I have a completely different vehicle, a V6 Chevy S10, but I wasnt happy with the trans shifting either. It should be the same trans in both trucks.
I bought a Hypertech Power Programmer, initially not to change the shift pattern but it had that capability and I was unhappy with the factory setting so at @ 5,000 miles I reprogrammed it.
What a difference!! Theres a light I catch about half the time going to work leading up an overpass to the highway.
Before I reprogrammed the shift pattern, I could floor it and maybe get to 45 before slowing down to make the on ramp.
Now I make 45 halfway up the overpass! the factory shift pattern was holding me back.
I think GM has this trans programmed for very smooth (and sometimes time consuming) shifts.
Picked up our 2002 Bravada on Friday and took it on a trip to upstate NY for a long weekend. What a great truck!! We just love the comfort, interior and looks of this beast. The engine is creamy smooth and the transmission is also. One complaint was some trim that was loose inside the driver door, but I'm sure that will get fixed up pretty easy.
I am almost jealous of my wife as she will be the primary driver of the Bravada. I have a 02 Yukon which I love, but I almost which I had bought one of the GM midsize triplets instead. Oh well, only 32 more leas payments and maybe I can switch.
Glad to hear about the Winter Mats from GM being available. Do you have the GM part number for those (both front and rear)? I ordered the mats from WeatherTech but was disappointed with the fit (esp. in the rear). If you can provide the p/n's we can check the pricing thru GMPartsDirect.com. By the way, here's the response I got from GMGoodwrench when I asked about mud flaps:
The part numbers for the mud flaps are below (sold as pairs, molded guards cannot be used with fender flares, only rear guards can be used with running boards).
part # description 12497428 flat splash guard with contour, 9.70" wide, no logo 12497434 flat splash guard with contour, 9.70" wide, with GMC logo 12497606 molded front splash guard with GMC logo 12497607 molded rear splash guard with GMC logo
The part #'s for moulded mud guards that you listed are the correct p/n's. Factory running boards on an Envoy has nothing to do with the guards not fitting on the front!!!! Don't know what they mean about the fender flares. I have an Envoy with factory running boards,moulded guards front and rear. The fit is great. I painted them to match the color of the vehicle. (blk)
I have installed the molded guards on my Trailblazer and they fit perfectly. I don't know what the fender flares have to do with anything. I have running boards and again, they don't interfere. The instructions were clear and the mounting hardware provided. I think GM did a great job with making these parts available.
I'm happy to say the same for the hood deflector and side window vent shades.
Another accessory I picked up was the load stop / canoe carrier. Once the brackets are mounted to the roof rack rails (5 minutes) the bars can be attached or removed in seconds. They have integrated locks to ensure they are not removed by others. The racks are much more usable than the stock rack bars, raising the load and ensuring a strong flat set of bars for carrying a serious load. They also come with adjustable load stop brackets to keep things from moving side to side, as well as 4 web straps to secure the load to the bars. Nothing moves on this set-up. I was actually thinking of removing the stock cross bars since they are not much use, given their curved shape. Great for wind noise but not much else. I prefer the new rack which is easily removed in seconds. I have used it to carry my canoe as well as to transport beds. You can also get attachments for the bars to carry Kayaks, bikes, skis etc. Great Rack, highly recommended.
Recalibration did not work. Unfortunately no codes show up. The service tech is taking the vehicle home tonight hooked to some electronic device to see if he can pinpoint the problem. Service bulletin # 290801 had no effect. My dealer here in RI is most helpful and I will keep everyone posted.
First off, the Accessories brochure (sp?) is out, GMGoodwrench Internet Response Team was kind enough to send me a xerox'd copy of their's (they only had one). The doc number is ACC-CA-0168-01. Second, re: my post #2618 and guards on front can't be used w/ running boards, that came directly from the response I got from GMPartsDirect.com and is also stated in the accessories guide. It made no sense to me since I couldn't see how they could come in contact w/ the running boards but that's what GM says. If folks say they work fine that's great news. Third, they have the Custom Vinal Floor Mats out, I suspect they will fit much better than the WeatherTech ones do. Pewter: Ft - 12497749 Rear - 12497716 Oak: Ft. - 12497748 Rear - 12497715 GM's list price is $47 for the front pair and $36 for the rear pair. Much cheaper through GMPartsDirect.com but S&H charges will kill it if you only buy one item, the more you buy S&H charges per item goes down. HTH
I took my TB in and left it with the dealer for three days. They still couldn't find the source of the squeal in the right front of the car that occurs above 25 mph. They contacted GM and were told that GM is aware of the problem, but they don't have a diagnosis or fix yet. They will keep working on it, but my dealer didn't have any idea when the fix might be identified.
