For some reason my tires only last 10K miles too, and I do NOT peel or smoke them. But I do take corners a bit more aggressively than normal people."
Taking those corners at 90mph can sure wreak havoc on tire milage.;-)
just my two cents.
lets pray they fix the transmission problems. mine is fine but problems are numerous. anyone know if they have replaced it with a new one or just re-worked the old? the hand brake is a big mistake, why not leave the foot pedal?
so far, not to impressed, maybe driving it will change my opinion.
Until about 5000-6000 miles in my 98 Accord, I used to feel a slight jerk between shifts (especially 1-2, and sometimes 3), and accelerating during cornering (I'm a leadfooted driver) would leave the tranny wondering.
And then there was a noticeable difference. The only time 1-2 shift is felt if I accelerate hard and force the transmission to shift past 3000 rpm. The other shifts go unnoticed and in the situations when the tranny appeared confused have not come back. And now I have about 90K miles.
So, give it about 7500 miles, and you should notice a difference.
Just surfing the web when I found this. I have nothing to do with the pictures or the writing. I just found it while surfing the web.
Has anyone been able to determine the angle of the brake handle? The S2000 has an e-brake that is angled away from the driver (pointed at the passenger's side of the dash). It means that the pull action is up and toward your body. Very nice. I was hoping that the TL would use a similar design, but I'm doubting it. Has anyone found a pic that gives a real clue?
P.S. the tranny in my TL-S is only getting worse with age.
Mercedes-Benz tends to offer cars with manual transmissions and underdash emergency brakes. That, combined with the awkward action of their manual transmissions leads some to conclude that they really want buyers to specify the automatic in their cars.
There's no jerkiness at all with the new drivetrain.
And with the market segment that the TL is competing in, I'm amazed that anyone would complain about a handbrake. The TL has always been both entry level lux and on the sporty side, but the current gen was designed with an automatic transmission in mind, hence the footbrake. But now, with the greater availability of a manual, staying with a footbrake would be a big mistake, IMO, mainly for the reason cited by bobshiftright.
Any issues with throttle tip-in are issues with the cable-linked throttle, not the engine. The new TL is rumored to use a drive-by-wire system like the TSX. That should cure any problems at the pedal.
On the handbrake, I'm another who thinks this is necessary with the manual transmission. I can appreciate the desire to have an unobstructed console, but the 6MT version makes the handbrake a necessary compromise.
I believe that Acura has always tried to be the affordable performance & luxury marque, but they've failed since the Legend. The cars were neither luxurious nor sporty. The last TL and the MDX have been the best showings. The new TL, TSX, and rumors concerning the RL show signs that they are serious about getting the mix correct. The 6MT and HPT package are two of those positive signs.
As far as handbrake, I like the foot-operated one in the current TLs and don't like the idea of going back to handbrake. It's a terrible obstruction in the center console and doesn't do anything useful for those with automatic transmission.
Any Opinions would be appreciated...thanx.
I am one who feels they are going away from the luxury feel to a sport feel. Not sure if I care for it yet. Lets hope the price is not more than 33k without navigation.
just a thought !!!!
Yes, for this generation, mostly because manual transmissions were only available on higher priced specialty models (Type-S). With this generation, it looks like you can get a manual on any TL, so I'm guessing there will be quite a few more TLs with one. So the changes make sense, since the handbrake is such a necessity for the manual and is entirely functional with an automatic. Besides, there are lots of precendents... many other cars (Accord, Altima, Camry, Maxima, A4, BMW 3 and 5 series, Lexus IS) come with handbrakes with either manual or automatic.
It's not likely to change, so I guess you'll either have to get used to it or look for alternatives... but as I noted above, many of the likely alternatives have the same feature.
http://www.acurainspired.com/gallery/view_album.php?set_albumName- =albuq16
However the transmission is crap.
And why do you like the foot-operated parking brake so much? Is the hand-operated brake sticking in the way of your purse?
king_george, those are the pictures of NY Autoshow concept car, not the real '04 TL.
But for now, I am going to beat those 260 horses to the ground.
Hope the transmission is changed.. because I sure have a problem with it.. on top of the engine... I tested one out before buying my CTS.
Explain to us the problems you had before you ventured off in Caddy Land.
Did the transmission suddennly down shifted on you or better yet, did the engine fall out of the car?
I can tell you this for sure, the Acura is a far better car than the CTS- IN MY OPINION.
If you don't like Caddy, which you probably don't because of your comments, that is okay. I don't care, because I personally do like Caddy. Please don't fight with me..I am telling you.. I didn't like the transmission in the TL. In my recent post 'transmission problems' which I said... I admit that I made a mistake.. i should've said I don't like the transmission and I prefer the Caddy too in styling.
If Acura applies the same principles that they've applied to pricing for the last four years, the 2004 TL will be priced very competitively at the MSRP. And it is not going to sell for anything below MSRP for at least a year.
The tranny does suck and yes the engine is o.k. but the throttle needs to be reworked.
Just tell me if it is the same tranny and engine.
