To Fix Up or Trade Up, That is the Question
larry767larry767 Member Posts: 1
Folks,
I need your advice. I have an 89 Reliant, 4 dr. with the 2.5 Litre engine and A/C (no other options). I bought this car 16 months ago with 114,000 km. I put on 225 km/day commuting to work and back so today it has 163,000 km on it. Today, the alternator died on it. Aside from a set of tires, this is the only major problem I've had with it.
It is due for a tuneup for sure and possibly some other major maintenance. I've been getting around 28-29 miles per imperial gallon. Due to the amount of driving I'm doing I'm considering trading the K car off on something that gets better mileage.
My question is, should I be wary about things going wrong with the K car and look to trade up to something more reliable and better on gas or should I just spend some cash on a tuneup and other items to bring it up to par?
If the answer is to fix up the K car, what items should I have the mechanics check out knowing that I've done nothing to it and don't know the history of it's first 114,000 km?
If the answer is to trade up, what would one recommend for high reliability and fuel economy based on 225km/day of driving? Note that I only have about CAD$3000 to play with and can't afford to buy or lease anything new.
Thanks in advance for your opinions,
Larry Jorgenson
Humboldt, SK, Canada
«13456718
    I don't think I'd trade a known vehicle for an unknown one, especially in the price range you are shopping in.
    You should look at repair and maintenance costs in relation to monthly car payments on a new car. Can you fix this old car up for say the equivalent of $100 a month? Well if you can, then you won't finance a new or nearly new car for anything near that, and buying a cheap used car might easily result in $100 a month bills anyway.
    I'd say that unless there is something really dreadful wrong with your car, I'd fix it up.
  • wtd44wtd44 Member Posts: 1,208
    And I agree. The math seems to say you have a very good deal going with what you have, versus the alternative you outlined. Run the K car until it is well worn out, then go for the "trade up." I personally have had great luck with (preDaimler) Chrysler vehicles. I have not yet owned any of their vehicles built since the merger.
    It's almost always cheaper to repair the car that you currently own. Most people just want a new/different car and they will use a couple of expensive repairs as the economic justification for trading. I usually buy a 2-3 year old vehicle and put 150000 miles or more on it before I sell it.
  • marmommarmom Member Posts: 2
    I need some advice. I have a 2003 Acura MDX that has a crease in the liftgate and a scratch on the bumper. The body shop estimate is $600 to fix. I will be purchasing a new vehicle(not another Acura) soon and trading the MDX in. Should I fix the back end or trade it in as is? Thanks.
  • driftracerdriftracer Member Posts: 2,448
    for several reasons. If it's traded/evaluated with the dent in place, you have to understand that used car managers are not body shop managers, and don't estimate down to the penny. They may decide that what you have an estimate for of $600 is actually a $1600 hit.
    Driving up with a damaged vehicle also prompts going over the vehicle with a fine tooth comb. That little ding or scratch that wouldn't have been noticed on a normal walk-around gets seen and there's a few more hundred dollars lost.
    Having "curb appeal" is priceless. Get the dent fixed, get the vehicle detailed, and drive up with a clear conscience and a beautiful rig - a quick walk-around, and you'll get all the money for the rig that you deserve.
    Thanks so much for the advice. I will do that.
    long story short, but in reality, that $600 dent could cost you $2k at trade-in...
  • junglyboijunglyboi Member Posts: 1
    I've had my 93 SL1 (and associated headache) for a year now. The week after I bought it, something happened and the car was overheating ... extremely. Since the sales lot I bought the car from mysteriously vanished (the entire lot!), I took it to a Saturn dealer.
    The dealer replaced the water pump or a sensor or something - can't remember now - total bill $650. When I started up the car on the Saturn lot, the car was shaking vilontely (had not done this before). I shut it down and walked back inside.
    The informed me that my timing chain had skipped (funny they didn't notice it when they had my car in pieces). So they wanted another $1,000 to fix that). Total bill now $1,650.