After two trips to the dealer and 5 days of not having my Envoy, the dealer was finally able to stop the squealing. They put it up on the rack and in four wheel drive so they could be under it to hear where the squeal came from. They also contacted GM (GM is aware of the problem) and they told them to change a specific seal. Here's what's on the Service order:
Inspect for high pitch squeal noise from right from differential intermediate housing seals dragging on shaft. New design seal available per T.A.C. F1447 R&R front differential housing to replace seals & repack with lubricant.
P/N No. 12479012 Desc.: Seal 6.056
GM told the dealer that the part was redesign to correct this problem.
I hope this helps you.
After they did this work, it hasn't squealed since, but only time will tell.
Currently, we have (or had) a 2000 Chrysler 300M. Beatiful car, drives nicely, and is just a great car to own. However, on October 22, we were rear ended badly at a stop light and the car had some pretty significant damage. They ended up deciding to fix it with a $10,000 estimate for the work. From the looks of things, we might have it back by the end of November or beginning of December. However, this is my mother's car and she has said she jsut won't feel safe in the car anymore and isn't going to keep it. So now, we must start looking for something new, most likely an SUV, probably a GM.
Because the car is only a year old, 4 years and a little less than 15 grand is still owed, so purchasing is most likely out of the question. Leasing is probably the way we will go, but as never having done this before, we have to research it a little more. As for which vehicle, we really like Tahoes and Yukons, they are really tough and solid SUV's built off a great truck, but they are a little too much price-wise and the gas mileage might not be the best. In addition, the Envoy and Trailblazer are also very nice, and actually seem like they'd be a little better of a choice, size and feature wise.
So now, I need some leasing information on these two SUV's. I've already seen and read through tlauro's leasing site and it's very informative. Most likely, we'll be looking more into both an Envoy SLE or a Trailblazer LT, not sure on whether 2wd or 4wd. The Envoy SLE has a nice Euro look to it and offers the air suspension and has the nicest interior. The Trailblazer LT is also good looking and offers both the Bose and a driver conveniance package that aren't options for the Envoy but the interior is cheaper and plainer and there's no air suspension.
We still haven't driven any vehicle yet and are currently in the stage of looking at brochures, ads, and most important, price. If anyone who has leased on of these new ute's could, what re some of the basic figures or deals available and what are the prices/payments you have gotten?
I just completed a purchase of an '02 Bravada yesterday. I chose it over the Envoy/Trailblazer because of the 5 year/60k warranty and because I didn't see the need for the switchable 4 wheel drive. I don't plan to tow boats or climb boulder strewn paths. Beach15, I'd be curious to know why you are not considering the Bravada.
Mine is Pewter and has 1SB (Memory Seats), Heated Seats and Bose Radio as options but not 6 disc (we wanted the cassette player). MSRP was $35872 and I paid $32,500 on a demo w/ 1100 miles (about $300 below invoice).
I used my GM Card earnings ($3158) on deal. When the dealer called in to verify the rebate amount, he was told I qualified for an extra $1000 rebate making the card rebate total $4158. Anyone know why??? The dealer did not.
Mileage: 18mpg at steady 72-73mph with a gusty cross wind. 17mpg at a steady 77-79mph with the roof rack bars all the way back. Just learned that the front bar should be placed over the rear door to reduce noise and drag when not in use.
As for the Bravada, I actually do like it myself, but as you may have seen, I was talking about the Trailblazer LT and the Envoy SLE. Mainly because, these two models are lower priced but well equipped and because they have cloth seats because we don't particularly want leather again. If a good enough lease deal is possible though, we might think otherwise.
So, anyone out their who has leased on of the triplets, what are some of the figures you got? I'd like to know how much you put down and more importantly, how much are your payments, if you don't mind? I'm just trying to see what we can afford first before anything else.
I took my TB LT into the dealer to get my left side mirror replaced and mentioned the very slight pedal vibration I get around 60 mph. They ended up keeping it overnight as the service tech was talking on the Internet to GM. The next day they said they cleaned the throttle and reprogrammed a PCM. Said they fixed it. Said the tech drove it before and after and it was gone. NOPE! I can still feel it. Maybe it is nothing to worry about I don't know. It is such a minor feeling you would almost hardly notice it.
Does anyone think there is a need to put a cable lock on the spare tire????
Car Man is the handle of the host and he is very helpful at getting current rates and residules. My guess is GM is still at 6.5% rate with 48% residuals. Not an awesome rate but a very real residule. The result is your payment will be a little higher than it could be, but with such a low residual on an SUV, you'll easily exit it 6mos early or sell it and make some money.
