Good luck to all of you with trouble , very sad to hear about that ... and to those who are happy with your vehicle .. you are one more satisfied customer like me ! LOL !! :-)
One post mentioned bushings, but didnt go into detail.
I am a 2nd owner(1997) of a 1995 Galant "S" since 32k, with auto/pwr brks/steering windows,doorlocks/cruise/abs/cd - 80k miles. 8yr\100k extended warranty.
no major problems, all maintenance done religiously.
Up until this past Sunday, this car was as quiet as a car can be for it's size.
Sunday it developed a squeak ( like stepping on a warped board in a wood floor). The squeak is on the front passenger side and is only heard when:
1. hitting a dip or rough road
2. steering while in reverse. ( squeak then sounds like it's coming from the steering )
my mechanic says "the bushings needed lubricating". This explanation doesn't sound right, based on my understanding of bushings.(and the lubrication didn't work, BTW)
Has anyone had this type of squeaking problem ?
If so, what exactly was the cause of the squeak?
I will be taking it to the dealer ( shudder ), but i'd like to be armed with a little info.
Thanx for all your help
Thinking on 2000 es
1) Looking for information on Galants-new or used.
2) Looking for diagnosis of (or sympathy for) problems on our Galants.
3) Sharing appreciation for current/past Galants.
Groups #1 & 2 have the highest likelyhood of showing up and being vocal. This is a Galant not a 'Vette (etc.), so Group #3 is not as prevalent.
Therefore, people looking for information (#1) are looking at a negatively biased cross-section.
My advice is buy a car if you like it and feel good about the purchase. The bad experiences of all here, while valid, should be taken as individual data-points with the understanding that it is not the whole data-set.
My addition to the group history is that I have had 2 Galants for 3 years total ownership and 30k miles. I never took either to the shop.
-Lots of people like me don't intend to keep our cars for 150,000 miles...
Boston: don't sell your car yet , wait until the warranty expires at least.
About extended warranty ... I think I read you can't make a claim during first 15-30 days, maybe i read wrong.
1. Noisy, everything rattles, squeaks makes a whole bunch of noises.
2. Not reliable, becuse they don't last long.
3. Mitsubishi service does suck big time...
By buying a Galant, you're wasting money and asking for trouble.
IMHO
Also, the 15K mile difference has made a great difference in the feel of the two cars. In the 2000, the engine and road noise is noticeably louder. The car rides rougher. The difference is almost like one has a luxury suspension and the other has a rougher sports tuned suspension. I'm not implying that my ES has a sports tuned suspension, just using this as an analogy. Tire wear on the 2000 is in line with what you'd expect with 18K miles.
Anyway, does anybody have any ideas regarding the adaptive shift?
Since you drive lots of miles ... well,
My uncle has a Sienna , 60,000 miles in like less than 2 years ... and holding off pretty good.
My cousin Accord, 2 years and 80,000 miles and still drives like new ...
My sister protege: 6 years and 100,000 and starting to break apart.
My Galant: 4000 miles in 1 yr , too little to tell what's gonna happen.
it's how well / often you maintain the vehicle (and use the warranty for defects) and if the mechanics care about quality of service or not. I had a 96 mirage which I regularly maintained, but I tortured the engine (constant high rpm driving). Although I had it for only 55000 miles in 5 years, the only thing I changed was the oil, radiator coolant, and transmission fluid, and changed the brake pads and fluid.
My parents own a '90 galant which has survived after 10 years in the middle east heat and dust.
Which is why I bought a 2000 ES 4 cyl back in april. Of course the steering wheel started shaking around 70 mph. took it to the dealership, and they told me everything was ok, took it to several automotive shops, same answer. Then I get a recall notice. Traded the 2000 for the 2001 ES V6 back in Oct. The engine started idling roughly after 200 miles in P or N, without a load (no AC). took it to 2 dealers, the first said that it was the fuel. I used QT, but switched to BP, Shell, Texaco. No difference. Took it to another dealer, who diagnosed the engine and said it was running under mitsu specs. I think it might be the plugs but since it's a hassle to replace them it wasn't worth changing until my scheduled tune up. As long as this thing lasts 10 years, I think I can put up with a little roughness. One thing I did notice in the suspension was that the 2000 was softer than the 2001. I liked the 2000 feel better, but oh well.
I have a Mitsu Galant 97.It has about 41k on it and I brought when it had around 32k. From the past 2weeks I observed that as i go more than 60 miles/hour my handle vibrates and if I slow down below 60 miles its ok.Can anyone please suggest me some answer for my problem.
Sajay
the past 2weeks I observed that as i drive more than 60 miles/hour my steering wheel vibrates and if I slow down below 60 miles its ok.Can anyone please suggest me some answer for my problem.