    I came back a few days later and started my car again which now puttered (evidently to a bent valve). They said that it would cost another $950 to replace the valve. I was now completley out of my savings. So they said that it would be ok to drive the car as long as I didn't mind the puttering at an idle.
    On the way home I realized that my accelerator now had a point after an inch or so of being pressed down where it became stiff. I figured out I could push harder to get past the point I needed to be able to merge into traffic without being run over, but that the power I had when I first drove the car was now about half. I took it back to the dealer (3rd time in one week) who said that I had a bad throttle box (of course I don't even know what these parts are). They wanted another $900 to fix that (funny how every repair is $900!!).
    I figured I'd tough it out until I could afford to have it repaired. Until about another week goes by and the alternator goes out. A friend of mine knew how to replace the alternator so he did. I can afford free :)
    But now as I'm driving down the road the headlights (and dash lights) just sporadically dim out for a second or so and sometimes the car nearly stalls just idling. My friend doesn't know what the problem is. The alternator was a new part.
    So now, I have a bent valve, dimming headlights, sticky accelator, sometimes have to jiggle the battery cable to start it, and on top of it all it seems to burn oil quickly.
    Here's my question. Am I just a glutton for punishment hanging on to this car, or is it worth saving up the money to fix all these problems? And are these problems normal on a car this old with 146,000 miles? Do I keep the car or get rid of it like a hot potatoe?
    Given the car's resale value and mileage, and given that you have no used car lot anymore to sue for being ripped off to begin with, I would definitely pull the rip cord, take the painful hit and put your money into something worthwhile.
    So much money wasted-- what a shame. I vote with Mr. Shiftright.
  • cutehumorcutehumor Member Posts: 137
    I would drive it until the engine blows without putting anymore money into it. or sell it asap. I had bad luck like you did. I bought a 138k/10 yr corolla for $2k. I junked it after the head gasket blew and got a reliable car. It needed alot of work!
    High mileage vehicles are like time bombs waiting to go off...
  • armtdmarmtdm Member Posts: 2,057
    Not so if maintained rasonably well. todays engines can easily go 150,000-250,000 miles with decent maint. A new tranny, front end etc, is always less expensive then the depreciation hit when that new car leaves the lot. I have three over 100,000 now and doing well and all are safe and realiable cars to drive anywhere.
    I think wdt44's point was not to contend that some engines do in fact go 250K, but rather this: that after a certain point, a high mileage vehicle is subject to sudden and unpredictable disaster. The statistics suggest this is true, just look at the odometers in any wrecking yard, on cars that were not in collisions. Some bad and sudden thing brought them there.
    For this reason, I like to advise people to pay very very little for cars with over 200K on them, as their lifespan could be measured in days....or months...or years...nobody knows what's going on in there. Engineers never planned for engines to go that far.
    Right on! I can't imagine that I would ever buy a car that had over 200K on it. In fact, I would walk away from the vast majority of cars with 100K. Only desperation would get me into that position. I like 'em new or near new. During the last quarter of the first 100K of my own miles, I start looking to move on. I don't recommend this avenue to anyone, rather I am just reporting that this is the way I go about it.
    I'd say about 175K on a modern car or thereafter, it could drop dead any minute and, in terms of market value, is essentially worthless except as a high risk beater. I'd certainly pay well below wholesale book, even for a well maintained car.
    Think of it as if you were buying a 40 year old pitcher for your baseball team. His arm could be gone in one pitch.
    Dude, you need to contact the hosts to have them delete your post - they don't do the cursing thing here on Edmunds...
    They should delete the poster as well.
  • crankshaftcrankshaft Member Posts: 105
    Several months ago my 91 cougar with 3.8L(84k)blew its head gasket.The #3 cylinder received a good dose of coolant.The engine did not seize or overheat.The body is in very good condition,many new parts were installed prior to the disaster.I do not know whether is is a good investment to fix this thirteen year old vehicle or sell it for parts.These engines are known for doing this and I fear it would happen down the road again.I would appreciate any feedback.