To calculate a payment...just use my spreadsheet from the site and plug in the above for now with the vehicles you've looked at. You'll get an idea of the payments and what not for sure.
There have been several posts on this problem, beginning with message #2523. Sounds like a fix was identified in message 2624. Thanks, Sostrouble for your efforts. I plan to call my dealer and let him know of this. One comment: when I took my TB in last week, I gave him a copy of all the messages on this bulletin board that referred to this specific problem. That made it pretty difficult for them to say it was isolated to just my TB. They took my complaint much more seriously!.
Does anybody know where I can get a good car cover for my Envoy? Also, FYI, I just received a cargo mat from GMpartsdirect.com, part #12497847 for about 47 bucks including shipping. It fits great and looks great (thanks to Cissy for the info)
I believe you should be able to get this from gmpartsdirect.com as well. I know they have one available for the TB, part 12497710, $114.00. Since the vehicles are nearly identical, this cover may fit the Envoy as well.
California Car Cover Company has an excellect selection car covers for any vehicle. They also have a very nice color catalog which goes into detail on the car covers and all the other products they carry. I have ordered from them twice and been very satisfied.
I just toook my TB in today and here's my wishlist: -Whining sound coming from front end, probably similar problem mentioned before -Center console is loose and makes a lot of noise -Making sharp turn causes unknown grinding, not tire against wheel well, metal! -And a recall has been issued for "Transfer case Reprogram"
It's been 2+ weeks since I brought my new TB LTZ home and I've been incredibly happy with it so far! I can't believe how quite it is and how nice the ride. Not bad for a "truck"!
One thing I've noticed though - this morning and on Monday it sounded like a large fan was running pretty hard when I started up my TB in the morning to go to work. I hadn't heard this before, but both Monday and this morning were a bit cold. The noise goes away after a few minutes. It almost sounds like the car is running at really high RPMs, but that's not the case. Anyone else experience this?
No other noticeable problems though (crossing fingers here!)
And king1079 - what's the "Transfer Case Reprogram" recall for? ie: what are the "symptoms" and do you know what vehicles it covers? Thanks!
I have 4wd LT, so I don't know if 2wd is affected. Misc. posts have stated the shift pattern to be inconsistent, so I think they are reprogramming the chip to smooth out shifting.
The sound that you are hearing upon startup from cold is probably the cooling fan. It works on a viscous coupling that allows the fan to freewheel when the clutch is warmed, however it is "locked up" when cold, because the fluid is not warmed yet. I have a TB (company issued) and it does the same thing, usually for about 20-30 seconds. I have also noticed this on other trucks that I have driven, all equipped with engine driven fans, vs electric fans. If you look in your owner's manual, someplace it mentions this, at least it should. It is normal, and is no cause for alarm.
Does anyone know when the latest recall went into effect? I asked my dealer about the TSB thats been out for a couple of months but he knew nothing about it. My transmission is getting so bad now that when I pull off from a stop light there is such a delay that when it kicks in the whole vehicle shutters. When cold there is a total lack of power that is sometimes dangerous. Of course when I've taken it in it is warmed up enough to not be so noticable.
Why don't you print out a copy of the recall and hand it to your dealer? It will inform him/her of what he/she should already know and eliminate any further off putting! :-)
The one I found on the NHTSA has a recall date of 10/31/01 WEB SITE: www.nhtsa.dot.gov/cars/problems/recalls Campaign # 01V334000 Number of units affected: 78004 COMPONENT: Power Train Transfer Case (4-wheel drive)2 MANUFACTURE DATE: 01/2001 - 08/2001
DEFECT SUMMARY: Vehicle description: sport utility vehicles equipped with 4-wheel drive. The calibration of the transfer case module could cause insufficient high speed gear engagement.
CONSEQUENSE SUMMARY: If the gear is not engaged, the vehicle can roll when the transmission is in "park" and a crash could result without warning. CORRECTIVE SUMMARY: Dealers will update the transfer case control module calibration to increase gear engagement.
I guess I found the problem. There is no recall listed for the Bravada although I did find it in the Envoy. I wonder if they have included the Bravada in the recall. My dealer certainly won't jump through any hoops to please me.
My guess is the Bravada is not included as it's all wheel drive not 4WD thus a different system that thankfully for owners, doesn't suffer the same fate.