Sajay
the engine leaks oil but it was fine for a while around time,in fact it was surprisingly smooth,until one day the engine light turned on.
the mechanic did an oil change,tun eup with new spark plug,replace ignition wire set,spark plug wires,then distribution cap,ignition rotor.
now the car is worse than before,and i only drove it for 2000 miles arund time.
when i drive it for more than say 15 minutes,it started to make noises at the stop light,some times it will just die .
once in a while while driving there seems to be some kind of pullback ,hard to describe .
what bothers me is the stop light incident when it died on me,does any one know what is going on?
i hate to go back to the mechanic every other week,i wonder if they know what they are doing.
now they are gettimngdefensive and say it is the mileage and enigine leak.
but i only had it for 10 months and 2000 miles ,it was not that bad before they worked on it,help please
like i said i let my driver license expire and i need a car to practice,it is a catch 22 situation,no car no licence,no license ,no car!it has a new rebuilt transmission and new radiator.
i did some work such as oil change,tune up,battery and minor parts.
the engine leaks oil but at first there is no sign of whatever ,now if i drive long enough,it will vibrate loudly at stop light then it may die .
my mitsubishi dealer offers me 1000 as trade in,i paid 2200 .
i know from reading this board,the zero program is killing the resale value of mitsubishi cars,so i am not sure if i get a new car,should i buy something else say a honda or a good toyota?
consumer report said gallant is a good value and my dealer offered floor sample white 6 cylinder 2000 gallant ls for 18.000 cash.
i would like to hold on to my 92 car a little longer to recoup my investment and just use it for around time errands,buti really like to know what is wrong with it,when it dies at the stop lite,both engine and oil lites lightup,does it mean something.
i have no problem restarting but i like to know what can cause it to happen?
While I understand those so quick to defend the reliability of their Galants against the likes of Toyota or Honda (depreciation of Galants not withstanding), your assertions, obviously based on your own understandable emotional attachments to your cars just don't have a quantative leg to stand on. With regularity I read nearly all of the major car magazines, as well several leading consumer magazines, as well as several forums on the web, and the reliability numbers year after year of these two makes is far above all of the other brands domestic or foreign. To be fair though, even with its problems, the Galant is a far better car than many others on the road and perhaps (sadly) all of the domestic makes. Reliability wise, every publication that rates cars rates the average Gallant just a few notches below the more homely Camry or Accord.
This post was not meant to anger any of the proud Galant owners. However, as further evedince of Mitsubishi letting their quality slip, I would point you to page 18 of the January issue of Automobile magazine which reads as follows, "In the wake of Mitsubishi's embarrassing recall debacle, the Japanese Transport Ministry has temporarily withdrawn the company's registration certificate - thereby forbidding it to launch any new cars in Japan...". I guess to be fair, if the US had a similar policy, all cars would have to be imported.
arent our gallants come outof normal,ill facility or is it just assembled there?
true,new car owners should be astute in paying attention to what other car owners have to say,especially those who own their cars for a while or bot a used one.
my dealer offer of a white floor sample 2000 gallant LS is 18.000 cash (before 1000 trade in for my old one)-please note it is a white one and down in houston,white ones get dirty easy.
also there is a rebate program going on nationwide for all 2000 gallant of 2000 dollars.
also it is a floor sample so there will be some mileage and test driving abuse.
i dont know whether it is still available,but since then i have received calls from other dealer(mitsubishi) for 2001 gallant ls for msrp plus 100 with more generous trade in.
i suspect come next year,all auto makers domestic and foreign will be scrambling to sell their cars.
this zero program is bad news for resale value.
my salesman recommend taking up on the zero program and find alternative financing within a year,do not wait when one year is up and face the choice of paying 9% to your dealer or have your local bank tells you it is now a one year old car.
another suggestion is to accept the zero program,keep the cash in bank to earn interest and come back a year later and pay it off.
of course all these arrangements will be more than 18,000 .
i still would like to know what is wrong with my 92 gallant which dies at stop lite
the seller bot this car at auction and quickly found out prior owner had been driving with the parking stick up!it ruined the transmission,but i have heard from other mitsu owners that the transmission is an achilles heel for mitsubishi.
i think car quality has gone up in recent years,especially the lower end domestic ones and the cheap foreign ones like hyundai.
unfortunately there are more car owners who drive more and maintain less, our lifetstyle is so hectic that some of us dont have time to do every thing.
also there are folks out there who know howto drive and nothing else about the car like oil change,tune up.
We all know some people do get bad cars that break in few months , but those people also come out here and say DO NOT BUY GALANT ! , why? I don't know .. but we all respect their voice, as we should also have the respect when we say BUY IT !
I do have said lots of time, If you want proven reliability go for the camry or accord, I recommend those 2 also, since lots of my family have them and are really good !
Mikef
I have a question about the trip odometer. How do you actually set it? I am trying to test my fuel mileage.
People who think that Mitsubishis have suspect quality are really missing a treat. No problems from my fantastic car!
I am still a happy Galant owner.
My mileage was usually around 28 and now I am barely making 22mpg. But it's all correct. I live in Chicagoland and our cold weather causes it.
Wake up and drive...
marcin