    The car has such little value, it would be difficult to justify---unless all else is perfect and the miles aren't too high. But the cost of repair will exceed the value of the car. Probably you could just go out and buy another '91 cougar in nice shape for less. I'd say don't do it unless you do all the work yourself and you need "garage therapy".
    Some cars are "one major event" from being basically totalled.
    You might even consider a junkyard engine swap, but as Mr. Shiftright says, you gotta need garage therapy to stand it. You mentioned parting it out-- would you do that yourself, or were you referring to selling the unit to a wrecking yard?
    It really has so little value. A wrecking yard might take it for free but wouldn't give you anything...well, maybe if you drove it there, $35 or something.
    parting it out doesn't make sense, either. What are you going to do with a partial car in your driveway?
    So to be realistic about it, you either have to fix it yourself or give it to a kid or something to fix up.
    thanks for the input.i can do some repairs but engine swaps and head gaskets are a little too much for me.bad thing is i had month old tires on it when it quit.i am going to put it up for sale,cheap.hopefully,someone with the skills and patience might find it worthwhile.
    there you go. That is a sensible approach I think given the value of the car and the severity of the problem. You never know what you're going to find when you open an engine.
    Why not sell the nearly new tires at a reduced price, and the deal is the buyer must also take the car they are on! Uuuuuuuuuuh... just a... thought.
    like if you use your supermarket card,buy four slightly used tires get car free(after rebate???)
    That's it!
  • vs001vs001 Member Posts: 3
    I have a fully loaded 2001 eclipse GT with only 30000 miles that I have babied for the past 4 years. Got hit badly by a hailstorm that also picked up some gravel and stones. The front windshield was cracked and the sunroof and rear windshield were smashed to bits. Some water also entered the car and wet the carpet (didn't see too much water on the dashboard).
    When I drove for a short distance, i smelled something burning and the speakers started making a hissing sound and then loud creaking noises. I immediately pulled over and turned off the car. The hissing/creaking from the speakers continued although key was removed from ignition.
    Got the car towed to a body shop where an adjuster looked at it after 2 days and said it might be totaled. The battery has been disconnected to stop speakers from making sounds. My guess is that the amplifier is shorted, but i don't know if there are bigger problems. The radio does not turn on but the speakers make noise anyway (if the battery is connected).
    The car is in excellent shape mechanically and I would like to know what is the best course of action if the appraiser's estimate is close to 80% of Actual Cash Value.
    1. I could argue that they repair it. Would they be required to pay for further damages within the next few months if there is further damage to sensors etc?
    2. Take the money they offer and buy a new/ slightly used car. Nada guide has the car at 14,100. KBB has it at 13000 (accounting for leather, sunroof, alloy, in dash cd changer etc)
    3. Take the ACV less Salavage value and keep the car. Get the glasses fixed (about 2000$), amplifier replaced (about 500$ plus labor) and ignore the little dents on the body which I am told pop out in the Texas heat. If i do take this option, is there some way I can get the electrical system examined to check for possible damage to other sensors (body shops in the Austin area don't seem to have much experience with electrical systems and the only dealer is 30 miles away and I don't know if i should be driving there)? Would you recommend disconnecting the fuse for the amplifier circuit and driving the car short distances to get estimates?
    If anyone has knowledge of Eclipse, do you know if there are important sensors under the seat/ on the floor?
    Also, if the car were totaled due to hail damage, do you know how it would show up on on title searches such as carfax? i.e. would i be doomed if trying to sell the car in a couple of years?
    Any help would be much appreciated. Thanks.
    I think if you are satisfied with the settlement check you should bail out on this car for any number of reasons, the biggest one being that with a salvage title and hail damage you cannot presume anywhere NEAR book value. So you would be investing in a severly depreciated asset and yes, there would be great difficulty in selling it.
    Given what you describe, I can't see how it wouldn't be totalled. Flood damage is almost always an automatic total these days.