Thanks for posting this find! I will probably be brining in my LTZ for the recall and the tranny squeal yet this week. I just wish I could find more time.
gmdrone: Thanks for the explanation of the noise. I figured it was something like that - and since I didn't see any other problems, I figured it wasn't too worrisome. And believe it or not, I read my owners manual cover to cover the night I brought the Trailblazer home, but I don't recall any mention of the noise I was hearing. Not to say it's not in the manual - just that I don't recall reading it!
king1079 and sostrouble: Thanks for the info on the recall - Since I have a 4WD it looks like my TB will be going back to the dealer eventually. I'm assuming a recall notice is in the mail...
I may be incorrect, I drive 6-7 different vehicles per year, always read owner's manual, (good BRM), and I may have read in G-van manual, M-van manual, S truck, etc. I must admit that while I've noticed the problems others have talked about related to transmission, I don't worry about it too much, as the only time I've noticed it on my TB is when it is first started from cold, and being 45 years old, I have always let a vehicle warm for 1-2 minutes before I even try to move it! I think that goes back to my autos with carburators, they would almost always stall out without a manual choke! This truck has 9000 miles on the clock already, and I cannot say anything bad about it except for the on-center numbness in the steering, (plays havoc in a crosswind), and the fact that it doesn't get what I would consider good mileage. (17.2) around town. Other than that, I find it to be a very nice ride, of course I had a 2001 AWD Astro before this with 23,000 miles when I turned it in, and that is like comparing a Freightliner to a Camaro!
My complaint: Whining noise coming from front end; Solution: Bleed air from bladder on steering system My complaint: Grinding noise when sharp turning; Solution: Oil& Lube guys must remember to lubricate chassis when changing oil My complaint: Loose center console; Solution: Re-install center console Recall: The adjusted the timing on transmission to make it nice and smooth!
We bought our LS Trailblazer a few weeks ago, and have a thousand miles on it already. The first thing I added was a WeatherTech bug shield that was the easiest I've ever installed and looks and fits great. Then purchased Husky mud guards for the front and rear. The rear ones were a little harder to put on as I had to remove the wheels to drill the holes. I was surprised that I was only drilling though plastic, no metal, but they seemed to hold OK. I did notice that the plastic moulding inside the wheel wells were missing screws/fasteners. I recently ordered Husky winter floor and cargo mats but haven't received them yet (20% off sale price still totalled $216, ouch). I'm wondering if anyone has added running boards or steps. I've started researching them and am considering the Lund X-step. My kids are having trouble climbing into the back seat and could use a step.
As of now, has anyone heard that GM has fixed the issue with the memory of our outside mirrors?
I'm brining mine in on Monday for the Recall Fix on the Tranny and TSB for the Squealing Transfer case but no one there heard about the mirror issue...odd?
I'm considering a 2002 Envoy, I've looked at a number of vehicles and noticed in many cases, the thin black plastic trim which covers the roof pillars contain air bubbles. Very similar to air bubbles in a decal. Has anyone else seen this condition? Is there any easy fix, or does the trim have to be replaced?
The trim seems very flimsy and provides lots of opportunity for installation variance.
HAD MY TRANSMISSION RECLAIBRATED THIS AM BY MY DEALER. TOOK THEM ABOUT 40 MINUTES, THERE ARE TWO UPDATES THEY WILL PERFORM. MY TB SURE DOES PERFORM ALOT BETTER NOW, HAVE 5900 MILES ON NOW AND STILL AM IN LOVE!!!!!!!!!!!!
Brought the TB in for a bunch of things, one of them being a low howl from the steering when you turn gently to the right. Almost like driving on grooved pavement. They didn't know what it was. Had to call Tech Support. Got a call this morning and they said that GM has issued a TSB to change the power steering fuild to one that is thicker????. Problem is they don't have any at the dealership. They will get some next week. Wonder what that will do when it is really cold outside? I'll keep you posted on this. A few mentioned that they had flapping doors when driving over a washboard road. Told them I had the problem. They said they pushed the door pins back in. I don't think this will solve the problem. I would have thought they would have adjusted the latch? Anyone have an idea?
myself, a buddy with GMC Yukon XL and two GS 430's are all getting it done. I'm getting the partial kit since I have a bug gard for the hood and with the Trailblazer, the bottom half of my front bumper is Dark Gray Cladding.
Both headlights, foglamps, the bow-tie/grill area and the front bumper and wrap around sections to the fenders are being done.
It's a little over $300 but worth it. I had it on a 300ZX for several years before selling it and it was flawless up front.
