Visitor Agreement.
with 155,000 miles. it has been a great car, I am the original owner and have taken good care of it. Nothing major has happened to it except a blown out radiator
around 90k, and I recently replaced the supercharger with
a $250 used one that works well, except the typical smoke on startup many get.
Anyway, on to the question at hand...I have been told it
is caused by a small transmission sensor that goes off
by accident sometimes, and that the only way to really fix it is to replace the entire transmission. Bummer for you if it happens alot. At 155k, if it starts happening alot I am trading in as a new tranny is not worth putting on a car which will be most likely pretty done at 200K. As I said,
while a bit scary (and has only happened on the highway at high speeds) it doesn't really seem to be serious. As you said, it resets after you turn the car completely off and
back on again. See if yours happens only when the car is cold. That has seemed to be a factor with mine, it has only happened in the chilly weather.
I have a 2001 2.5 Millenia with 121,000 miles on it. I currently use 89 unleaded fuel but the manual said 87 fuel would be okay but at the cost of performance. I've heard some people talk about engine knockings when you use 87 fuel on the Millenia. Fuel prices are soaring these days so would the 87 fuel work okay with my Millenia?
Sorry for the delay in responding. That is the drawback to this medium. Hopefully you have not sunk too much money into the solution and not found a remedy.
-Lambster
It turned out to be the distributor. Once replaced problem solved.
Here is my problem, when the car starts cold, and you keep it running without turning it off, it runs great. If for any reason you turn the car off, and start it again before it cools off (2-3 hours), the engine light will start flashing, and the engine will run quite bad. It will run, but rough, like timing, misfire, injection are not correct. It will stay this way; sometimes the engine light will stop flashing, but stay on, until you turn it off and let it go back to cold before starting again.
I can drive it for hundreds of miles with no problems, as long as I don’t turn it off.
Any ideas???
The Mazda Club Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
Our local good guy radiator shop told me that cars like Mazdas tend to be finicky about their cooling systems. You have to be very careful to get the system well-burped, eliminating all air bubbles in the system. I had the radiator out for inspection (no leak or low-flow rate problems) and replaced the thermostat and hoses. Having been warned, I was extremely cautious about bubbles.
Cooling system now fine. Recently drove from Fort Wayne to Evansville with no problems and honest 28.5 MPG (adding acetone) on the way down. That was the best it's ever done.
By the way, I think the car gets 15% better mileage with acetone than without.
Steve
just found this site and appreciate all the wonderful info. I bought my son a '96 Millenia S lst year with 84K miles. It now has 92K and I have no idea if the timing belt has ever been changed.
Any thougths on the cost of changing the timing bet? Should water pump be replaced at the same time?
it's been an excellent car so far. Thanks!
I've been told by 2 different mechanics that this is an interference engine? Is the Millenia S different than the non "S" engine for timing belts?
You also need to call 1-800-lemon law. Sometimes thats all that works.
Good Luck
Thanks for the advice.
Transmission:4-SPEED AUTO OD TRAN 2W FWD
Engine:2.5L DOHC V6 24 VALV
I entered my VIN on the mazda website and this is what it came back as!
If premium is recommended, then using it will gain you more power and better mileage. However, with the S, the knock sensor cannot always react quickly enough to compensate when the supercharger spools up.
Make sure the expensive 60K service was done (timing belt, plugs, etc.). Use premium and enjoy the car.
thanks!
A broken fuse? A broken thermostat? The protocol for replacing a broken "thermostat" (a part only $18) seems to be a hell of an effort. I'm hoping I read the wrong information.
Could anyone send me in the right direction?--hopefully not to a dealer.
Thanks a bunch.
Someone got a real deal on purchasing my second one from the dealer. It needed O2 sensors and all 60K work. Millenium Edition that sold with 59,000 miles for less than $7,000 (I believe the asking price was like 10K). The dealer did all the service, and the purchaser got a vehicle that was like new.
You likely paid more for the car than you needed to (KBB and even Edmunds list inflated values for these cars, compared for what they are really selling for). You may have been happier with the non-S model, which is just as pretty. I recommend a person buy one either from a Mazda dealer (they will have done the required service), or from someone who has all the service records. O2 sensors will be pricey from a dealer. Shop around for parts.
Tuition in the school of life stuff: it is easy enough to turn off the check engine light without fixing the underlying problem. Running a computer check through Autozone for example might give you a better idea of whether there are any error codes stored on a car you are considering. As for price, a good check is to see what similar models have sold for on eBay.
You need to evaluate repair costs and overall condition. It may be cheaper for you to bring the car up to optimum condition, or it may be cheaper to dump it now. All depends. Has it had the 60,000 tuneup and timing belt change? Is it using any fluids? Any leaks at all? The steering wheel doesn't matter that much...it's mostly for show. Set it where you want it, and then turn the auto feature off most of the time. Less stress on the steering column motor, and the feature will last longer.
AC settings. I checked the fuse and its okay. Any ideas on how to fix it myself
or is a shop going to have to do it?
Tom
