(my resume includes, '78 Datsun B210, 83 Civic, 87 Prelude, 89 Nissan Maxima, 92 Toyota Tercel and 96 Accord(for my wife).
Well, nothing is perfect, I guess.
Many of my friends have 97-98 camrys & they don't have any such problem. Only problem is the oil cap doesn't open on the first time(not good in winter)
I don't care what kind of new car a person buys a new car should never have wind noise and if I were you, I would bring the car back to the dealer and have it looked at.
Good Luck
Since 1998, Toyota Camry don't have a timing belt, instead they start using timing chain. I have a Camry 95 with 128k and is runing strong. the maintenance in this vehicle are cv boots, 2 timing belts,oil changes and tranny filter change. I think I invested in a great automobile.
Right now, I'm contemplating on taking a test drive on another new camry out on the highway to see if it produces any where near such excessive noises as mine...b4 I can reasonably tell Toyota that it isn't my perception or keen hearing! If anyone else has anything else to offer or suggested course of action...I'd certainly would be very appreciative. I have a feeling this is going to be lengthy process.
'00 XLE V6 ~2800 very noisey highway miles
Concerned about extra passenger and/or vacation weight in pick-up performance on 4 cyl. Price difference seems to be around $1100. Any comments would be appreciated. Thanks!
0-60 for Camry 4 CYl is 10.5 which is same as the grand caravan & 6Cyl is 7.9-8.0. So the performance difference is big one as such.
Camry will be redesigned in coming 10 months I suppose & rumoured to have 155-160 on the base model.
but a place to try is:
www.camryman.org
want to spend extra money for a LE V6. One thing
I am satisfied is that CE doesn't have front
reading light (map light) unless with a power
sunroof option which is not available for CE.
Is that possible for me to get a 5 speed CE with
front reading light? Thanks.
Moon99
I can only guess that maybe one of your rear windows is not closing correctly and is leaving a small gap for the wind/air to come in. But in any case, something needs to be fixed as there should NOT be that kind of wind noise coming in....
I also get a swamp smell from A/C upon start up. If A/C is used the smell goes aways in a few minutes. If I don't use A/C swamp smell stays much longer. Dealer sprayed something in which did nothing. I am waiting for the do nothing zone rep to see the car. This same car took 6 trips to dealer who couldn't fix shimmy in front end. Independent garage balanced wheels on Hunter road force machine.
Its a nice car but should be better than this.
I finally took my 2000 LE Camry to the dealer last Friday. Yep, the dealer heard the noise as well(rear door, right hand side).
They replaced the outer window rubber seal thinking that was the cause. Well, we (the mechanic and I) test drove Camry with new rubber seal, the wind noise was still there. The whole
Saturday they have not call me, I do not what there going to do next. The car is still in the shop. Now, this is like owning non Toyota Cars.
By the way, this Camry is built in Japan.
Will post more stories later.
Another guy said the his dealership's 2001 Camry's order limit has been drastically reduced for the new year (from the usual 60 for January, Feb, March sales to something like 10-20). There is a rumor that the 2002 Camry might be released in late spring or summer.
Can any Toyota dealers here shed some light or confirm the rumor?
rdavid222: Is there any way to go back and parse thru the old postings for topics that pertains to "noise" or "wind noise" rather than look thru every post?
2000 XLE V6 ~3000
I got my LE back last night.
Here is what happened.
1. The dealer offer me to test drive a brand new 2001 Camry (no more 2000). After the mechanic and I drove it, we found no same noise. Meaning no noise on this particular Camry.
2.The dealer test drove my Camry with new rubber window seal(post #180) and heard noise still.
(We drove the identical course).
3. The dealer and I drove another (randomly selected)2001 Camry, and no wind noise.
After steps 1, 2 and 3, the dealer thinks the wind noise comes from the mismatch of the doors(??). The front door and the rear door have a gap in vertical direction on the right side of the car.
Now here is the kicker, with no guaranty, the dealer wants to addust the door (either front or rear door)and play around.
To me, this is like having a medical surgery without knowing what will happend to my body.
I told the dealer that I will think about it and also dealer to slow down on trial on this error methods.
What do you think?, have an operation on my brand new Camry.
It sure is pain ....
This is not what I expected from Toyota.
I must admit that the dealer is really trying hard to get this thing resolved, but this is not the dealers fault. It is THE QUALITY PROBLEM.
2000 LE, 4 cyl, Japanese built
Ok, I took my Camry in today. The service manager went on a test drive with me and he heard the obvious wind noise @50+mph, and we just drove around the block. I told him that it was much worse on the highway, and he told me he should've taken it out on the highway. After we came back into the service area, he gave me this BS about how every Camry has such inherited noise. He then proffer me to take a test drive on any vehicle on the lot; however, I did not have the time so I will have to come back and do that.
