Visitor Agreement.
Thanks alot
Matt
Please tell us how you managed to beat your buddy's GTP. Was he going in reverse at the time?
I had the four door and was never sorry that I chose that over a two door. The Grand Prix is the only car that I can think of that looks just as good or even better in the four door version vs. the two door. I would definitely get the four door again if I were to get another Grand Prix. (And I WOULD be getting another Grand Prix, if I were going to buy a car.)
The convenience of the four door is immeasurable vs. the two door, but I put looks at the top of the priority list. If I thought the two door looked better, that's what I would have gotten, despite the inconvenience. Fortunately, you can have both the convenience and the good looks with the Grand Prix four door sedan.
That baby of mine was the only car that I have owned (and there have been MANY) that never had to go back to the dealer for any kind of warranty repairs or adjustments. I put almost 20K miles on mine, and never had the first problem with it. I only traded it in because I wanted a Jeep so bad.
I don't know where else you would get the looks, the performance, the fuel economy, the comfort, the trunk space, the dependability, etc. of a Grand Prix for anywhere near the same amount of money. They are great cars!
tom
I realize no car is perfect.
What are the known issues with the GPGT?
Problems: I have had is the automatic temperature control system. There was one of the icons blinking on and off strangely. The system worked but it was annoying and is under warranty so they replaced the unit.
The second problem I have had is that the sunroof is a little noisy. When I hit bumps, I hear squeaks from the sunroof. I haven't had the dealer check this out yet.
Overall, fairly minor problems.
All I can tell you beyond what I said in that post is that it seemed that almost everyone that was posting in here was also very happy with their GP's. There were almost no negative posts by owners of Grand Prix's! That ought to tell you something! You can go to almost any other discussion for a particular vehicle and find a large percentage of the posts to be negative. That sure was not the case here when I was actively involved in this discussion.
I would definitley get another GT or maybe even a GTP if I were going to buy another car!
I have had my little Jeep Wrangler for a year now, and I am very happy with it. I still wish I could have had the Jeep and kept the Grand Prix, but there was no way.
Hope this helps.
tsjay
What cured the problem was a silicone base rubber compound that was liberally applied to the outer weather stripping. As explained to me, although not necessary visible, the outer black weather stripping can be dried and cracked. By applying the rubber compound (comes in a vaseline-like tube for $6.95) over the outer stripping, this solved my squeaking problem.
The mechanic at the dealership gave me the compound and told me to apply it every six months. For the past 4 months, haven't heard a squeak! Hope this helps!!
For its size, the Altima is great. As for price, it can easily get near $30K should you get the car loaded. Is it worth the price? I think its priced too high, but it depends what you're comparing it to. If you want room, power and a better ride, the SC Grand Prix/Regal (or Maxima) is the choice. If you like a more compact design, fresher interior/exterior and designed to take corners, the Altima is worthy of a look...and of a higher insurance premium.
Just my $0.02...
Maxima was nice but I did not like the beam rear axle. And I personally did not like the design of the gauges.
Altima is pretty expensive, does not come with ABS ot TCS standard. Plus the interior materials are a bit cheesy.
I would have easily gone for another GTP or 300M but figured, hey let's see for myself what all those Acura freaks are so extatic about.
Plus there a a couple of things on the GTP that used to annoy me - slow power windows and dim headlights. 300M does not accelerate under 7 seconds and the tranny is not always smart.
On a separate topic, anyone catch the news of the delay of the next generation Grand Prix/Regal?! More info can be found at <http://www.thecarconnection.com/index.asp?article=4485&sid=173&n=156>
If you buy, I guess... well, I would have not been able to afford financing a TL-S.
And with GTPs around here, they did not seem to discount them too much. MSRP is 28K+, pretty close to TL-S's going price. A few dealers told me 3% over invoice, but stil it's not a great discount.
That Regal/Grand Prix delay in the news is probably good news. They must be trying to make them look better than the original 2004 designs.
My guess is Lutz wants a more refined interior on the car which will be all good. I had a GP before my current Intrigue and the weak point IMO was the dash which was a little too plasticy. Given the Intrigue is in it's final year, the 04/05 GP better be good if GM wants to keep my business. I have good feelings about this delay and since I won't need a new car till at least 2006, time isn't an issue for me.
Headlites flicker and/or dim many time, typically
more so it seems when its cold out, while driving.
A TSB (out since last Feb.) to replace an alternator with a redesign has failed in most owners cases to fix it.
Since the car is built in the same factory as the GP (Fairfax KS), some over from the Intrigue group were wondering if any of you GP owners had this ailment ever?
Thanks and Happy New year to you all!
This is my first time checking out the Grand Prix topic here, so I thought I'd comment on a few of the last hundred or so posts...
First, for all the people questioning where Performance Shift went for newer cars... This feature still exists in the PCM, but there is no longer a wire or a switch to enable this digital input. You can add the Performance Shift to your new Grand Prix with one wire and a simple switch. Check out ClubGP and search for 'shift' to find the thread.
Second, I saw a few posts about whether or not a smaller pulley will decrease gas mileage. The answer is absolutely. Technically speaking it shouldn't, but when you add 15 to 25 horsepower to your car in two hours, you can't help but drive it quite a bit harder...
Third, you should ALWAYS run 92 or higher octane in your GTP. If you go to a smaller pulley, I believe this is paramount.
Fourth, I recently designed a Limited Slip Differential for our cars. I can't seem to shorten the link enough for Edmunds to let me post it, so you'll have to search for 'differential' on GlubGP. Anyway, I thought some of you would be interested to know there IS a cure for torque steer in our cars.
Scott A. Cook
Westerville OH
2000 SSEi
13.438 @ 101.89 (2.013 60' time)
Good luck!
Scott
I scrolled back thru a few hundred messages but didn't see anything about towing so please excuse me if its been covered already.
What type of experiences have you people had towing with your GPs? I would be towing a 1700# boat and trailer. I have a 2000 GP GT so the power shouldn't be an issue.
I want to avoid towing if possible, but if my truck dies before I have enough money for a replacement I could be stuck doing it. Any recommendations for heavy duty rear suspension and towing kits?
It has been a while since I have posted any messages on any groups. Purchased a 2002 GP GT end of December and I LOVE IT. The only drawback, is the cool color, blue-black, really shows the dirt. (as all dark cars do). I would highly recommend this car to anyone thinking of purchasing it. Still learning what can be changed to suite my driving needs. So if anyone has this car and has found something really great to change please let me know. So far the only thing I want to change is when the doors lock and unlock.
The last Pontiac I owned was 6 years ago, a firebird. Will check out the site periodically for car info.
Thanks for any help!!
As far as driving in snow, we put winter tires on it and have no problems getting around. We live in the Colorado front range (Denver area) - don't have to contend with deep snow very often, though. I do have to say that I'm dissapointed with how the traction control functions. Typically I find that I've reacted to the wheels slipping before it does.
Hope this helps!
Deep unplowed conditions have stopped my GP.
Dedicated snow tires that are skinnier than the 225/60/16 OEM size will help alot.
The trunk is a very good size and I constantly surprize my wife with how much I can pack in it for trips.
Check out the Chicago Auto Show info on the G-Force show car
Anyone know when this car will be out?
