Visitor Agreement.
2. Is the AutoStick available in the Stratus Sedan for 2002?
3. Is the AutoStick also know as the 41TE? If no, what is the
nomenclature for the AutoStick?
Thank you,
WKH
andre1969 -our plants( we had two in Brampton at one time)were AMC plants before getting bought by Chrysler. The first plant opened in 1961 and built many cars like the Rebel ,the Gremlin, the Hornet and the Concord . In 79 and 80 we built CJ 5 and 7 's . From 81 to 86 we built Eagle 4x4's and Concord's. Then from 87 till we closed in 92 we built Jeep Wranglers. The plant that we now build the LH in opened in 87 and built the Premier till 92 . The old plant was closed and the Jeep moved to Toledo , Ohio and all people from the closed Jeep plant moved up and joined the people in the Brampton plant to build the GREAT LH cars.I stated with AMC building the Jeep Wrangler.
the 41te is the "official" name for the auto tranny in all fwd chryslers that have a transverse engine layout (stratus, neon, minivans). the lh car's (intrepid, concorde, 300m) official auto tranny name is the 42le. basically, "t" means transverse and "l" means logitudinal. therefore you could surmise that the lh cars have a longitudinal engine/tranny layout. lastly, the 4 means 4 speeds and the 1 or 2 is a relative torque capacity figure. the 42le has a higher torque rating vs the 41te. oh, and "e" means electronic...
jeffew's (c01) back! anybody miss him??
Daimler has really dropped the ball on the PT Cruiser, no updates or new models yet. The 2.4 liter turbocharged Neon SRT is a go for next year, so maybe that engine will find it's way into the Cruiser.
If Bob Lutz and product over marketing takes hold at GM, may have to look towards GM to replace the R/T in 2008.
I know next performance cars from Dodge will be SRT, but that´s another story. I hope the Intrepid R/T will continue on, maybe if they drop it, they will next race the Charger SRT, What do you think, heard something about it??
Dealers were told to stop ordering R/T´s???????
Anyone else out there notice the tire screach in corners?
I think that the 2.7L does not produce enough torque for these heavy cars. I would not consider the 3.5L because of the timing belt. I could not afford the cars with the 5.7L Hemi.
btw, timing chains can fail too, and i would never go past 100k even on a timing chain since almost all of todays engines are not free wheeling and therefore a timing belt/chain failure could be very expensive! just my two cents...
do you have any specific info on the upcoming lx engines? personally, i kinda doubt the 2.7l will make it into the new rwd cars. i suspect the offerings will be 3.5l v6, 4.7l v8 and finally the 5.7l hemi v8 for the 300n. it would be an awefully huge jump from 3.5l to 5.7l, wouldn't it??
my '00 intrepid had the new "lifetime" tranny fluid (atf+4). which basically said you'd never have to change the tranny fluid under normal conditions. i still would change that around 60k if it were me...what does your owner's manual say??
as for using the machine vs just dropping the pan. for a car that probably doesn't tow anything, i'd say just dropping the pan should be enough.
As for the 2.7 and needing more torque, couldn't they just play around with it some, like with that active intake valve they used to have on the ES when it had a 2.7? It only gave it about 5 extra ft-lb of peak torque, but it raised the torque curve across the board, up to around 4,000 rpm where it peaked at 195 ft-lb. And around 5000 rpm, it still had the same 190 ft-lb as the regular 2.7. Or couldn't they revise the transmission ratios to give it a quicker first gear, so you could get to peak torque more quickly?
I think the Crossfire concept car has a 275 hp 2.7, so the engine is capable of a lot more that what it's doing.
One thing I have noticed, though, is that the thing makes the white steam in the cold weather for a real long time. At an idle, even after a 30 mile highway drive in dry conditions, it blew the white steam. Also a bit of a burning smell has persisted, but seems to be going away (I know most new cars do it), but both of these things are a bit weird. No soot in the tailpipe, and coolant is A-ok. Anybody with any thoughts?
You probably did a good thing, changing the oil early. I've heard conflicting stories on whether it's really necessary or not anymore, but I say better safe than sorry! Although I waited until about 2000 miles before my change.
I wouldn't worry too much about the white steam, unless you start smelling antifreeze, too! I think the white steam is just a by-product of today's cleaner-running cars. They burn more cleanly, but also run leaner, which means they suck in more air. I'd guess the steam is just the moisture from the air that was used in combustion.
Regarding this "debate" on the 2.7. Having driven several base Intrepid's with the 2.7, I too think it is a great engine. Yes it is a bit light on torque (especially in heavier vehicles). DC COULD increase torque and hp by adding variable valve timing control (as other manufacturers do) but I doubt they would.
I'm still hopeful that the next Intrepid will be front drive and exhibit the same continual improvement evidenced from Gen 1 to Gen 2.. Peace and prosperity to all!
I would compare the specs on the tires, that should tell you all you need to know to make a decision.
glad to hear your still around...! i must admit that i'm a little disappointed the next generation lh cars won't be fwd. hopefully dc will at least offer awd.
rikstr,
whether the inner wheel well is plastic or metal makes little difference. the problem with the lh cars is that they don't have quite enough suspension isolation and therefore road noise infiltrates the cabin more than in cars such as a wallowy camry or buick. the trade off is excellent handling and ride characteristics...
As for road noise though, Emale's right. The fender wells have nothing to do with it. My grandmother's '85 LeSabre has plastic fender wells, and it's one of the quietest cars I've ever driven. I'm not going to comment on handling, though ;-)
Otherwise, still a great car all around. The noise issue is a matter of taste. I kind of like the sounds it makes. The road noise became considerably less when I changed from the Eagles to Cooper Lifeliners. (My family owns a Cooper dealership, so take that recommendation as coming from a biased source.)
Has anyone sprayed the wheel wells with undercoating to reduce the noise they don't like?
Ed
I have 37,000+ miles on my 2000 ES. On Wednesday, the car started acting up. Whenever I took my foot off the gas pedal, the car would stall. I had the car towed to the dealership and the mechanic told me that there was "lots of carbon in the passages in the intake manifold." He also said that there was "lots of carbon in the idle speed motor" and that he would replace it. He said my problem may be due to a lot of stop and go driving.
Has anyone had this problem before? Could this also be caused by waiting to fill the gas tank when the fuel level drops down to an 1/8 of a tank?
