Any ideas?
However, several of the problems we have had are not unheard of - the dealer claimed many of them are common. This includes the rotors, ingnition switch, dash board, radio antenna, etc. I also noted that the new AC fan motor was a completely different unit. Seems they may have switched suppliers because of problems.
That said, there are things about the car I like, particularly the body styling. But this was our first American made car in many years (over 20 for me), and I would say it will be our last.
One minor thing - one of the driving lights burned out a month ago. The wife had it replaced at a local Goodyear shop. They used a similar bulb, even made by the company (Sullvania), but it was marked "3157" instead of "4157."
Well that one burned out in less than a week. So, I headed to a local GM dealer (we are fresh out of Oldmobile dealers around here) and bought the correct bulb. These bulbs do not appear to be common, so I would recommend going to a dealer should one of yours burn out. Cost was only $8 each (I of course bought a spare).
Glad my home has gas heat. :-)
With my foot off the brake and my left turn signal on, the left rear parking light dims each time the rear blinker flashes. Any ideas?
HTH
No, I checked my turn signals and all of them flash. I guess I'll have the dealership look at it, since I have an extended warranty on it. Of course, I'll get down there and won't be able to reproduce it.
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
Not a bad time to start looking for a replacement. In a five-year old car that's being driven 25K miles a year, the problems only increase, not decrease.
I have a '98 Intrigue with 75K that I bought used and drive 7-8K a year. If I were driving as much as you do, I'd be driving something else - not a five year old car.
Anyone have any insight into what the recall is for?
If you have a recall notice from gm regarding your intrigue my suggestion would be to read it through and let us all know what it says.
2001 3.5L and no recall notice
Fuel filter - Never replaced. Should I? How many are there, one or two?
Fuel injector & throttle body cleaning - Never done. I haven't noticed any hesitation or lack of power. Worthwhile service?
Dexcool Coolant - Never replaced. The stuff is supposed to be good for 5 years, 100K miles, right? Should I wait that long?
Transmission fluid - Never replaced. My driving isn't severe, but I'm not sure I want to go 100K miles before having it done. Should I chance it?
Serpentine belt - Never replaced. How long are you guys waiting? I usually replace belts before 70K miles.
A/C service - Never done. Is this really necessary if you aren't having any A/C problems?
Front end alignment - Never done. No uneven tire wear or pulling, not sure if this is necessary.
As you can tell, I haven't spent much on maintenance for my car up until this point. I think I probably spent more on maintenance for my wife's Saturn SL.
- oil changes
- fuel filter, around 50K
- serpentine belt, around 60K when it showed some deterioration
- no fuel injector cleaning and doubt it is really worthwhile as all gas now has some cleaning additives in it.
- coolant is supposed to be good for 5 years but mine was changed when the water pump was replaced (around 50K)
- transmission fluid looks good on dip stick so I have not replaced it
- AC has not had any problems, I don't think there is any preventative maintenance for this system other than to make sure it periodically runs to keep the seals lubricated
- no front end alignment has ever been done, if the car tracks straight and doesn't pull it should not be necessary
- front brake pads replaced at 60 K, rotors were not resurfaced as they were repaced at 44 K
Hope this helps.
I don't have an Intrigue, but do have a '98 Aurora with similar maintenance concerns. This is what I've done/I would do in your shoes:
Fuel filter - replaced at 42K mi (4+ years - bought the car used). Will replace every 30k mi from here on out.
Injectors, nope. Throttle body cleaning yes, only if needed (if it's gunked up - had it done around 45k - my IAC motor had to be replaced, so they were in the neighborhood). Will do again in another 40-50k mi (2-3 years).
coolant - supposed to be good for 5 years. I've "heard" (and previously experienced in my '96 Lumina) that the Dexcool slowly changes into a brown goo. If yours is still orange, it's fine, but if the overflow tank is getting crusty, get it flushed. Had it done at 34k on mine when the water pump went (GM paid :-)
Tranny fluid - I always have service by 50k mi. Never had a tranny problem with a car. I know some folks who work at dealers/have "free" access to the equipment, and they do theirs every 20-25k mi.
Serpentine belt - replaced it (and the separate water pump belt in my Aurora) around 40k mi. I was stranded once at 3:30 a.m. in the middle of nowhere in northern Wisconsin because my '91 Grand Prix's water pump belt broke - had to climb a tree to get reception on my analog brick cell phone. For the $20 cost for the belt, I don't chance this on any car.
AC service - don't touch unless you're having problems.
alignment - while it is technically possible for both wheels to be turned "in", so your car doesn't track to one side but the wheels are still out of alignment, if you're not seeing any odd wear patterns on your tires, don't waste your money. Do, however, get your tires rotated every 7500-9000 miles.
Just my opinions/beliefs. Hope this helps,
-Robert
GP
My 2001 Impala is noticeably quieter than my intrigue.
Enjoy your regal.
As I read the review, I immediately thought of the first time I drove the new Altima. The first time I accelerated hard from a stop, I ended up in the next lane in about 2 seconds without ever turning the steering wheel. Very annoying and unnerving. Sounds like Nissan has transferred the same problem to the Maxima.
It was a very nice ride, but that solid rear beam axle *was* horrible. It would sort of "hop" when you hit a bump driving at freeway speeds, which is somewhat unnerving. While I would have liked to have the Max's power in my car, I much prefer the Intrigue's highway manners.
I've never driven a Regal GS, but have ridden in a friend's Pontiac GTP; nice engine setup, that thing does move! Both cars are significantly more cheddar than the $18.5 OTD price I paid for the Intrige GL, however.
I'm likely going to bring the Intrigue in for a check up next week. Warranty is almost up and I want to make sure everything is ok before we are on our own. The flicker will now be brought to the attention of my service manager.
In the above section from your post #8923 you mention an "IAC motor." Is this the motor that I hear upon starting my 2000 Intrigue that lasts about 20-30 seconds and cycles on and off sometimes while driving? Should I be hearing this sound? Does it mean something's wrong? I only have about 6,500 miles on the car.
:-D
Well, no more. I was at the local Speedway filling up, and I noticed that the regular unleaded light at my pump was blinking. Well, crap. So, I put in midgrade (89 octane).
About a day later, I noticed that the engine seemed to be a bit gutsier. A few days later, I was at a light and accidentally tromped the accelerator a bit too hard. The car took off like it was on FIRE. I played around with it a little, and came to the conclusion that putting 87 octane gas in this car is a mistake. I know the 3.5's big brother requires premium, but thought (like most people) that anything beyond 87 octane was a waste for this engine.
I was wrong, and I encourage all Intrigue owners to cough up the extra $1.50 or so and try it out. The difference, for me at least, is startling.
That said, if it works for you, great!
Oh well. It wasn't exactly scientific apparently.
CAA
I would definitely answer yes. Mine has been very reliable and has never had to be at the dealer for more than 3 hours... Have about 75,000 miles on it now. Other than trim the only problem was the crankshaft sensor. It does drink about a quart of oil between oil changes.
I'm going to hang on for it a few years and enjoy the 0 payments/pay down the mortgage.
Did I just jinx myself?