I haven*t signed onto this site for over a month but would like to pose a question to any tb owner. I have a tb with 4K miles. It performs great. However, upon start-up in the morning, it seems like the transmission doesn*t engage. By this I mean that I am taching up around 3000 and the engine doesn*t seem to respond as it normally does. The engine seems to make excessive noise since the rpm*s are up but the engine response and normal power is not there. However, after warming up and traveling about 2-3 miles, the problem seems to disappear and full power reappears. I thought that it must be my imagination when I first noticed it about 3 weeks ago. However, today I received a recall notice on the transmission. After signing on here, I have read about many transmission anomalies. Does this situation seem to match any other problems that any of you tb owners out there are experiencing. If so, is this recall supposed to address it. It appeared to me that the recall just involves a safety issue of the vehicle accidentally coming out of park. I*m worried that the problem may get worse as colder weather appears since the problem only seems to exist after an overnight cooldown period. I*d appreciate any thoughts on the situation. Thanks.
For any of you wondering, here's a link to all the official GM pics of the new extended-length Trailblazer EXT and Envoy XL. They're of both the inside and the outside. Yes, that 3rd seat is actually roomy looking and has space behind it like an extended minivan plus a 2nd level fold-up shelf. Only thing is, both of them look rather strange on the outside, especially the Envoy. From the photos, it appears that the longer Trailblazer will have the LTZ's 17" rims also on the LT.
At first I thought it made tons of sense for GM to offer a stretched version of the TrailBlazer. Figured it would outdo the Explorer. Then I thought about the size of the TrailBlazer EXT compared with the Tahoe:
Since the Envoy XL/TrailBlazer EXT will eventually be available with the 5.3L V-8, you could also assume that they both tow about the same. In fact, the Envoy's wheelbase is 13" LONGER, making it probably superior for towing. The only thing smaller about the Envoy XL is the width which is just 4" smaller. In fact, the Suburban's wheelbase is just 1" longer and length is only 12" longer than the Trailblazer EXT/Envoy XL.
Having said that, I would think that buying a Tahoe would make little sense for most folks.
Does anyone know if they have the "weather tech /Husky type" of floor mats from GM yet. I have an Envoy and am looking for them. Dealer says they only have the thin flat ones. Part number would be appreciated.
Remember my post on 11-1 about the repair for squealing. Well, it's back, not as loud, but it coming from the same area. So I guess it back to the dealer to have the squeal check, along with the recall. If either of you come up with the real repair, please let me know!! I've only put about 200 miles on since they repaired it.
I have been following this site for several months and appreciate everyone's comments. On October 8 I finally made up my mind and ordered an LTZ Trailblazer with sunroof, heated seats, limited slip, 3.73 rear, and cargo mat in majestic red with pewter from Frank Chevrolet in Sleepy Hollow, New York. Pricing was $100 over cost. Much to my surprise, the dealer called on November 8 to say the truck was on the way and should be there later that day - incredible - one month from order date to delivery to dealer! I have ordered GM cars/trucks before - the last one, a 1998 Oldsmobile Intrigue, took over three months!
I pick the truck up on Tuesday and will report on my experiences as the miles accumulate. Anyone thinking about a Trailblazer in Westchester should give Joe Valle at Frank Chevrolet a call - nice guy, no BS, fair price without the need for discussion, and he can get the vehicle you want!
part # description
My sale man never pointed it out to me, but I did pay for the deal with the 6 disc CD & SH package included.
Is that CD system itemized on your invoice? If so, then it would seem your dealer is obligated to provide you with it.
tidester
SUVs
I'm glad you noticed this squeal too!
I just started hearing it after about 4,500 miles on my TB LTZ.
At first I thought it was my air intake/K&N, then the luggage rack, tires, etc....now I have some good info. Thanks!
Anyone else have a sqealing or high pitch sqeal/whistle in the right front side?
tim
http://www.timlauro.com
Tom
you can jump over to the leasing section of yahoo's town halls and find out the current rate and residules. "Lease Questions - Ask Here" Nov 3, 2001 3:15pm
Let me know if there is anything else. Good luck.
http://www.calcarcover.com/
tidester
Host SUVs
Will keep you all posted on the results.
tim
-concerned parent...My Children Below
Thanks again to all of you!
tim
Let me know if you have any questions.
tim
Okay, here's the pics!:
2002 Trailblazer EXT & Envoy XL
Envoy XL Tahoe Suburban
Length: 207.6" 198.8" 219"
Wheelbase: 129" 116" 130"
Height: 74.9 2wd 76.3 4wd (probably same height with XL's 4wd)
Width: 74.6 78.8
Weight: 5020 5050 5219
Will the 3rd row be available in Trailblazer, Envoy, and Bravada?
What can we expect tthese vehicles to cost when they come equipped with the 3rd row?
Thanks all
And I hope the 3rd row is easily remouvable or maybe even optional - I'm more interested in additional cargo than passengers ...