    Mr. Shiftright pretty much said it all. Grab the money and run! You'll be doing other Eclipse owners a favor by supplying some good parts to a wrecking yard for them to buy as needed. >:o]
  • nell1nell1 Member Posts: 1
    I am hoping someone can help me with my problem.
    I have a 95 sl1 automatic with 155k miles on it. I was driving today and I noticed a funny burning smell... kind of like burning rubber, but not quite. It kind of had a sort of a burning hot metal smell to it, it that makes sense. I had been driving for a while and the engine was hot. the RPMs dropped very low when I came to a stop. the temp gauge went up over the halfway point. It started shifting gears erratically and the SES light came on. I pulled over to check it out. Tranny fluid was good, oil level good, belt seemed to be in ok shape. I couldn't see any obvious problems. I read the engine codes and I got a tranny code 23 (no 3rd gear.)
    It may have been my imagination, but it seemed to me that I had to brake much harder to get the car to stop and that the steering was looser. I also go a nasty lurch from the change in gear when I slowed to make a stop.
    I had previously noticed recently that the RPMs always seemed much lower than they should be while idle, especially when the engine was warm.
    I have also gotten the same tranny code several times before.
    any ideas what the problem could be?
  • dodgekbaddodgekbad Member Posts: 56
    Would that hold true for my k car as well? It's an '88, 2.5l, with a fryed tranny. The mileage reads 59k however. I've got the car fax when I first bought it, 6 mo. ago, and it's supposedly original mileage. Although it was a 1 owner, and tough verify I guess. I suspect it was rolled back.
    Anyway, the shop gave me a base estimate of $1289. Other things....The rack leaks, and the rear brakes need fixing too (and leak also). the car consumes oil like crazy also. Th eboots might be ripping too. I am starting to answer my own question. But the thing is very very clean. The exterior is immaculate however. I've never seen a 17 yr old car with paint this good. Recently I replaced a sensor myself and cap, wires and plugs.
    Best way for you to evaluate this situation is this: Go do some research on classifieds and find out how much it would cost you to BUY a really nice, really cherry car identical to yours.
    I think you will find that you could buy one "ready to go" for less than it would cost to repair yours. If that's true, then really you know the answer. If a replacement car in top shape is, like...DOUBLE your up-coming repair bill, then maybe you should fix yours.
    Sounds like you are looking at $2,000 easy to get this car in shape and that's without correcting the oil burning issue.
    I would think that the high oil consumption (along with serious tranny problems) is the cardinal sign that this may be one to avoid fixing up, UNLESS you can do nearly all the work yourself and are highly motivated to do it.
    It leaks oil - I don't think it's burning it. I can see new, shiney oil on the top part of the engine. It's a leaky gasket I think. But the leaky rack has me worried. I've put in 4 bottles of Lucas and have it pretty much under control. Whether it will will hold up 'til Sept., and pass inspection - that's another story - and another $500. That I could get a used one howver and take care of it for under $175.
    I am thinking of going with a used one. It's $200 with a 30 day warranty. My problem is: who will put it in? Every real shop wants $800-$900 - hardly worth it at all. The Kelley book value is $1000 and the NADA is $1200-$1700 (not 100% sure on the NADA, and that's retail). The junk yard guy says I could probably get someone "across the street to do it." I figure that would be another $250. But it'll be a junk yard tranny - installed at another junk yard. Good luck with a warranty and/or having a tranny that doesn't leak oil etc. And the $250 installed is a guess. That's an estimate I got from this other junk yard who said they had a tranny for me, but later realized they didn't. Ugh! Not sure on this or that....sounds like I know what to do - junk it.
    There are some wrecking yards that will clean a used tranny, remove the pank for inspection and even pressure test the unit, bag it up and warranty it.
