The Sandman :-)
I love my 03 2.5LE (purchased Jan 03)- but at that point, it had comparative advantages- a 165hp 4 cylinder, 4 wheel discs with ABS, and side airbags with head protection.
Now, many competitors offer similar features, more room, better crash scores, fuel economy, etc.
I'd recommend a Hyundai Elantra for bargain shoppers, and if you can find one with ABS and side curtains, the Corolla is an excellent mix of economy, safety, refinement, room, and reliability.
~alpha
-Brian
Great car!!!!
~alpha
Does any one get the spy-shot/info about 2006 sentra? It was great to see the 2006 Civic Si with 2L with 200hp! Hope 2006 SE-R will be more than 175hp!
Turboshadow
Turboshadow
if anyone can help me out i thank you greatly
The dealer is unsure if the vehicle has ABS brakes. This is one of our "must haves". Does anyone know how you can determine if this car has abs brakes short of driving it? Is there a code in the VIN# or somewhere else in the vehicle.
BTW it has 41000 miles and he's asking $6900. What should the vehicle sell for in good + condition?
Thanks for any feedback.
The plastic dipstick broke inside the tube, had to spend hours to fish it out, only to be replaced by another that is just as bad. Uses much more gas than expected. I have an '89 Honda Civic that I don't even take good care of, and yet never gives me problems and still gives me 35mpg after 239k miles. I would recommend anything other than a Sentra!!!
The car isnt tops in its class, and one similar to mine is no longer offered, but I LOVE it, and can't wait to see what Nissan does for the redesign. At this time, I think the best bet for most people is a Mazda 3 with ABS/Side Curtains, a Corolla LE with ABS/Side Curtains, or on the bargain front, a (soon to be replaced) Elantra with ABS.
~alpha
I have a 200 Sentra GXE, I was wondering if anyone had any ideas to upgrade my performance. If it is even worth it. I only have 31,500 miles. so far its been a good little car. besides for the Mass air flow sensor and both axles going bad
http://www.greghome.com/Greg's Garage/2002MaxSE/In-Cabin Microfilter Change.htm
I have a 2001 Sentra GXE. 71000 miles. The engine light first went on 6 weeks ago. The car started to run rough (like missing) and idled low. I took it to the local Nissan dealership and the diagnostics showed an O2 sensor was bad. So I got it replaced. They said I should also change the plugs in case a plug misfire caused the problem. So after the $280 O2 sensor and $80 plugs (yep, $20 a piece NGK's) I took it home. The light promptly came back on. Angered (I'll keep it clean), I took the car to another place (ProCare). They diagnosed an O2 sensor problem. They said the dealership replaced the wrong one. After $264, the 2nd O2 sensor was replaced. I took the car home. The light promptly came back on and the car AGAIN was running rough. More irritated, I took the car 100 miles to another Nissan dealership in hopes of finding either competency or honesty. As you can tell, I do not trust these places a second time after they rip me off. This dealership said that the ECU was bad and needed replaced. They said that because Sentra ECU's are known for being bad in this particular year, it had an 8 yr/80000 mi warranty on that part. So they replaced it free of charge to me.
My issue is this: I probably did not have a bad O2 sensor. I spent almost $600 replacing parts that were probably in perfect working order. Ok, I'll meet them half way. MAYBE one O2 sensor was bad. But most probably not both. Do you guys know how I could contact a Nissan rep to see if I could get any restitution? Would it be worth it? Thanks in advance for any advice.
Thanks for any help.
The Sandman :confuse:
It always has spark. Pcv valve, egr valve, MAP sensor it any, or what? I'm sure it's some kind of vacuum deal, but I'm not sure where. This was so sudden, that something obviously broke. The exhaust isn't clogged.
Thanks for any Ideas. Lurid Lloyd
I've seen other Nissan wheels on EBAY and very hesitant about switching rims as the car runs smooth as glass now and I don't want any problems if I do switch. I know there's a problem with different fitments and they have to be hub centric. Went to a rim store and they advised me to keep my steelies as I would never get the same smooth ride with any other wheels. Saw some nice one's at Sears also.
Any thoughts or suggestions would be great.
The Sandman :-)
Here are the highlights or my 5 years and 57K miles with the sentra GXE.
Wheels replaced do to recall. No charge.
Hesitation when engine is cold. This occurs without fail if I don't let the car warm up. I'll drive a block or so to the first place where I gradually let off on the gas in anticipation of stopping. The engine stutters just for a second and then runs fine. I don't have this problem in summer months. I took it to three dealers while it was under warranty and none could duplicate / diagnose the problem. I even left if over night so they could experience the cold engine. No luck. So far this is just an annoyance, but I fear someday the other shoe may drop.