Also, I have a feeling this service manager is telling me the standard explanation so as avoid further costly investigations unless I start to gripe more vigorously from this point on.
Questions: Does the wind noise emmanate thru the front pillars in your camry or just b/w the seams around the doors?
Lastly, if you decide to go through with such "exploratory surgery" on your camry...I suggest that you get a written guarantee from the dealer/Toyota. I'm also curious if they'll lend you an equivalent loaner while such actions take place?
Hope things go well if you decide to go ahead with it and keep us posted.
A gromet in a hole for the wires to pass thru to the mirror control motor had been pushed out towards the mirror.Another had a door missing on the backside of the speaker that mounts in the door. Another pushed some weather seal in the window seal.
Also found a lot of frustrated souls!
Given (somehow) your E-Mail address I could attempt to forward the search results to you, but the above summarizes my search results to date.
Well, my wife and I are thinking about leaving it alone as is. We do not feel it is good idea to have a surgery (major) on this Camry, specially there are no gurantees. Too bad.
In my case, the dealer did not give me any misleading BS, they really tried HARD to make this go away. Yesterday, I went to the dealer and talk to the sales manager and complained to him.
The manager told me that his leased Avalon have same sort of wind noise. Pretty funny. He admitted that it is manufacturing problem. Oh, he tried to fix this wind stuff with new rubber seals (twice)but wind noise is still there. He did not try any more fix on it. Since he works there, a bad idea to push his luck by asking for more trys. Besides, it is leased.
The mechanic told me that these later Toyotas exhibit far more problems than older models.
Anyway, most likely, I am not getting any operations done on my Camry. I may put some tape over the mismatched area and drive it around this Thanksgving Weekend and see what happens.
Oh, I want to say that I am not a difficult consumer. I rather spend my time away from car dealer (or auto shops)and enjoy my life.
Be back with more sagas.
But too bad this camry is over price and less power only 136HP.If you like more horse you gotta go for the Nissen sentra SE it has 145HP and you
save some couple thousands dollars.
The V6 will likely use a derivative of the Lexus 3.0L engine currently used in RX300, making 210-220 hp, (Highlander V6 will use the 220 hp RX300 V6).
Recently, my brother-in-law (an autobody specialist) noticed a yellow marking on the inside of the door near the hinges. He said that was something used by auto body shops. Also, we found some auto body sand paper behind a panel in the trunk. Next, I checked with carfax.com and they revealed that the car was owned by a rental company before I purchased it....not by the Toyota Company.
It is obvious that the dealer lied to me. What recourse do I have ? Is there a state or government penalty that can be assessed against the dealer ? Can anyone help me ?
Also, my sunglasses holder never worked correctly. One of the tabs keeps coming loose when you open/close the holder door. A friend who owns a 2000 Toyota Tundra Pickup has the same assembly in his car, and he has the same problem. The dealer tried a few different doors, and has ordered an entire replacement assembly.
The car is very nice, very quiet. My ears pop when the door shuts...which is pretty cool. Its quieter than my Infiniti I30t. I should have opted for the 6 cylinder engine however, even though the 4 cylinder is adequate. Overall, the car is great, except for the minor problems.
Occasionally on business trips, the rental I get would be a Camry (98 or 99). I never noticed any wind noise.
I bought a 99 Camry last year (v4) and noticed wind noise at 55+ mph. About 6 months later, I got broadsided and this totaled the car. :+( However my 5 year old daughter and I walked away with just a few bruises. :+)
I went back to the same dealership and got another Camry (2000, v6). I expected to get the same wind noise, but to my very pleasant surprise there was none!
I figured it was the LoJack dude that introduced whatever caused that noise to happen. The second Camry already had the VIP system installed, so I opted out of the LoJack.
http://www.toyota.co.jp/Showroom/All_toyota_lineup/Camry/interior/images/int02_vga.jpg
http://www.toyota.co.jp/Showroom/All_toyota_lineup/Camry/exterior/images/ex01_vga.jpg
http://www.toyota.co.jp/Showroom/All_toyota_lineup/Camry/safety/index.html
I have a 2000 Camry (4 Cylinder). It has about 14,000 miles on it. A couple of days ago while I was on the way home. The engine light suddenly went off. After I had read the owner's manual I thought it was the gas cap loose. I had tried to tighten it up and the light still stay on.
I had read the Jrct9454's remark, it may be the O2 censor? could anyone help on this?
Some also say that it won't go away at all, and that you need to have the light reset by the dealer.
Well, you could try to get your dealer to reset the light. If it's indeed the gas cap, it should not come back on after the reset (you did tighten the cap right?). But if it comes back on, then you will probably need a engine diagnostic.
I am going to the dealer to have it check sometime this week.
I was wondering, is there going to be another promotion from Toyota soon, like, in a couple of months? They used to have $750 rebate running for a long time. But I forgot what months were those.
TL