    I think I can get it installed by an indy shop where I get gas from near work, from a guy I can somewhat trust. He wants $400 to install, I think. So in total $600. But he was saying no warranty - and why not let him rebuild for $1100 with 3yr. warranty? He says if it doesn't work that's another $400 to remove. And the car is at a shop near my home; the indy shop is near work - 16 miles from home. Towing could be big$$$$. I have to find out if my cell phone tow insurance will cover it. Is $600 a decent gamble; Seems like a lot. I can empty the bank and get $3000 car wholesale from my brother in the car biz as soon as tomorrow at auction...In the meanwhile I am getting killed on gas on an '81 caddy loaner....Advice?
  • Kirstie_HKirstie_H Administrator Posts: 11,242
    OK, I am SO not an expert, but this would raise a red flag for me. You used the phrase "somewhat trust," which isn't a ringing endorsement. Is he planning to do a worse job for $400 than he would for $1100? Personally, I'd look for someone who gives you ONE price.
    kirstie_h
    Roving Host
    Host, Future Vehicles & Smart Shopper discussions
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    $400 is for installing a junk yard tranny
    $1100 is rebuilding my existing one
    Seems fair
    I'm thinking blood is thicker than water, as the old saying goes. I'd be visiting my brother on this one, were I you.
    No warranty, no dice.
    I have a buyer who is willing to pay more for the car (AS IS, knowing all the damage) than what insurance will deduct for salvage. However, insurance says they will not pay TTL if I keep the car. Is insurance supposed to pay the TTL irrespective of whether i keep the salvage or only if I give them my car?
    That's right, if you keep the car you don't get T&L.
  • blueiedgodblueiedgod Member Posts: 2,798
    I have a 1988 Honda Prelude Si 4WS that has been in the family for years and now no one wants it. It has been sitting in my garage for 2 years. I would drive it once in a while and changed all the fluids last summer. The body is starting to rot, but the engine and tranny are like new. Starts on the first crank and shifts smoothly. It has 130,000 miles and needs new exhaust. The on-line places sell Monza pacesetter headers, flex pipe, cat, midpipe and resonator, muffler for $500. I can probably install it myself. The question is, will the car be worth more with new exhaust if I were to sell it than without? As of now, I have sitting outside asking $700, had one kid drive it, he liked it, but wanted me to put in the exhaust and keep the price the same. I doubt I would be able to sell a 17 year old car for more than $1000 even if I fix the exhaust. It will need timing belt replacement soon, as the last time it was replaced at 60,000 miles. The only reason I have been hanging on to it is because of its rarity.
    I'm no expert, but personally, I'd say $700 as-is. Seems like an ideal car for a student-type person who is very mechanically inclined. It's not going to be the type of vehicle that attracts someone who has to rely on a shop to fix everything, but it should be relatively easy to take on as a DIY job. You're right that you're highly unlikely to get more than $1K for it no matter what you do, so why put money into it that will take away from your pocket.
    Review your vehicle
    The 4WS Preludes were interesting but they never proved to be very popular or handle any better than the regular ones. They were NASTY to unload from the transport trucks and near impossible to drive in icy or snowy conditions. A real handful if you didn't know what you were doing.
    At 130,000 miles there is probably a lot of life left in that Prelude. I'm not sure what you mean by "rot". Even if it's a total rust bucket it is WELL worth the 700.00 you are asking for it.
    The last thing I would do is put a Micky Mouse exhaust system on it. I wold sell it AS IS. For 700.00, it's a screaming deal!
    Sell it as is for whatever you can get.
    I don't know what part of the country you are in, but some parts of the US are more tolerant of rust than others. Here in California, a badly rusted car is basically wrecking yard material.
    Installing a complete exhaust system is no easy task, either, even on a lift with air tools and welding equipment. Don't go there, please!
    Tell the kid to take it or leave it for $700. You're price is fair enough.
    I have a91 cougar which has a blown head gasket on the V6.it has 84k miles.the body and interior are excellent.the tires were a month old when the head gasket failed.the engine did not overheat and still runs.it is beyond my skills to repair so i bought another car.my question is,what is something like this worth?I hope i can sell it to someone who might want to fix it.