Air Conditioner - faulty wire. During the first month after purchasing this car new I noticed that on some days the a/c would stop producing cold air for short periods. Of course the dealer could never find the problem until - you guessed it - 2 months after the warranty expired - they found a wire bundle that had a short. Problem solved for ten cents worth of wire and $100 labor.
Alternator belt. Shredded itself at about 38K miles. Seems premature to me.
Front wheel bearing. Starting grinding at 55K miles. Decided to replace both just in case. While they had the front wheels off the mechanic shows me the rotors. The outer 1/8 inch was rusted. He explained that while the surface that made contact was still serviceable, the outer edge would soon contact the pad assemble or something like that. I frankly didn't understand what he was saying, still don't. Anyway, I bought his sales pitch since he said that there would be no labor charge for replacing the rotors since they were already off for the bearing change. Total cost for the bearing and rotor replacement -- $480. ouch. By the way. The pads were still good. Has anyone ever heard of a case where the original break pads lasted longer that the original rotors?
I average 36 mpg on the highway, 30 in town, and 32 mpg combined and I check it on every tank. Best ever 40 mpg, worst 29 mpg.
Overall, not a bad car. Knowing what I do now I would make the same choice if I had to do it over again. This was the new model (basically same as current) in the summer of 2000 when I bought it and at the time was IMO the best choice in its class.
Lastly, if I ever meet the sorry so and so who designed the placement of the oil filter and catalytic converter I'm going to strangle him. The filter sits directly above the converter surrounded by other engine and suspension parts. This makes it extremely difficult to remove/replace and results in oil dripping on the cat. That leads to a burning oil smell for the first week after every oil change. Not to mention the thrill of burning your wrist on the cat as you struggle to detach the filter. :mad:
Does anyone know of a manual override for this? Is there ANY way to get the cd to come out without taking it to a shop? Thanks for your help!
Tom
Got the part in and fixed 2 days later.
The Sandman
However, while in the on-position, it tries to start--and this can be heard as the engine turns; it just does not turn on the car.
The lights, radio, windows, locks, everything works. Just not the car itself.
Problems leading up to this problem include the 2002 Sentra quitting while driving. No warning, just stopping while driving. It would start right up again after having stopped, however now it does not.
I switched out the fuel pump relay, but it was to no avail either.
Do you guys think that the problem is a faulty fuel pump itself or is there another culprit?
I went in for the recall on the ECM foam a couple of months back, however I believe that the damage to my ECM was already done, as not long after having had the recall, my car started dying while driving.
After attempting to self-diagnose, I finally had it towed to the Nissan dealership this morning.
Their diagnosis? Their reader was not able to connect to the car--the same problem I was having with my OBD II Reader.
So, their "diagnosis" was that I needed a new computer--and THEN they could see if anything else is wrong with the car.
They haven't even checked wires/cables going to the ECM--they are just charging me for a new ECM.
Mind you, I would be okay with this, had there not been a reason leading up to this ECM failure--the reason for the recall was to stop the result of not having the recall in the first place--as they say on their recall page on the Nissanusa website: "This may also result in the "Service Engine Soon" light coming on or poor driveability. If the engine stops running while driving, this could result in a crash without warning."
My car still did this until recently when it just would not start.
I'm stuck over the weekend without a car because, after having called multiple Nissan spokespeople (via their (800) numbers), I was left on a string: I can't get my car from the Nissan dealership without paying for a new ECM which (1) I'm not ultimately sure is necessary, and (2) I would have to pay for--but I believe should be covered.
Needless to say, should there be no responses to this post, I'm quite an irate Sentra owner at this moment in time--a shame because I enjoyed my red car. :sick:
(1) Cracked evaporator pan in the a/c which left a puddle of water in passenger foot well. took going to 2 dealers and finally showing the mechanic and service writer that there was "water" to get the new pan put in.
(2) Replaced the rubber seal around the trunk lid and cardboard piece over spare tire last week. The spare tire well had water down there and they said this rubber strip needed replacement.
What is the ECM and where can I find if my vehicle is included in the recall? The only thing I don't like is the mileage, but after 2 diagnosis...everything is "in specs", so they say it's o k. Wish it had mileage like my past Corolla's, but car drives nicely and much better since the "Poortenza's" that came on the car have been swapped out for great Turanza tires.
Any help on this ECM issue would be appreciated!
The Sandman
http://www.nissanusa.com/form/0,,action-NRecallPublicLanding_sctid-51054,00.html
Just put in your model and year!
