Quoted from "idec.com" (among many other sources, GE lighting, Osram-Sylvania,etc): "Inrush current (initial current through the filament) has an adverse effect on life expectancy. Cold resistance will have a more detrimental effect than hot resistance to inrush current. Life expectancy of incandescent lamps can be maximized by reducing occurrences of cold resistance to inrush current." Like I said... and the main reason why I don't like all the unnecessary automatic on-off business with the headlights.
above graph from Osram-Sylvania
"Describing normal battery drain as "parasitic drain" may be confusing to some"
That's how GM describes the normal drain in their technical papers, like Techlink and in the service manual. That is the accepted term.
I had problems with parasitic drain related to the ignition switch. They first replaced my ignition switch to fix a problem with the Service 4WD light coming on and disabling my 4WD. It was an elusive problem that would clear itself if I turned the ignition off then on again. I happened to be traveling and near a Chevy dealer when it happened again. While the light was on, they hooked up a diagnostic tool and commented there was no power getting to the 'rear grid'. A few days after they replaced my ignition switch, I started noticing the dash lights (gear indicators like P-R-D, etc) stayed illuminated even after the car was off and the key removed. I went on vacation for 10 days and came back to a TB dead as a doornail. So dead we had to push it out of the garage and jump it for 20 mins before it would even click when I turned the key.
They replaced the ignition switch a second time, told me the first one was installed incorrectly (done at another dealer). The look in their eyes told me I don't want to know what they really found inside my dashboard.
Meanwhile, I am wondering if the severe battery discharge incident caused damage to my battery and my less-than-robust cranking on these cold days as opposed to DRL load.
Your thoughts and opinions appreciated -
That will take some life off of it.
How cold has it been?
If it's around 20 or so, I don't notice any difference in cranking. When it's 10 or less, the slow cranking is noticeable, but that is to be expected.
BTW did a search for "ignition switch" got two pages of old messages about various problems and switch replacements, so don't feel alone!
There is no defogging capability on the side glass. You may see the On-star antenna, or other glass etchings.
This would apply for the 2002-2004 TB, Envoy, Bravada, as well as the earlier body styles 1995-2001, since I have both styles.
'02 Envoys had an optional diversity antenna system, with antenna elements on the L & R rear side quarter windows. That's probably what you see. Also, there's no vertical mast antenna if it has the diversity antenna system. I think they did away with that option on the '03s.
"Most of us have played around with halogen bulbs and found out that the only thing that really decreases life is over voltage and high G-forces."
tblazed, why would anyone describe a normal condition "normal drain" as a "parasitic drain". The two are not the same. As far as rush current is concerned, if the bulbs are designed to withstand the .004 second rush of higher current the first time they are turned on, they should last for the average expected life of the bulb. The .004 second of higher current is factored into the life expectancy rating. I have never seen a warning label on a bulb "caution, turning this bulb on will shorten its life expectancy". Every part in our cars will break sooner or later. Sooner if you use them , later if you don't. I once heard that the life expectancy of the average car driven an average of 50 mph. was only 2000 hours. I could not believe it until I did the math, 50 m/h x 2000 h = 100,000 miles. Most cars don't reach 100,000 miles.
BTW, are tungsten filament bulbs and Hologen bulbs considered the same for your graph?
"The new Envoy Denalis will be unveiled next week at the Chicago auto show along with the Chevrolet Uplander, Pontiac Montana SV6, and the Buick LaCrosse."
Any pics available of the Denali Envoys available?
My 2cents
You must be very hard on your vehicles! I had over 190,000 miles on my '68 GTO when I sold it. And about 140,000 on my '71 Chevelle when I sold it. My '88 S-10 has 98,000 miles on it, and still going fine, no problem. It is certainly going to "reach" well over 100,000 miles. What are you talking about??
"BTW, are tungsten filament bulbs and Hologen (sp) bulbs considered the same for your graph?"
It's not my graph, it's Sylvania's.
They all have tungsten filaments. The "halogen" is a gas added to allow the filament to burn hotter, put out more light and not evaporate the filament onto the inside of the quartz glass bulb.
My point was the figure of 2000 hours for a operating life of a car. If your car lasts 140,000 miles that comes out to 2800 hours.
You got me on the spelling of halogen. That was carelessness not ignorance.
I still think your belief that bulbs burn out quicker if used more often is short sighted. Halogen bulbs will burn out quicker due to surface contamination from hand oils rather from turning them on and off as designed. Vibration is another factor in bulb longevity. More vibraton, less life. How would you explain the longevity of radio tower bulbs. They flash on and off all night for years before burning out. Certainly they are exposed to rush current.
Your recommendation would hold true for HID headlights. They will burn out quicker if turned on and off often, especially if they are not allowed to cool off between cycles.
Here's some GM reading material for those interested in battery "parasitic drain".
4-2002 Techlink Battery Parasitic Drain Issue
This will cause a check light, at least. The fan clutch is managed by the pcm (computer), wouldn't recommend it.
Mind you, I'm not complaining. It's one of the few intelligent designs in the car.
