVE to use premium unleaded?
Thnx
Even the T5 manual says that you can use regular gas, but they don't recommend it because the car will run best on 93. I'll probably be using 91.
I use 89-octane gas in my S70 "light turbo" and in my 850 non-turbo. It works fine. Also, I pretty much stick to Chevron, which a couple of dealers have told me is superior to other brands (contrary to the conventional wisdom that all gas is the same).
Most (but not all) stations, regardless of brand, get their gasoline from terminals -- the hydrocarbons are the same. They then can pick the additive from additive dispensing units, usually coloacated with the gasoline.
Will I ever get a status call?
Will my tranny be replaced?
Will I be driving in their loaner car the next several years?
Tune in next week...........
Scott
Thanks for the info.. i'll check it out at the next oil change...
Don
KISS MY [non-permissible content removed] VOLVO!!!
Actually mine is semi-ok..been to the dealer ALOT for bulbs, warning lights and one no-start..(of course couldnt be replicated or fixed)..but when it runs right its a beautiful car!
well took it on a long vaca trip yesterday..30 minutes into the trip, the check engine light comes on.. (was on months ago and apparently fixed as it was faulty)..well, started smelling rotten eggs in the car...
anyone have THAT problem... oh, posted recently that my drivers seat feel like its shifting in its tracks..someone posted back that there is a dealer fix for it...an interesting car to own.. so far my 2000 Honda civic EX coupe just has oil changes...a dull car..no fun problems to figure out...:)
Don
2000 S70SE
the adventure continues!
If these problems have been occurring since the vehicle was acquired, I would make an attempt to not only contact the regional Volvo Customer Care line but the national office and the office in Sweden by mail. This is a serious issue.
If Volvo reading this post, SHAME ON YOU!
I was told today they have the part to check the pressure on the trans and they will check it by Monday. In any event, they are not getting the loaner until they fix the car.
I am disgusted and want out of this abusive relationship. Anyone want to buy a used Volvo w/ only 28K, dealer (dis)serviced?
Sorry to clog the board but this is therapeutic as well as a good way to warn others to be wary. I realize my case is extreme but this (s70) board is more of a gripe forum, clearly indicative of the car's performance. Check other vehicles and you will see that mechanical problems are not the main topic.
So let's recap: The cars run like crap and they depreciate faster than a portfolio loaded with tech stocks. Oh, and I forgot, they treat theircustomers like shills by manufacturing inferior parts that need to be replaced 4X as much as NORMAL parts (I'm talking about their 13K mile/28K mile break pads/rotors).
I've owned several used cars and I've never had an experience like this. I would plunk down 30-35K on a used lexus before I buy another Volvo.
Actually, I won't be buying a Volvo EVER!!!!
I agreed to take the car home and drive it for a few days. Maybe it's me. I will say one thing..positive believe t or not. After driving the loaner for a month (2001 Accord) you cannot even compare the two. The volvo is a solid auto and quiet. I did miss it. Then again, maybe I'm developing an abused customer syndrome.
Anyway, that's it for now.
Your comments please.
Sometimes it works out OK !
I have linked this discussion into that folder, but it will always reside here in Sedans.
Looking forward to meeting everyone!
KarenS
Owner's Clubs
Even if you don't want the car, I'd exercise the purchase option because you could probably resell it for more, depending on the factory options you have.
I currently own a 1991 740 - with 126K miles - it's rock solid - yes it's had some occasional problems but it is solid and i know I can get 250K miles on it.
Any input/insight appreciated.