Good Luck
quickdtoo said, "If you have wintry condtions regularly the 4x4 will be appreciated." Where do you live? Last year was our snowiest on record here in the Mid-Atlantic area, and with 4x4 I didn't skip a beat (because of snow, that is). My boss lives in FL last year got a 2x4 and now is relocating to PA and he is selling it to get a 4x4. Also, consider if you will ever want to go off-road. I've had some fun in deep sand on the Outer Banks of NC, and climbing a fairly steep hill on a washed-out abandoned dirt road in VA to find an old church/graveyard to do some genealogy research.
ficuss said, "My TB has been ok, but I doubt I would by another G.M. mid size SUV" Because of all of the quality problems I have had (2003 model year) I seriously considered a buyback and I will never buy another American-made automobile. I decided (at least for now) to keep my TB because they gave me an extended service plan and feature for feature, the TB does offer a lot more creature comforts for the price than the others. However, had I test driven a Nissan Xterra before I bought the TB I probably would have bought it because:
(1) My past positive experiences with the legendary Japanese engineering and manufacturing quality
(2) $6,000 less for top of the line model Xterra compared to my mid-level TB XT
(3) the difference between the two was not worth an extra $6K IMHO.
So, if you're a gambling man - go for the TB 4x4 with an extended warranty. It can be a nice vehicle - and it does offer a lot of value for the cost, that is, if you don't value your time.
Get the 2x4 - it may just give you your life back!
February 6, 2004: 9:50 AM EST
DETROIT (Reuters) - General Motors Corp. said Friday it was recalling about 1.8 million cars to fix an electrical defect that can spark fires in the steering column.
http://money.cnn.com/2004/02/06/news/companies/gm_recall.reut/
GM Recalls 824,000 Cars to Fix Power Steering
January 12, 2004
http://consumeraffairs.com/news04/gm_recall.html
...and for those of you who have the pinging in your engines after startup...there's this:
GM Stealthily Buys Back Noisy Trucks, SUVs
November 26, 2003
General Motors has been quietly buying back dozens of full-sized pickup trucks and SUVs after consumer complaints about knocking noises from the engine, consumer lawyers said.
http://consumeraffairs.com/news03/gm_buyback.html
Lucky us...my spouse has a Tahoe...it's not pinging, but my TB does...
like the cars in the articles, they have ignition switch problems - just haven't been recalled (yet)
gotta think some parts are used in more than one vehicle -
my dash still runs very hot - too hot to touch - I'm wondering when the fire will start
Bottom line,
Quality and company reputation matters.
the comments were intended for the person who was shopping for a new truck.
- Best Value: For the price, I could not find more horsepower and features.
- I get a GM Supplier discount. This amounts to about $1000 below invoice. It's the price the dealer paid to get the car onto their lot. They still make some money from GM due to a holdback. (GM pays the dealer every time they sell a vehicle)
- I've owned all GM since I started driving and have found them to be very reliable and good performing vehcles. I have no use for a gutless Toyota that can't get out of its own way. The downside is the resell value. If you expect to sell it in two years, you will not be happy with the price you get for it. I tend to hang on to my cars for 7-8 years / 150K-180K miles.
Invoice price is $31,332
GM Supplier price is $31,047
GM Employee price is $29,853
The GM Supplier discount price is printed on the invoice, and from what they told me it does not change by region or for what supplier you work for. So, what's your secret? Are you a GM employee?
Also, where are you guys getting air filters from? Are they available in the aftermarket or are the dealer only? What do they cost and how often should they be replaced?
I'm getting ready to replace my first air filter in my Envoy at 15,000 miles. They have them at NAPA for about $21. If you have a AAA card, they also give a discount at NAPA, so I think I got it for $19. I have a question for those of you who have installed one, however. Do you have to remove that crossbar that goes across the air filter housing, or if you loosen the 3 screws can you slide that housing out from under the bar? Thanks for info.
Todd
Anyone ever heard of True Flow? They make a foam filter for our trucks, as well as an intake system. I like the idea of the foam. If anyone here is using one, I would love to hear an opinion.
Took 10 minutes to put 10 gallons in. Toyota passed Ford for #2 in the world, won't be long before they are #1 if this keeps up.
GAM
You want quality? How about something as fundamental as putting gas in the damn thing. This morning I couldn't. Two different pumps, as slow as they could pump, pump, click, pump, click.
I was once told that the dreadfully slow gas station pumps were due to a clogged filter on their pumps, and that they need to change their dirty pump filter.
GAM
The first time I went to put gas in my TB, mine went pump, click, pump, click too. I pulled the pump nozzle about 1/2 way out and found a position where it would fill without cutting off, but if you set it and walk away it doesn't shut off before it overflows and runs gasoline all down the inside of your rear fender, then the fumes fill the inside of the car and stay for hours.
Hasn't happened to me in awhile because now I stand there and hold the nozzle 1/2 way out for the entire fill. Not fun on these 10 degree days in freezing rain. I estimate how much gas it will take to fill 'er up, then when I get within the last gallon or so, I slow the nozzle and listen for the gas to come up the neck so if it doesn't shut off, I don't spill too much. I'm getting pretty good at guessing how much it will take (but it shouldn't be this hard).
Gotta love those undocumented features!
